Speed of Heat
Old March 19th 05, 02:57 PM
Julian Scarfe
The stagnation temperature I recall is roughly given by the following:
Ts/T1 = (1 + (M^2)/5)
"Mike Rapoport" wrote in message
link.net...
I have flight manuals that give a correction for airspeed and altitude and
the numbers are much higher than 3C even though the speeds are below M0.5.
In the MU-2, the temp sensor is in the tail section where the cross
section of the fusilage is actually decreasing..
I think the problem is only with the numbers that got plugged in. At M =
0.5, you get
Ts/T1 = 1.05. In other words a 5% temp rise. 5% of about 273 K is about 13
K,
i.e. 13 degC.
Is there both a compression and a friction heating of surfaces due to
airflow?
It's the same phenomenon. The "friction" occurs because the air is brought
to stagnation in the boundary layer.
Julian Scarfe
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 12:18 PM
Painting and air cooled motor? CitizenX Home Built 5 June 30th 04 12:47 PM
Va and turbulent air penetration speed. Doug Instrument Flight Rules 70 January 11th 04 08:35 PM
Va and turbulent air penetration speed. Doug Owning 69 January 11th 04 08:35 PM
Speed Astir Guy Acheson Soaring 0 December 11th 03 02:24 AM
