I had the same AH in my motor glider (but running on 12 volts, not 14)
and removed it after a few years and one very expensive overhaul. It was just too unreliable. Never subject to mishandling, just highly unreliable in my experience. Other pilots I've talked with have had similar experiences. And there don't seem to be any "low cost" (under $5k) electric AH's that are much better. I now use the simulated AH on my Garmin 196 and am considering the new, solid state varieties. Hopefully Bumper (aka Johnny the Morgan) will comment on this as he has one and I think likes it a lot. I don't fly clouds and want an AH purely for safety in the unlikely event I get trapped above clouds that close in under me. Hasn't happened yet (knock on wood), but I think about it. Martin |
![]() wrote in message oups.com... I had the same AH in my motor glider (but running on 12 volts, not 14) and removed it after a few years and one very expensive overhaul. It was just too unreliable. I've also heard the electric artificial horizons (AH) or attitude indicators (AI) have not been so reliable. Also, most are relatively expensive and large 80mm (3.125") and so take up a lot of panel space. The smaller 2.25" inch gyro instruments, as used in jet aircraft, have been very pricey. Recently there have been some better options. PC Flight Systems has PDA based AI and the smaller, stand alone E-gyro. Though the E-gyro is sold as an AI, though functionally it is really more of a needle and ball (without the ball), providing mostly roll info with a relatively insensitive pitch display. Practically, this is just fine for gliders, 'cause if you can keep the wings level, pitch is controlled by airspeed, control-feel, sound . . . or whatever you have handy that isn't iced up and still works! The Garmin 196 that Marty and I both use, provides a GPS derived and very usable panel display. When flown by an experienced instrument pilot, the 196 can get you safely out of the soup "partial panel". In the lower left corner of the 196 display is a depiction of what looks like a turn coordinator. However, if functions to display turn info only. I'm currently using a TruTrack and am very happy with it. It reacts a bit faster than the 196 panel (which has about a 1 second delay) and many pilots will find the TruTrack display more intuitive and easier to fly as its blue horizon remains pretty much in line with the real one. Again, no pitch info on this instrument, but it seems ideally suited for gliders, being light, 57 mm, draws 150 ma (install a toggle switch), goes from power-off to usable display in 3 seconds (even in a steep bank), and costs about $450 USD. all the best, bumper |
What about
http://www.stratomaster.uk.com/php/s...=details&id=70 Full horizon functions, choice of display size and low power consumption. Anyone tried one? "bumper" wrote in message ... wrote in message oups.com... I had the same AH in my motor glider (but running on 12 volts, not 14) and removed it after a few years and one very expensive overhaul. It was just too unreliable. I've also heard the electric artificial horizons (AH) or attitude indicators (AI) have not been so reliable. Also, most are relatively expensive and large 80mm (3.125") and so take up a lot of panel space. The smaller 2.25" inch gyro instruments, as used in jet aircraft, have been very pricey. Recently there have been some better options. PC Flight Systems has PDA based AI and the smaller, stand alone E-gyro. Though the E-gyro is sold as an AI, though functionally it is really more of a needle and ball (without the ball), providing mostly roll info with a relatively insensitive pitch display. Practically, this is just fine for gliders, 'cause if you can keep the wings level, pitch is controlled by airspeed, control-feel, sound . . . or whatever you have handy that isn't iced up and still works! The Garmin 196 that Marty and I both use, provides a GPS derived and very usable panel display. When flown by an experienced instrument pilot, the 196 can get you safely out of the soup "partial panel". In the lower left corner of the 196 display is a depiction of what looks like a turn coordinator. However, if functions to display turn info only. I'm currently using a TruTrack and am very happy with it. It reacts a bit faster than the 196 panel (which has about a 1 second delay) and many pilots will find the TruTrack display more intuitive and easier to fly as its blue horizon remains pretty much in line with the real one. Again, no pitch info on this instrument, but it seems ideally suited for gliders, being light, 57 mm, draws 150 ma (install a toggle switch), goes from power-off to usable display in 3 seconds (even in a steep bank), and costs about $450 USD. all the best, bumper |
Just a correction to the name, it's TruTrak and the URL for the page
(if I have it right) is http://www.trutrakflightsystems.com/...struments.html I found this out by googling on "TruTrack artifical horizon" and Google was kind enough to ask me if I meant TruTrak. I also had trouble with the URL on the next msg, involving stratomaster.uk. My browser came back with "cannot find the site" type message. Martin |
Hello all,
I made a small research on the subject some time ago. My purpose was to protect myself in wave flying. What I found was the installation of a traditionnal turn and bank or an artificial horizon became to pricy and could only be fitted with great difficulty on the panel of my PIK. What I found were two alternatives: one good, one excellent. Both were Palm PDA based. One was a E-Gyro which is nothing else than a certifiable "solid state" gyro that can be easally installed in the back shelf of your glider and have the display on your PDA. These instruments are the best. The E-gyro requires about a minute to align before departure. The other solution much more cost effective is as stated on this thread, is an AI based on GPS info. I would not recommand it for thermalling in cloud as the response rate is quite slow as in the first flight simulators for PC's. What it is, however, is a good wing leveller that will get one back in VMC when one has goofed up. Do have your airspace cleared up first! Fly safe Marc PIK-20B "74" |
drug/alcohol testing policy: effective? | gatt | Piloting | 159 | January 28th 05 06:19 AM |
New artificial horizon - Sigmatek or R.C. Allen? | David Herman | Owning | 7 | November 13th 04 01:38 PM |
Testing Stick Ribs | Bob Hoover | Home Built | 3 | October 3rd 04 02:30 AM |
Torsional Vibration Testing | B2431 | Home Built | 8 | July 25th 03 07:15 AM |
