vincent p. norris wrote:
The secret squirrel part is how do you find out the blade rate to knots correlation of everyone else's submarines. Well, ATC can give a pilot a groundspeed readout based on tracking his progress on the radar screen. Can't something of that sort be done with subs? As in time-distance using two or more fixes, yes. I think the old fashioned way was with a piece of paper, but it is nothing for a primitive (by today's standards) computer to do it for you with two or several fixes. Or could the Doppler effect be used for that purpose? Also yes, but of course if the target is not heading directly (or near directly) towards or away from your receiver, then doppler shift will be less pronounced. You can sanity check the "big picture" using, among other things, doppler, fixes, and common sense. Last, a lot of the time you only have some of the above information, the fixes may have questionable accuracy, so then you get an approximate solution. |
Today ou can hear another ship (prop) a hell of a lot farther away than you
can get an accurate fix on it. Although in WWII the equipment wasn't that developed, it was probably true then also. Diamond Jim |
Ended up in Colorado because of company move so didn't cost us a dime.
House now paid off; good place to live except dry; Rockies 30 miles away. Wx is pretty good about 90 percent of the time (about 330 days it's good enough for VFR flight!). Plus a lot of inertia. We do get down to Corpus Christi/Port Aransas every year). Walt BJ |
![]() wrote in message oups.com... Ended up in Colorado because of company move so didn't cost us a dime. House now paid off; good place to live except dry; Rockies 30 miles away. Wx is pretty good about 90 percent of the time (about 330 days it's good enough for VFR flight!). Plus a lot of inertia. We do get down to Corpus Christi/Port Aransas every year). Walt BJ Agreed that Colorado is a good place to live (and my weather is better than Walt's). Tex Houston |
Jim Carriere writes: vincent p. norris wrote: The secret squirrel part is how do you find out the blade rate to knots correlation of everyone else's submarines. Well, ATC can give a pilot a groundspeed readout based on tracking his progress on the radar screen. Can't something of that sort be done with subs? As in time-distance using two or more fixes, yes. I think the old fashioned way was with a piece of paper, but it is nothing for a primitive (by today's standards) computer to do it for you with two or several fixes. An interesting thing about all that Target Motion Analysis jazz is that in some ways, the old analog "Iron Idiots" were better at it than the modern digital numerical computers. You'd crank in the inital observed estimates, and see if the Fire Control System's generated solution matched the target. If it didn't, you'd fudge this & that (Target bearing & speed, for example, or range if the speed was known) until it was tracking smoothly. -- Pete Stickney Without data, all you have are opinions |
21st Century E-Business Money Making Formula | NeoTycoon | Owning | 0 | January 18th 05 08:28 PM |
21st Century E-Commerce Money Making Formula | NeoOne | Piloting | 0 | January 4th 05 12:57 AM |
millionaire on the Internet... in weeks! | Malcolm Austin | Soaring | 0 | November 5th 04 11:14 PM |
Landing and T/O distances (Was Cold War ALternate Basing) | Guy Alcala | Military Aviation | 3 | August 13th 04 12:18 PM |
Can F-15s making 9G turns with payload? | Paul J. Adam | Military Aviation | 114 | September 27th 03 05:47 AM |
