Don't you already have a cigar lighter in the panel?
If not, it's something you need an A&P to sign off (note I didn't say do - you could do the work yourself). Find the right A&P - one who understands what a minor alteration is. Michael |
Michael wrote:
: Don't you already have a cigar lighter in the panel? : If not, it's something you need an A&P to sign off (note I didn't say : do - you could do the work yourself). Find the right A&P - one who : understands what a minor alteration is. Not that I disagree with the fact that this *is* a "minor alteration," but does the FAA consider that to be true? Isn't something that permanently ties into the electrical system supposed to require a field approval? -Cory ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
alteration," but does the FAA consider that to be true? Which FAA? Every FSDO is a fiefdom unto itself. Isn't something that permanently ties into the electrical system supposed to require a field approval? Would that include a T&B? How about a voltmeter? A radio? Post lights? In some FSDO's, you're right - it's considered major. In some FSDO's it's not. The real issue is that unless you bring it to the attention of the FSDO, how are they going to know? You simply need to get it past your IA at annual time. Some IA's will ignore it even without paperwork. Most will accept an A&P's signature and not question his determination that it was minor. And a few assholes will actually ground your plane and make you either pay to have it removed or get the FAA involved. A 337 doesn't save you from this - remember how Honeck had to remove his strobes, installed under a 337, because the IA decided they weren't legal and got the FAA involved? That's why it's important to choose your shop carefully. Michael |
: Which FAA? Every FSDO is a fiefdom unto itself.
Sadly, yes... that's pretty much what I meant. It's dependent on your particular FSDO. : Would that include a T&B? How about a voltmeter? A radio? Post : lights? Yes, I should say so. The only reason not to would be replacing a part with an equivalent part. If your T&B dies, you can legally replace it with an equivalent part without a field approval. A more electrically-oriented example would be if you wanted to add an ammeter to your voltmeter-equipped plane vs. adding a voltmeter to your ammeter-equipped plane. In the former, you need to sever the charging wire and put in either the meter or a shunt for the meter. In the latter you only need a negligible-current wire to run to a voltmeter. I would argue that the latter is a minor alteration, but the former is much more significant. I'm sure the regs don't have any way to distinguish between issues that subtle. : In some FSDO's, you're right - it's considered major. In some FSDO's : it's not. The real issue is that unless you bring it to the attention : of the FSDO, how are they going to know? You simply need to get it : past your IA at annual time. : Some IA's will ignore it even without paperwork. Most will accept an : A&P's signature and not question his determination that it was minor. : And a few assholes will actually ground your plane and make you either : pay to have it removed or get the FAA involved. A 337 doesn't save you : from this - remember how Honeck had to remove his strobes, installed : under a 337, because the IA decided they weren't legal and got the FAA : involved? True. Just shows how broken the whole system is. My question is what in the *HELL* is a "signoff" by a certified IA good for if the next IA and everyone thereafter is responsible for it too? It only serves to hold last guy accountable for everything. What's the purpose of a certification for an IA if the next IA can't trust the previous' work? I don't recall Jay getting phucked having to remove strobes. That sounds like it was an ugly FAA-ism. : That's why it's important to choose your shop carefully. Again, I call bull**** on this. Unfortunately, it's true. -Cory ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
A more electrically-oriented example would be if you wanted to add an ammeter to your voltmeter-equipped plane vs. adding a voltmeter to your ammeter-equipped plane. In the former, you need to sever the charging wire and put in either the meter or a shunt for the meter. In the latter you only need a negligible-current wire to run to a voltmeter. I would argue that the latter is a minor alteration, but the former is much more significant. I'm sure the regs don't have any way to distinguish between issues that subtle. No, the regs don't. People do. There is such a thing as judgment. An A&P is supposed to be able to make a judgment call with respect to what constitutes a major vs. minor alteration, within certain guidelines. The guidelines give a fair amount of latitude. In many FSDO's, the poliy is to make that latitude go away by dramatically restricting what is allowed as a minor alteration. Just shows how broken the whole system is. Well, yes. That's why I don't think it's useful to discuss what the rules actually are and what constitutes compliance - because it changes from FSDO to FSDO, and from inspector to inspector, and if an inspector wants to hang you he will find a way. The only useful things to discuss are (a) what is actually reasonably safe and (b) what you can get away with in terms of inspections. In general, the only reason you need an annual is in the event of an accident, and then only for insurance purposes. You might argue that you need it to be 'legal' but that's a false argument. No plane is ever legal. Any plane can be grounded. Therefore, you're really no more legal with an annual than without. Unless the plane looks like crap or has obviously non-aviation stuff installed, a ramp check will not catch an out-of-annual aircraft - not that ramp checks are common. I don't recall Jay getting phucked having to remove strobes. That sounds like it was an ugly FAA-ism. No. It was a bad shop. The IA had the option of letting the 337 stand, and nobody would have questioned it. For decades, nobody had. I believe those strobes are still in a shoebox. Michael |
Michael wrote:
: No, the regs don't. People do. There is such a thing as judgment. An : A&P is supposed to be able to make a judgment call with respect to what : constitutes a major vs. minor alteration, within certain guidelines. : The guidelines give a fair amount of latitude. In many FSDO's, the : poliy is to make that latitude go away by dramatically restricting what : is allowed as a minor alteration. There is such a thing as judgement, laws by definition do not allow for such a thing. They are written in such a way as to preclude substantial differences in individuals' interpretation. The whole concept of accountability is why many FSDOs are making that latitude go away. If all you have to do is push paper stamping that a DER said a field approval is OK, then it's not your fault if it breaks. : Just shows how broken the whole system is. : Well, yes. That's why I don't think it's useful to discuss what the : rules actually are and what constitutes compliance - because it changes : from FSDO to FSDO, and from inspector to inspector, and if an inspector : wants to hang you he will find a way. The only useful things to : discuss are (a) what is actually reasonably safe and (b) what you can : get away with in terms of inspections. Again, the two fundamental axioms of certified aircraft (and flying in general): A. What's safe is not necessarily legal B. What's legal is not necessarily safe. : In general, the only reason you need an annual is in the event of an : accident, and then only for insurance purposes. You might argue that : you need it to be 'legal' but that's a false argument. No plane is : ever legal. Any plane can be grounded. Therefore, you're really no : more legal with an annual than without. Unless the plane looks like : crap or has obviously non-aviation stuff installed, a ramp check will : not catch an out-of-annual aircraft - not that ramp checks are common. Right... no plane is ever legal. : I don't recall Jay getting phucked having to remove strobes. That : sounds like : it was an ugly FAA-ism. : No. It was a bad shop. The IA had the option of letting the 337 : stand, and nobody would have questioned it. For decades, nobody had. : I believe those strobes are still in a shoebox. I'll say a bad shop. If I remember correctly, there's no such thing as "grounding" an aircraft. It's simply not returning it to service. Seems like one could bail on that inspection and go elsewhere... even if you technically have to fly it there not "returned to service." -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
are making that latitude go away. If all you have to do is push paper stamping that a DER said a field approval is OK, then it's not your fault if it breaks. But all you're doing is pushing the determination from the A&P to the DER. If having the DER say it's OK is good enough, why not the A&P? After all, both are certificated. What's more, you can argue that you have less responsibility with an A&P, since he supposedly met an objective set of standards to be certificated, while a DER didn't. It would be awfully cynical of me to believe that this is being pushed to the DER's because anyone can become an A&P, but becoming a DER is a cushy retirement gig for a fed or someone connected. Again, the two fundamental axioms of certified aircraft (and flying in general): A. What's safe is not necessarily legal B. What's legal is not necessarily safe. Add a third - sometimes you have to choose one or the other, because you can't have both. I'll say a bad shop. If I remember correctly, there's no such thing as "grounding" an aircraft. It's simply not returning it to service. Seems like one could bail on that inspection and go elsewhere... even if you technically have to fly it there not "returned to service." There's a whole discussion of this happening now on AvWeb. Technically you are right. You can require that the IA sign off the annual (as unairworthy) and give you a list of discrepancies, get a ferry permit, and fly to another airport to have the discrepancies resolved. But in real life, that's not an option unless you are at an airport with multiple competing shops and can simply taxi over. First off, you need a mechanic to sign off the ferry permit. We just had one of those issues locally. A flight school plane was pranged at an airport a few miles from home. A local shop did the repairs - but then decided additional repairs were necessary. They wouldn't sign the ferry permit. Nobody else on the field was going to **** in their soup for no good reason (since he wouldn't be getting the business either) and a mechanic had to be brought in to sign it from the home field. If I just told an owner the plane needs a certain repair, and the owner wants to go for a cheaper (and in my opinion less safe) repair elsewhere, what possible incentive could I have to sign his ferry permit? I know he's not coming back to me, so it's all extra liability for no reason. Second, you've just ****ed off the only shop on the field. What are you going to do the next time something breaks and needs fixed? Get a ferry permit every time? That means having a mechanic travel to your home field every time something breaks. And sometimes the plane won't be ferryable. We had a case like that too. One of the flight school owners on the field managed to **** off EVERY A&P on the field, and can't get any work done there. So he had to have a twin flown to another airport with a failed brake. Of course nobody was going to sign off on a no-brake ferry flight in a hot twin, and certainly not anyone on the field. He got one of the flight instructors to fly it anyway. Your only real options, if you are based at a field with only one shop, a (a) Move (b) Deal with the shop, on their terms. They have you over a barrel (c) Learn to do your own maintenance, and get someone to sign off for you Michael |
PDA GPS power issues (i.trek Mouse) | Mark Morissette | Owning | 8 | March 24th 05 02:14 PM |
Power management on a O-300 | Victor | Piloting | 0 | July 9th 04 01:09 AM |
Cessna buyers in So. Cal. beware ! | Bill Berle | Owning | 92 | June 26th 04 03:24 PM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Piloting | 1 | November 4th 03 12:57 AM |
Aircraft engine certification FAR's | Corky Scott | Home Built | 4 | July 25th 03 06:46 PM |
