![]() Bob Greenblatt wrote: Aren't we trying to puncture the edge of the cylinder very near its bottom at maximum speed? Got to thinking about your question, Bob and actually we shouldn't try to hit the edge of the cylinder at red-line. Why? Because our sailplanes are very inafficient at red-line, in fact they start coming down like a stone at anything over 90 knots. We should climb the last thermal to 500 over home + a smidgen and then fly the indicated M/C to the edge of the cylinder. You should get there between 60 and 90 knots, depending on conditions on the glide. If you get there at red-line, that means you climbed too high in the last thermal and it cost you (time). The finish line, on the other hand, requires a finish at red-line, so that we can exchange our excess speed for pattern altitude. I'm even tempted to say the cylinder is the most efficient way to fly the final glide, but if I did, OC would just fly off in another snit, and I would be forced to look up all those big words, again............... :) JJ |
Optimum is the same for either finish. Most of us just don't have the
guts to cut it that close with a line finish. With a high cylinder finish, you can cut it close. You're risking points if you end up a bit lower than you hoped. But your margin for momma and the kids is built in to the optimum answer. Its then more a contest of skill than nerve, at least for the final glide. Since most pilots will try to fly efficiently, the range of speeds at the cylinder is reduced, and lowered compared to the gate. Makes for a nice orderly follow the leader to land, with a tad more time after the race is over to sort it out. That can degenerate when everyone finishes way too high and hot or just squeaking in a rolling finish, but it does the same thing with a gate. With a line everyone shoots for the sweet end of the line. There always is one. With a cylinder, finishers will naturally be much more spread out. Maneuvering will be less predictable, but also more uniformly gentle. Given the blind spots in all our gliders, and the tendency to fixate on the targets you see and know about, we really count on the big sky theory more than we like to admit. A little more natural spacing makes the sky bigger. But the cylinder is an instrument approach since it is completely invisible, which has to pull some of your attention into the cockpit. Cutting the edge of the gate is, too, since its really defined by GPS coordinates, not a ground feature. Not very comforting for either finish in traffic. If you think either one is really safe, you're nuts. Both can be executed successfully, but the margins flying that close to so many other gliders and the ground are just not that big. I think the cylinder is a bit less risky, but a lot less fun. A perfect final glide to the edge of the cylinder at 75 kts is so anti-climactic after an epic adventure out on course. Nothing compares to the good old assigned task and no minimum height gate. But I can change... If I have to... I guess. -Dave Leonard ZL wrote: Bob Greenblatt wrote: Aren't we trying to puncture the edge of the cylinder very near its bottom at maximum speed? Got to thinking about your question, Bob and actually we shouldn't try to hit the edge of the cylinder at red-line. Why? Because our sailplanes are very inafficient at red-line, in fact they start coming down like a stone at anything over 90 knots. We should climb the last thermal to 500 over home + a smidgen and then fly the indicated M/C to the edge of the cylinder. You should get there between 60 and 90 knots, depending on conditions on the glide. If you get there at red-line, that means you climbed too high in the last thermal and it cost you (time). The finish line, on the other hand, requires a finish at red-line, so that we can exchange our excess speed for pattern altitude. I'm even tempted to say the cylinder is the most efficient way to fly the final glide, but if I did, OC would just fly off in another snit, and I would be forced to look up all those big words, again............... :) JJ |
