making turns for 15 knots
Old March 29th 05, 03:58 AM
vincent p. norris
The secret squirrel part is how do you find out the blade rate to
knots correlation of everyone else's submarines.
Well, ATC can give a pilot a groundspeed readout based on tracking his
progress on the radar screen. Can't something of that sort be done
with subs?
Or could the Doppler effect be used for that purpose?
vince norris
Old March 29th 05, 05:20 AM
Jim Carriere
with subs?
As in time-distance using two or more fixes, yes. I think the old
fashioned way was with a piece of paper, but it is nothing for a
primitive (by today's standards) computer to do it for you with two
or several fixes.
Also yes, but of course if the target is not heading directly (or
near directly) towards or away from your receiver, then doppler shift
will be less pronounced. You can sanity check the "big picture"
using, among other things, doppler, fixes, and common sense.
Last, a lot of the time you only have some of the above information,
the fixes may have questionable accuracy, so then you get an
approximate solution.
Old March 29th 05, 07:11 PM
Diamond Jim
Today ou can hear another ship (prop) a hell of a lot farther away than you
can get an accurate fix on it. Although in WWII the equipment wasn't that
developed, it was probably true then also.
Diamond Jim
Old March 29th 05, 09:09 PM
Ended up in Colorado because of company move so didn't cost us a dime.
House now paid off; good place to live except dry; Rockies 30 miles
away. Wx is pretty good about 90 percent of the time (about 330 days
it's good enough for VFR flight!). Plus a lot of inertia. We do get
down to Corpus Christi/Port Aransas every year).
Walt BJ
Old March 30th 05, 01:56 AM
Tex Houston
Walt BJ
Agreed that Colorado is a good place to live (and my weather is better than
Walt's).
Tex Houston
Old March 31st 05, 05:48 AM
Peter Stickney
Jim Carriere writes:
with subs?
or several fixes.
An interesting thing about all that Target Motion Analysis jazz is
that in some ways, the old analog "Iron Idiots" were better at it than
the modern digital numerical computers. You'd crank in the inital
observed estimates, and see if the Fire Control System's generated
solution matched the target. If it didn't, you'd fudge this & that
(Target bearing & speed, for example, or range if the speed was known)
until it was tracking smoothly.
Pete Stickney
Without data, all you have are opinions
21st Century E-Business Money Making Formula NeoTycoon Owning 0 January 18th 05 08:28 PM
21st Century E-Commerce Money Making Formula NeoOne Piloting 0 January 4th 05 12:57 AM
millionaire on the Internet... in weeks! Malcolm Austin Soaring 0 November 5th 04 11:14 PM
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 12:18 PM
Can F-15s making 9G turns with payload? Paul J. Adam Military Aviation 114 September 27th 03 05:47 AM
