Flying to KFME (Tipton)
Old March 25th 05, 02:22 AM
John T
"Dan Wegman" wrote in message
k.net
Although I'll file IFR, I've researched the ADIZ
requirements too since I also plan to conduct a local VFR trip to FDK
during my visit.
ADIZ requirements are pretty simple:
1. File a flight plan with AFSS via telephone. Leesburg is most familiar,
but there may be significant delays via phone if the weather is good.
2. Call clearance delivery from the ground (if possible - dunno about FME's
reception from the ground) and get a squawk. DO NOT get airborne without a
discrete beacon code. If airborne wanting to activate your flight plan for
re-entry, be sure to contact ATC while still 3-5 miles outside the ADIZ.
3. Once airborne and departing the pattern, contact approach on the
frequency given by the clearance controller.
4. If your transponder fails in flight, exit the ADIZ via a straight line to
the nearest boundary.
Remember: You're "activating a flight plan" - not getting a clearance. You
do not need to hear "cleared into the ADIZ". Once you have a beacon code
assigned by ATC, you're OK to proceed on course.
Don't squawk 1200 any time you're in the ADIZ.
Don't squawk 1200 within a couple miles of the ADIZ boundary. You know how
radar can paint you in a different location than you really are.
Keep in mind that even after contacting ATC after getting airborne, you're
still VFR. Don't assume you're cleared into Class B airspace, for instance,
just because you're talking to them.
Flying VFR in the ADIZ isn't that big a deal. If you're used to flight
following or IFR flight, then it's likely to be "old hat" to you.
I have video captures of a couple of my ADIZ flights on my site, if you're
interested.
John T
http://tknowlogy.com/TknoFlyer
http://www.pocketgear.com/products_s...veloperid=4415
____________________
Ten Years of Flying Jay Honeck Piloting 20 February 19th 05 02:05 PM
Routine Aviation Career Guy Alcala Military Aviation 0 September 26th 04 12:33 AM
Flying is Life - The Rest is Just Details Michael Piloting 55 February 7th 04 03:17 PM
Wm Buckley on John Kerry Big John Piloting 22 February 7th 04 02:19 AM
Announcing THE book on airshow flying Dudley Henriques Piloting 11 January 9th 04 07:33 PM
