("Mike Rapoport" wrote)
snip The Helio is like an onion in that there are layers of performance which make it rewarding to fly. Each time you master one layer, you find another. It is easy to get better performance than is even possible with other planes like C182 or C185 but that is very different than being able to use all the capability that is built into the airplane. If you'd like to talk some more about your plane... :-) What missions are you looking forward to with your Helio Courier? Missions that might be out of reach for a C182 or C185? Are most of the Helio's advantages over the 182/185 STOL, or is there more? What's your breakdown of the plane's attributes? Thanks. Montblack |
![]() "Montblack" wrote in message ... ("Mike Rapoport" wrote) snip The Helio is like an onion in that there are layers of performance which make it rewarding to fly. Each time you master one layer, you find another. It is easy to get better performance than is even possible with other planes like C182 or C185 but that is very different than being able to use all the capability that is built into the airplane. If you'd like to talk some more about your plane... :-) What missions are you looking forward to with your Helio Courier? Missions that might be out of reach for a C182 or C185? I am going to be flying into more of the backcountry strips here in ID. I went to a few of the easier ones last fall to go fishing but the practical season ended just as I was getting competent.. I would also like to go to Alaska on an extended trip. The advantages that I think the Helio has over the competition are that it will fly much slower while retaining very positive control (it has spoilers in addition to ailerons) and it doesn't stall so you can fly closer to the limits. At the other end of the spectum, it will cruise about 140kts which is a reasonable speed for getting places. Are most of the Helio's advantages over the 182/185 STOL, or is there more? What's your breakdown of the plane's attributes? Thanks. Everything on a Helio is designed for STOL. Low wing loading, fowler flaps, slats, spoilers, very forward gear location, reasonably powerful ect. All of this complexity was probably very expensive to build and that probably led to the company's demise but it makes for a great special purpose machine. The only negative is that it bounces around a lot in even minor turbulence because of the low wing loading. The ultimate STOL machine (excluding harriers and gyroplanes) is a Helio with an Allison turbine. I met a guy that just bought back the only one in existance (he also did the conversion) and he claims that it will get airborn in 80' and climb over 3000fpm. Mike Helio Courier H295 |
RIP Mike Valentine | Mal | Soaring | 0 | December 11th 04 08:27 PM |
Rogue's Gallery Update - Mike R's Helio & Mike G's Saratoga | Jay Honeck | Home Built | 1 | December 3rd 04 09:16 PM |
Rogue's Gallery Update - Mike R's Helio & Mike G's Saratoga | Jay Honeck | Piloting | 1 | December 3rd 04 09:16 PM |
Rogue's Gallery Update - Mike R's Helio & Mike G's Saratoga | Jay Honeck | Owning | 0 | December 3rd 04 08:25 PM |
PA28-181 - Stuck Mike - King Silver Crown | Roy Page | Owning | 2 | October 29th 04 03:36 AM |
