KFC-225: If it uses the same servos as the KFC200 &
KFC150, etc, it is not a PWM system. In the KFC 200: They have a bridge of power transistors in the servo along with a couple of low level buffers. The input to them is a linear signal on two lines: + right and + left. Only one at a time is energized. The op-amps that runs it are in the main box. The summation of the tachometer output that is located in the servo actually happens in the main box. Donno... ARE they different? Like KS-270A, etc? (The A model servos have IC buffers instead of the discrete ones used in the earlier servos). I have a hunch they did use the same servos... they would have saved a ton of certification costs by doing that. BTW: What happens to these is the brushes wear and the motor back end gets packed with carbon. Makes them start in a jerky manner. If enough carbon gets packed in, the bearings can fail. Way to observe: The FD bars move, but the control wheel does not. They are regular Globe motors, so the brushes for the same size can be found. Bill Hale |
| Thread Tools | |
| Display Modes | |
| Operation without a transponder | flyer | Piloting | 11 | September 14th 04 09:48 AM |
| Operation Cyanide and the USS Liberty (was: Navy crew remembers 1967 Israeli attack) | Issac Goldberg | Naval Aviation | 20 | July 12th 04 02:35 AM |
| "A Guide to Self-launching Sailplane Operation" available as a download(new edition) | Eric Greenwell | Soaring | 0 | March 23rd 04 07:27 PM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| Honeywell Cited by FSDO in Pilot Administrative Action! | Larry Dighera | Piloting | 3 | November 5th 03 04:04 PM |
