Colibri wrote:
Sean Trost wrote: I stand corrected. Thanks Jim. Learned somthing new everyday. Sean Jim Carriere wrote: Sean Trost wrote: Juan I believe that N1 is related to the velocity of the airstream introduced. Which is good. But not related to the ignition problem Now You have said that you have an excellent spark and good fuel. the only other thing you need for start is the right airflow. or volumn. Dont know about your engine specifically but most everything else runs right around 14 to 1 on the ratio wise. Actually, jets are a different beast from piston engines. Between about 25:1 and 50:1 is normal, even for lightoff fuel flow. Stoichiometrically correct combustion is too hot. 50:1 would be the total airflow:fuel ratio through the engine core. Of those 50 parts air, 15 are primary air that mixes with the fuel for stoichiometrically correct combustion. The other 35 parts are secondary air (not to be confused with a turbofan's bypass air, which doesn't pass through the core). Some secondary air passes around the exterior of the combustion chamber liner to cool it, and some passes through holes into the chamber to shape the flame and hold it away from the liner wall to prevent damage. This is a better explanation than I gave, but I'll elaborate further to this that while technically only 15 of those parts of air are "burned" (use to support combustion), and the secondary air begins mixing with the flame very close to where the fuel nozzle(s) are located. Depending on the design of the engine, some or even all the secondary air flowing around the combustor liner mixes with the primary air/flame before entering the turbine. Complex engines will route some of the secondary air through tiny cooling passages in the turbine blades themselves (I'm pretty sure you, Colibri, understand this, I'm speaking to the group and not trying to insult you), but I strongly doubt this is the case with Juan's engine. None of this is impingement starting air, which hits the turbine blades and then goes right out the exhaust duct. This is an important distinction, so is the difference between secondary and bypass. |
![]() "Jim Carriere" wrote in message ... This is a better explanation than I gave, but I'll elaborate further to this that while technically only 15 of those parts of air are "burned" (use to support combustion), and the secondary air begins mixing with the flame very close to where the fuel nozzle(s) are located. Depending on the design of the engine, some or even all the secondary air flowing around the combustor liner mixes with the primary air/flame before entering the turbine. Complex engines will route some of the secondary air through tiny cooling passages in the turbine blades themselves (I'm pretty sure you, Colibri, understand this, I'm speaking to the group and not trying to insult you), but I strongly doubt this is the case with Juan's engine. You are correct. My engine is not a turbofan, it is a turbojet, circa 1973. None of this is impingement starting air, which hits the turbine blades and then goes right out the exhaust duct. This is an important distinction, so is the difference between secondary and bypass. |
turbine in microturbine generator for aircraft? | Shin Gou | Home Built | 19 | December 26th 04 02:19 PM |
Alternate turbine fuel | Robert Bates | Home Built | 24 | June 7th 04 07:16 AM |
turbine propeller | sebastian | Home Built | 19 | March 21st 04 12:47 AM |
Pulsar with a turbine? | Badwater Bill | Home Built | 33 | August 28th 03 04:02 PM |
The Sun is hot but the beer is cold in Iowa! | Jay Honeck | Home Built | 13 | July 29th 03 01:14 AM |
