![]() The only constant acceleration is the acceleration of gravity. A "leaky integrator" with a 2 or 3 second Tau should work fine. How so? the plane doesn't know if it's right side up or not. You can do a barrel roll, or loop and always keep "down" through the bottom of the seat. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Roger That's a good question. I have run every other scenario over in my mind, and it looks to me that the proposed system should deal with them under any normal circumstances. However, I had not considered a constant acceleration "barrel roll" while maintaining the same heading. How to sense that??? My original idea had included an electronic "Gyroscpe" I had eliminated it when I discovered how hard the iMEMS ADXRS300 http://www.analog.com/en/prod/0,,764...S300%2C00.html are to get, but I may have to put it back. A homemade version is available. http://home.comcast.net/~scottxs/pie.../piezindex.htm |
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell | Otis Willie | Military Aviation | 0 | March 18th 04 08:40 PM |
Wing tip stalls | mat Redsell | Soaring | 5 | March 13th 04 05:07 PM |
Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 03:40 PM |
Can someone explain wing loading? | Frederick Wilson | Home Built | 4 | September 10th 03 02:33 AM |
An Affordable Homebrue 60 in DS machine | Grant | Soaring | 0 | August 8th 03 03:52 AM |
