In article
, "Kurt R. Todoroff" wrote: In article R5QZd.71896$Tt.15712@fed1read05, "BTIZ" wrote: All of the others talk of temperature rise do to compressibility based on mach number, but no one really addressed the speed accounting for friction of air molecules on the sheet metal which warms the aircraft. War story time, low level over the plains of eastern Montana, near Conrad and Havre Bomb Plots (Radar Bomb Scoring sites) and the outside air temp was about -15F, however, we were moving along at about .88mach at 500ft AGL, and the skin temperature was about 100F, not a worry about accumulating icing. Some one else referred to "Speed of heat" as being Mach 1, because most aircraft need after-burner or "heat" (reheat) as the Brits would say.. to make Mach1. BTDT BT Hi BT, What were you flying? Most of my time is in the F-111D and the EF-111A. I've also flown the F-15, C-130, C-141, KC-10, E-3. Did your aircraft have a skin temperature indicator or a total temperature indicator? Aircraft component heating is due to Mach compressibility, not skin friction. I'm confident that your 100F value reflected total temperature which is based on Mach compressibility. The "speed of heat" received it's colloquial name because the speed of sound is based only on the static temperature of the fluid medium, not on pressure or density as is often mistakenly believed. Kurt is quite correct in this. You can determine the temperature by taking the Mach number, finding the local ambient temperature/total temperature ratio. (all temperatures are absolute temperatures) At Mach = 1.0, the ratio is 1.2; at Mach = 1.5, it is 1.34; at Mach = 2.0 it is 1.8; at Mach = 3.0 it is 2.8. Just add the OAT to 459.7 deg F or 273.2 deg C to get the absolute temperature. |
("Orval Fairbairn" wrote)
at Mach = 2.0 it is 1.8; at Mach = 3.0 it is 2.8. That's-all-you-got? :-) Montblack |
Landing and T/O distances (Was Cold War ALternate Basing) | Guy Alcala | Military Aviation | 3 | August 13th 04 12:18 PM |
Painting and air cooled motor? | CitizenX | Home Built | 5 | June 30th 04 12:47 PM |
Va and turbulent air penetration speed. | Doug | Instrument Flight Rules | 70 | January 11th 04 08:35 PM |
Va and turbulent air penetration speed. | Doug | Owning | 69 | January 11th 04 08:35 PM |
Speed Astir | Guy Acheson | Soaring | 0 | December 11th 03 02:24 AM |
