Balloon-assisted jumping
Old March 23rd 05, 02:38 AM
Carl / KG6YKL
Morgans wrote:
"Montblack" wrote in message
("Vaughn" wrote)
More likely much of it would run down your leg, so the effect on the
flight would depend on if you were wearing shoes or not.
Pee-toe system?
Montblack
Groan. Go to your room!
A heated pee-toe, yet.
I don't know, I'm still laughing...
Old March 23rd 05, 02:57 AM
Stuart Fields
I'm amazed at the number of people with expertise in the aerodynamics of a
body that pees during flight. I wonder if NASA knows of this body of
expertise. I would also like to hear of the experience that supports the
experts knowledge.
Stu Fields
"Carl / KG6YKL" wrote in message
news:_D40e.60692$xt.55172@fed1read07...
("Vaughn" wrote)
Pee-toe system?
Montblack
Old March 23rd 05, 05:23 AM
Dan, U.S. Air Force, retired
("Vaughn" wrote)
Pee-toe system?
Montblack
OK, guys, we just had a string of moldy puns in the "A&P tipping"
thread. Urine deep need of help if you do it in this thread too.
Old March 23rd 05, 06:01 PM
JumpingMan
LCT Paintball wrote:
http://dsc.discovery.com/fansites/my...pisode_07.html
Lawn chair Larry really made his flight though it may not always
be reported accurately--e.g. no helicopter rescue, he came down
on his own by shooting the balloons as planned.
However OP was talking about folks contemplating a sub-flight
balloon-assisted jumping. I think this would be a bit less
spectacular than one might imagine as the balloon will not
rise as fast as the person does when jumping so that the
jump would be only a little higher than normal, followed
by a rapid drop until the slack in the lines is used up,
followed by a a slow drop the rest of the way to the ground
which I think won't be very far.
A very rigid connection between the jumper and the balloon
would have a smoother effect but wind resistance being
much greater and inertia also greater than for the unassisted
jumper I expect that would still be disappointing.
Long jumping will be hampered by wind resistance. However,
downwind long-jumping might be a real gas, stopping would
be the hard part.
Oh, OP said negative net lift. That means the pilot would not
need to jump, he will rise on his own and should give careful
consideration as to how to get back down. Keep in mind also
that on a sunny day the lift may increase as the gas in the bag
heats up. It will also increase if the pilot loses his lunch
or pees in his pants in flight.
FF
Sorry about the net lift mixup. I actually meant the person jumping
would have 3-5 lbs of net weight. So yes, he would be on the ground
but barely. In this case, even the slightest nudge with his toes would
make him airborn...so I don't think there will be much rope slack to
deal with, unless he tries to jump upwards very violently (although my
gut reaction was the same as yours). We would have at least 2
tethers...one to the ground and one to another person. This seems
pretty failsafe to me, barring shoddy tethering, with we would take the
necessary precautions for. Perhaps the jumper could also have a pair
of scissors in his pocket as an emergency solution to an airborn
accident. It seems like this would have appealed to more people...I
know it exists at some amusement parks. Here's the inspiration to my
friend's idea: www.parabounce.com
It clearly works there with no slack problem. You'll notice there are
two kinds of harnesses used. One is mostly rigid, allowing for a more
direct transfer of unward movement, while the other seems to be a more
straightforward setup...like a parachuter's.
The increase in lift due to heat is a good point...our tethers should
have no problem with the additional pull...right?
Does anyone have a cost estimate for this? They would be starting from
stratch.
JumpingMan
Old March 23rd 05, 10:54 PM
JumpingMan wrote:
...I
The video has me convinced. I want to do it too. Where are you?
are
more
more
Yes, no problem. There woudl be at most only a little additional
lift--very easy to pull back down and as the jumper rises more
rope, and therefor more weight will be lifted. You just need to
keep in mind that if airborn with no tether and net negative lift
there will be no way to come down in a controlled fashion without
releasing a little, and only a little gas. That can be done by
adding a couple of smaller balloons that can be released or
deflated.
from
stratch.
Google can get you prices for balloons, helium, skydiver's harnesses,
and rope. Rope is cheap. Helium is pricey. The rest is soemwhere in
between.
FF
Sloggi X69 hot air balloon cotc2001 General Aviation 0 May 7th 04 10:18 AM
the Jumping Jack - Electric ARF Pattern Plane FlitonUSA Aerobatics 0 January 15th 04 07:39 AM
Wind deflectors on balloon? Roy Smith General Aviation 1 September 2nd 03 03:52 AM
During hot air balloon races in Reno/Sparks, avoid Quality Inn Joe Clark General Aviation 0 July 18th 03 11:11 PM
