Light Sport Aircraft
Old January 5th 05, 01:58 AM
On Tue, 04 Jan 2005 18:55:13 GMT, (sleepy6) wrote:
I haven't researched it since the actual changes in the FARs so you
may be right ... but earlier versions allowed only the ultralight
transfers to be used as trainers and rentals for a limited period of
time. The factory kit ELSA were never allowed as trainers and rentals.
Since the transitioned two-seat ultralights get the same ELSA certificates as
the kit-built machines, I can't see how they could allow one type of ELSA to be
rented and not the other. But I think that's the reason for the 2010 expiration
date; to allow the two-seat UL trainers to continue in their present operations
for a reasonable amount of time.
BTW, Jim asked what the significance of 2010 is. It's just the date the FAA
selected at which time Experimentals will no longer be able to be used for
training purposes. No other significance, I think....
Also the factory kit ELSA and the SLSA that moved down to ELSA were not
allowed anything but factory approved modifications. We never got an
answer about modifications on the transfered ultralights. It was real
confuseing because they refered to transfered ultralights as ELSA also
and we had to see which ELSA we were dealing with as we looked up a
reference to a different section. That may have happened when they
wrote the actual FARs.
I hope your interpretation is right because ELSA kits were too
restricted for the life of the plane in the early discussions.
I have a sneaking suspicion my interpretation is wrong, just because it *would*
allow a lot more flexibility that I believe the FAA and EAA intended. I've been
given a good contact at the FAA, I'll try get a clarification.
Old January 6th 05, 03:36 PM
I've had a good exchange with one of the inspectors in the Light Sport branch at
the FAA.
1. Owners of an Experimental Light Sport Aircraft (ELSA) must strictly conform
to the manufacturer's assembly instruction during construction.
2. Once the aircraft is completed, the owner is free to change and modify the
airplane as he desires without permission or guidance from the original kit
manufacturer. Just like Experimental Amateur-Built, though, if a major change
is made, the aircraft will have to go back to the Phase 1 testing.
3. Persons owning an aircraft with a Special Light Sport Aircraft (SLSA)
certificate (e.g., production LSAs) may receive a new airworthiness certificate
in the Experimental category upon application (e.g., no prerequisites).
4. When the new airworthiness certificate is granted, the owner must surrender
the Special LSA certificate (which I interpret as meaning there's no going
back).
5. Once the new certificate is awarded, the owner is free to change and modify
the former SLSA as desired without permission or guidance from the original
aircraft manufacturer. Major changes will require the aircraft perform Phase 1
testing.
I did not ask specifically in regard to former two-seat ultralight aircraft, but
given #2 and #5 above, I can't believe it'd be any different.
Keep in mind, though, that this is new ground for the local FSDOs. It's likely
there may need to be some policy documents generated at the national level to
ensure a consistent interpretation.
What struck me during the exchange is how similar the SLSA to ELSA transition is
to the "owner maintenance" category in Canada. The owner of a production-type
aircraft will be able to have a lot more freedom as far as changes to his bird.
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 02:31 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 05:15 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
