#11
That's because the comment is classic Riley Clueless, Vaughn. Modern 100#
propane tanks are rated for _at least_ 250# _working_ pressure. Each tank must be tested two twice that working pressure and one out of every 500 is tested to four times working pressure. Pressure relief valves for cooking gas tanks are usually set for 375 psi. The compressed air that goes into the tank doesn't get nearly as hot as his overactive imagination says it does. In fact, the outside of the tank is quite cool to the touch at 280 psi. "Vaughn" wrote in message ... "Richard Riley" wrote in message news ![]() Propane tanks are normally rated for 250 LBS. That rating is normally at 120 degrees. 280 PSI air is probably a lot hotter than that. It's been too long since I've done ideal gas law equations, but I seem to remember 250 psi air getting to 300 or 350 F. At a temperature higher than it's rating, a tank is weaker than it's rating. You lost me here. In my experience, 250# air can be any temperature you want it to be. Vaughn |
![]() "Richard Riley" wrote in message news ![]() mercy snip I will be filtering this thread. All of that BS for one, solitary piece of useful information... |
In article , Juan Jimenez says...
"Richard Riley" wrote in message news ![]() mercy snip I will be filtering this thread. All of that BS for one, solitary piece of useful information... Gee Richard that's what we say about ANN ..lots of BS and little info LOL!!! Sorry couldn't help my self.Back to lurk mode Chuck S RAH-15/1 ret |
Sean Trost wrote:
Juan I believe that N1 is related to the velocity of the airstream introduced. Which is good. But not related to the ignition problem Now You have said that you have an excellent spark and good fuel. the only other thing you need for start is the right airflow. or volumn. Dont know about your engine specifically but most everything else runs right around 14 to 1 on the ratio wise. Actually, jets are a different beast from piston engines. Between about 25:1 and 50:1 is normal, even for lightoff fuel flow. Stoichiometrically correct combustion is too hot. |
![]() "ChuckSlusarczyk" wrote in message ... In article , Juan Jimenez says... "Richard Riley" wrote in message news ![]() mercy snip I will be filtering this thread. All of that BS for one, solitary piece of useful information... Gee Richard that's what we say about ANN ..lots of BS and little info LOL!!! Sorry couldn't help my self.Back to lurk mode Monkey see, monkey do. I guess it's true that retards feed from each other. |
![]() "Richard Riley" wrote in message ... All he has to do is google "propane air pressure rating fatigue" and he'll get most of what I gave him in my post. As obnoxious as he is, his kids should grow up with a father. All the results of that search that are relevant to using them as air tanks talk about 20# thin metal LP tanks, you dunce, not about 100# steel tanks. Do us all a favor and go play with your legos or something. Look, there's Chuck in the sandbox! Go play! Shoo! |
I stand corrected. Thanks Jim. Learned somthing new everyday.
Sean Jim Carriere wrote: Sean Trost wrote: Juan I believe that N1 is related to the velocity of the airstream introduced. Which is good. But not related to the ignition problem Now You have said that you have an excellent spark and good fuel. the only other thing you need for start is the right airflow. or volumn. Dont know about your engine specifically but most everything else runs right around 14 to 1 on the ratio wise. Actually, jets are a different beast from piston engines. Between about 25:1 and 50:1 is normal, even for lightoff fuel flow. Stoichiometrically correct combustion is too hot. |
Monkey see, monkey do. I guess it's true that retards feed from each other. Guess your right Hmmm let's see jim zoom campbell and jaun jaminiz (spelled wrong on purpose) :-) See ya Chuck (I designed my own plane ,did you?) S RAH-15/1 ret |
On 15 Jan 2005 09:18:40 -0800, ChuckSlusarczyk
wrote: In article , Juan Jimenez says... Monkey see, monkey do. I guess it's true that retards feed from each other. Guess your right Hmmm let's see jim zoom campbell and jaun jaminiz (spelled wrong on purpose) :-) See ya Chuck (I designed my own plane ,did you?) S RAH-15/1 ret You noticed that, too....?? John |
turbine in microturbine generator for aircraft? | Shin Gou | Home Built | 19 | December 26th 04 02:19 PM |
Alternate turbine fuel | Robert Bates | Home Built | 24 | June 7th 04 07:16 AM |
turbine propeller | sebastian | Home Built | 19 | March 21st 04 12:47 AM |
Pulsar with a turbine? | Badwater Bill | Home Built | 33 | August 28th 03 04:02 PM |
The Sun is hot but the beer is cold in Iowa! | Jay Honeck | Home Built | 13 | July 29th 03 01:14 AM |
