Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Vibration Monitor (Hyde, Wanttaja?)
Old March 28th 05, 09:04 PM
Frank van der Hulst
Pete Schaefer wrote:
Frank:
I do have quite a clue about EMI, and clearly have a better clue than you
about systems engineering in general. Here's a question for you:
Why bother?
For the same reason that we build planes instead of buying them.
If you're trying to cert bluetooth for aviation, maybe with the thought of
selling some other bluetooth product that you think you can make a big chunk
of cash with, then, yeah, maybe going off to play with bluetooth on your
airplane makes sense. Personally, I can't see it. Maybe it makes sense for
using it to reprogram boxes on your airplane, but to go to the extent of
making it useful/safe in flight....nah. Way too much effort for too little
return, given that the inclusion of an RS-232 port is so freakin' easy.
I agree totally. except maybe about RS-232. I suggest that some sort of
current-based rather than voltage-based signalling would be more
noise-immune. Bring back 20mA current loop! :-)
If you have some other goal in mind, maybe some other sensing or data fusion
tech (e.g. may you have a huge array of air data sensors for some advance
stall detection method), then you have to look at whether or not the tech
risk buys you something that you can't get otherwise. Why bluetooth rather
than the 1/2 dozen other wired data communication protocols (e.g. 1392, .
422, 232, 485, CAN, etc.) that are out there?
The TWO key ideas in the proposition (wasn't mine, BTW) were wireless
comms and self-powered. If you can do BOTH of those, then wired comms
and power is best. Wireless comms has been pretty much solved. For
example, I saw a projection in an engineering mag that within 25 years
wireless will replace wired as the cheapest comms technology to the home.
But without "self-powered" it is pointless. Are there any devices out
there that can turn (e.g.) vibration into *useful* amounts of electricity?
I get rather frustrated with people who get really !@#$ing enamored with
technologies for implementation and loose sight of what their goals are.
Hmmm... so what are *my* goals? Maybe I want the geekiest plane on the
block? I suggest that one or other of your 4 beers has introduced some
patronisation (as well as abrasiveness) into your system.
All
too often, risk variables get introduced where none is warranted, resulting
in zero or negative value added.
I'll choose what risks are warranted on *my* project, thanks.
I beat on my guys daily about issues like
this. (Kelly Johnson (...yeah, I work at that place.....) had a lot to say
about where it was acceptable to take project risks..too bad so much of it
never got captured in "the rules").
This is fine where *you* get to set the goals.
So, back to Blue Tooth....
Why bother?
*With* self-powered devices, it gives options not available via wired
systems.
For data collection, I've already got a half-dozen options in my hip pocket
that I know will work just fine with very well understood EMI issues that I
know how to mitigate. What's my goal? Blue tooth airplane or getting the
data for some other purpose?
I have very little room for Geek Factor on any airplane that I'll ever
build. If it can't buy it's way on (I'd lump Blue Tooth in here), then !@#$
it.
Pete
P.S. I just got done with a 5 hour drive and am tired as all !@#$. I've got
4 beers in me to diffuse stress. Please forgive my abbrasiveness. I'm not
really that bad of a guy. I just don't want people to pursue ideas that
will get them killed.
Hey, I prefer to talk straight too. And also don't want people to kill
themselves. But if people don't experiment with Experimental category
aircraft, then nothing is going to change.
Frank
Old March 28th 05, 09:19 PM
nafod40
systems.
Couple of sources. This is a hot research area.
http://www.sandia.gov/media/NewsRel/...eredsensor.htm
http://www.perpetuum.co.uk/
Old April 2nd 05, 12:47 AM
Ernest Christley
Why bother?
systems.
Even if you have to run 12V to it, in a metal airplane that will only be
one wire and one connection. Assuming they can build a wireless device
that can stand up to typical airplane abuse for a while*, this would
make for a much simpler and safer installation. At these power levels,
the EMI issue is a red herring that would be easily defeated with a
$0.98 roll of aluminum foil, and once defeated on the ground the
problem isn't likely to pop back up in flight (like loose cabling will).
IMHO
*It seems that your standard store bought router is designed to die
after a few years. I wouldn't trust this quality control with my
comfort. I barely trust it with my ability to read this newsgroup.
This is by far the hardest lesson about freedom. It goes against
instinct, and morality, to just sit back and watch people make
mistakes. We want to help them, which means control them and their
decisions, but in doing so we actually hurt them (and ourselves)."
Old April 2nd 05, 04:09 AM
Pete Schaefer
So, what things on the airplane are you guys going to replace with
self-powered blue tooth devices?
"Ernest Christley" wrote in message
om...
IMHO
Old April 2nd 05, 05:38 AM
Frank van der Hulst
First thing would be Bluetooth headsets... no more cords tangling round
the cockpit.
Next would be various engine instruments... EGT, CHT, etc.
Maybe move the entire radio receiver out to a wingtip or somewhere well
away from the engine's RF noise. But I can't see that being
self-powered. Perhaps we could use Tesla's beam-power technology to run
those.
Frank
Old April 2nd 05, 07:12 AM
Ernest Christley
the cockpit.
That's a good one. Keep an old pair if wired sets stuck in an
accessible hole someplace...just in case.
Perfect. If the signal dies, the plane won't know it. The Cherokee I
trained in didn't even have a working EGT.
those.
Frank
Oooh. You just lost me on that one. To much complication with the radio
to human interface there. You've got a device in front of the pilot to
select a station, which must transmit it to a device out on the wing,
which has to recieve and interpret it correctly, then transmit the
correct station's signal back over bluetooth. You'd still have to run
signal wires for the physical backup. I just don't see the advantage
when remoting the antennae is all that's necessary to avoid the engine EMI.
How about stress monitors built into the prop (I have no idea if anyone
makes such a thing). Would help you to carve a perfect prop.
Miniature temp probes and air pressure sensors that you can stick all
over the place. Would make it real easy to map out the pressure regions
on the airplane and design a better cooling system or decide if wing
modification would be necessary/beneficial.
Vibration sensors stuck inside control surfaces and different parts of
the skin. Early warning system for flutter. Might only give you time
for a short prayer, but it may save your butt if you can react quick enough.
Nothing is stopping anyone from doing any of this with wired sensors.
It would just be cleaner and easier if the wire can be left on the spool.
Old April 2nd 05, 07:53 AM
Frank van der Hulst
well away from the engine's RF noise. But I can't see that being
run those.
This kind of stuff is bread-and-butter for Bluetooth. Remember that one
of its original design goals was moving (high-quality stereo) audio in
real time from a player to headphones. Sending channel-select signals in
the opposite direction isn't a biggy either... Bluetooth devices are
continually communicating digitally amongst themselves.
You'd still have to run signal wires for the physical backup.
Why? The airplane will keep flying if the radio fails. Granted that,
depending where you live and fly, losing access to your radio could be a
bit, um, difficult. But, for many, a radio isn't a necessity.
You said it yourself in your last sentence: It would just be cleaner and
Prop blade pitch control... a motor in the spinner to adjust pitch,
controlled via Bluetooth. No hollow crankshafts and oil pressure
systems, no slip-rings.
Frank
Old April 2nd 05, 08:17 AM
Scott Skylane
/snip/
Frank
Eh? How would the motor be powered, batteries? I'm not sure how long
reasonably sized batteries would work. And what about centrifugal force
issues?...
Happy Flying!
Scott Skylane
Old April 2nd 05, 08:51 AM
Pete Schaefer
om...
How much would someone pay for the software to analyze this data? Also,
you'd probably need structurally integrated sensors, which would have to be
strong enough to support the loads. This would be a pretty tough engineering
problem in itself.
over the place.
More software. Sure it could be done, but cheaply enough for the average
home builder?
Might be really expensive to get the signals characterized well enough for a
warning system.
There's a ton of stuff stopping people from doing this right now. It's
money. None of the stuff you've mentioned is even remotely innexpensive. I
know people who've researched this stuff with the wired sensors for several
years, and haven't gotten much of it out of the lab. Yeah, with steady
improvements in computational fluids, finite element, mems tech, sensing
tech, etc., this stuff will be eventually packaged into something us
home-builder types can afford to use. However, most of it is still too
damned expensive, manpower intensive, and technically immature for even the
military to employ on huge aircraft development programs like JSF. By the
time this stuff really becomes generally available, I'm sure there will be
something better than blue tooth around.
Old April 4th 05, 04:47 AM
Ernest Christley
om...
problem in itself.
??? analyze ???
What analysis would you want to do other than to look a the relative
strains at a few distinct points. You'd like a bell shaped lift curve
on the prop, same as for a wing. I would pay $0 dollars for software
analysis, and opt for plotting the values on a sheet of graph paper with
a pencil. Well, that's not EXACTLY true. I'd probably use Gnumeric
(open source spreadsheet), as it would produce a much prettier graph
that I would.
Mind you, I'm talking a home carved wood prop here. Build in a little
pocket for the probe. Keep carving until one gives you the perfect profile.
over the place.
home builder?
Why the software again. Danm, man, what do you think people did before
Intel came along with their little 4-bit wonder. You're engine isn't
cooling like you want it to. The way to see what you need to fix is to
map out pressures in and around the radiator system (I'm building a
water cooled auto-conversion. Please be patient with the radiator
thing.) The current way is to run water lines all over the place, duct
taping them to the side of the plane to get them back to the cockpit so
that you can measure all the relative water columns. No fancy analysis
is needed. Either you have a few inches of pressure across the radiator
cores, or you don't. Move the sensors around to find out where the high
pressure areas are.
warning system.
Do you have a squelch knob on your radio? Do you have to run incoming
signals through a laborious data analysis before you decide where to set
said squelch? No! You just turn it up till the background noise stops.
Same here. If you hit flutter, the intensity will increase
dramatically, just like the occasionaly noise gets through the squelch.
As I said in my original post, it will probably give you just enough
time to kiss your butt goodbye, but flutter isn't always noticed for
what it really is and it does't always catastrophically destroy the
airplane. Sometimes it beats the airplane to death slowly. If the
'flutter squelch' from the t-tail always goes off as you hit 140kts and
dies back down as you pass through 150kts, it might be a clue that you
should rebalance the t-tail or avoid 145kts as a minimum.
I say those people are asking for too much. If you want the computer to
tell you exactly what's wrong, I'll agree with you all day long that
it's not economically possible with todays technology. If all you want
is a little information about what's going on around you (with the human
doing the divining), the cost is well under $500 (for wired sensors,
don't know about BlueTooth).
Vibration Monitor (Hyde, Wanttaja?) RST Engineering Home Built 71 April 4th 05 04:44 PM
Pinging Ron Wanttaja - "Unporting?" Bob Chilcoat Home Built 13 November 24th 04 07:28 PM
Vibration Testing Jim Weir Home Built 20 October 10th 04 07:22 AM
Vibration Testing Jim Weir Owning 21 October 10th 04 07:22 AM
Survey - 3 blade prop conversion- Cockpit vibration, happy or not Fly Owning 20 June 30th 04 05:32 PM
