what is a fender washer?
Old January 9th 05, 07:59 PM
On Sun, 09 Jan 2005 13:09:44 GMT, "Blueskies"
" jls" wrote in message ...
"Blueskies" wrote in message
. com...
A hardware store washer will be just fine as long as the purpose and use
is understood. This is the homebuilt forum,
right? Nothing illegal about its use at all....
You're right, Mr. Blueskies. I stand corrected. Cad plating on a washer
is unnecessary but it sure helps on the bolt and nut.
Now safety is an entirely different matter....
Most if not all washers I see in the hardware stores are plated, if not Cad then nickel. I don't recall seeing any plain
ones lately...
The VAST majority are bright zinc plated.
Old January 11th 05, 02:10 AM
Blueskies
You guys are probably right - zinc is it; same as galvanized, right?
Old January 11th 05, 06:41 AM
Jim Carriere
Yep, galvanized means zinc coated (by electroplating). A lot of car
body parts are nowadays too, they figured out how to make paint stick
to the zinc coating, look nice, and cost low enough to still turn a
profit.
Plastic fender? Steve Thomas Home Built 0 August 28th 03 04:36 PM
