Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Vibration Monitor (Hyde, Wanttaja?)
Old April 2nd 05, 08:39 AM
Pete Schaefer
"Frank van der Hulst" wrote in message
First thing would be Bluetooth headsets... no more cords tangling round
the cockpit.
That would be pretty nice. But now you need batteries in your headset to
power the audio amp.
Next would be various engine instruments... EGT, CHT, etc.
I guess you'd need some devices (i.e. wires) for routing the signal through
the firewall or around it. How much lighter would this be than, say, a
twisted pair for CAN?
Maybe move the entire radio receiver out to a wingtip or somewhere well
away from the engine's RF noise.
But I can't see that being self-powered.
The receiver could be, but not the transmitter. An antenna wire is probably
a lot lighter than running power out, so I guess that would need to stay in
the cockpit.
Old April 2nd 05, 10:16 AM
Frank van der Hulst
the cockpit.
Yeah. I wonder whether head movement would produce enough power... like
the 'self-winding' watches of the 1970s.
Not necessarily... I guess you're talking about a metal firewall
shielding the signals, right? But, assuming a fibreglass cowl, mount a
self-powered repeater someplace where the engine instruments can see it,
and where the instrument panel can see it (e.g. a bump on top of the
cowl, on a wingtip, on the leading edge, on the landing gear perhaps).
An extra benefit is that you no longer need (as many) penetrations
through the firewall.
the cockpit.
Well, I did suggest (kinda tongue-in-cheek) using RF to power the radio
transmitter, as Nicola Tesla proposed way back in the (IIRC) 1930s.
Yeah, I know that none of these things is quite right, right now.
There's lots of engineering to be done to make it workable. But I think
we *probably* have enough technology to be able to begin implementing
this kind of stuff.
Frank
Old April 2nd 05, 06:32 PM
Pete Schaefer
Probably not, but you don't need a lot. I guess it depends on how long you
need it to operate. Using modern digital amp chips (which are amazingly
efficient), you can keep consumption down. A couple of gumstick batteries
might be alright.
That kinda goes against my "as few possible components between the source
and the destination" philosophy. I think you'd have to just locate the
receiver on the firewall and put an antenna through.
If you don't keep working through the possibilities, you might miss an
opportunity to invent that new gadget that everybody just has to have.
Personally, I'm not hopeful that there's a big opportunity for blue tooth on
home-built airplanes, but there might be a couple of really good
applications.
Pete
Old April 2nd 05, 06:13 PM
Gord Beaman
Frank van der Hulst wrote:
snippo
the cockpit.
Not to change the subject but where did they come up with
'Bluetooth anyway?... (just lucky maybe?)
-Gord.
(use gordon in email)
Old April 3rd 05, 06:47 PM
nafod40
So, what things on the airplane are you guys going to replace with
self-powered blue tooth devices?
I'm typing out loud here...
When I suggested bluetooth the other day, what I had in mind was a kit
that you would temporarily hang on an airplane for specific tests, much
like we hang all the orange on Navy aircraft for flight tests. Much more
accurate pitot-static, vib sensors, postion sensors, data loggers, etc.
You could, for example, have a kit for flight testing an RV-8. Pop it
on, do the tests, and remove it. Or it could be used for "external
stores" such as a camera.
Afterward, I contemplated replacing all signal wires with wireless. So
any wire not carrying power could be replaced. This might be especially
useful for a refit, where access is far more difficult than during
initial construction.
Other harebrained ideas...two planes in semi-close formation could
network via bluetooth. Why? Could be low prob. of intercept comms on a
private channel, sharing of nav data, text messaging, ipod music files.
There's an ongoing thread on rec.aviation.soaring on bluetooth and
cellphones aboard planes.
Old April 3rd 05, 11:40 PM
William W. Plummer
Bluetooth: a solution in search of a problem
Old April 4th 05, 02:37 PM
nafod40
So was the internet for a while.
I'm thinking of just wireless in general, of which bluetooth is an
implementation (with a really catchy name.)
Old April 4th 05, 02:43 PM
William W. Plummer
Not at all. TCP, the original name for "TCP/IP" that we know today,
was designed to meet certain military needs but the bigger issue of how
to communicate through widely-disparate networks was _THE_ problem.
You can look up the IEEE Trans. on Communications paper by Kahn and
Cerf. 1974 as I recall.
Vibration Monitor (Hyde, Wanttaja?) RST Engineering Home Built 71 April 4th 05 04:44 PM
Pinging Ron Wanttaja - "Unporting?" Bob Chilcoat Home Built 13 November 24th 04 07:28 PM
Vibration Testing Jim Weir Home Built 20 October 10th 04 07:22 AM
Vibration Testing Jim Weir Owning 21 October 10th 04 07:22 AM
Survey - 3 blade prop conversion- Cockpit vibration, happy or not Fly Owning 20 June 30th 04 05:32 PM
