just checking
JRC has a pretty good track record, but one or two bad experiences can be disappointing. YMMV, Frank "BTIZ" wrote in message news:h3O1e.565$ZV5.57@fed1read05... ok... I think we all knew that... but from what I read... ICOM is not JRC... just cause ICOM is "made in Japan".. that does not make it JRC... I did not see any affiliation to JRC in the article... so.. whats your point? BT "F.L. Whiteley" wrote in message ... please read the following http://www.icomamerica.com/downloads/cq-interview.pdf "BTIZ" wrote in message news:ViL1e.543$ZV5.432@fed1read05... Hint,... it's not the antenna... it's the radio... JRC = Japan Radio Corp... Get an ICOM BT wrote in message ups.com... All, I have been using a JRC JHP-500 handheld radio for field communications and have been a bit disappointed with it's performance. It has a standard 6" flex antenna. When I am in the air and someone tries to talk with me using the handheld, the transmission always sounds very weak, even if I am flying right over the top of them at the airport. For all I know, the radio is fine and the real culprit may simply be the antenna. Any suggestions? Any suggestions on other (stock) handheld transceivers that have worked well for others that won't break the bank? |
Boosting ICOM IC-A23 Handheld Aviation Radio | CHANGE USERNAME TO westes | Instrument Flight Rules | 23 | June 9th 04 12:41 PM |
STS Handheld Radio Repair - USA | Ray Lovinggood | Soaring | 3 | April 25th 04 01:33 PM |
Vertex VXA-150 Pro V handheld radio question | Alan Meyer | Soaring | 2 | April 24th 04 01:42 PM |
Ext antenna connection for handheld radio | Ray Andraka | Owning | 7 | March 5th 04 01:10 PM |
Ham Radio In The Airplane | Cy Galley | Owning | 23 | July 8th 03 03:30 AM |
