Check he
http://showcase.netins.net/web/herke...n/escapac.html www.ejectionsite.com/escapacfr.htm In the S-3 community (I was a "backseater") we were always trained that ejection is the best option. In the portion of NATOPS that discusses ditching at sea, the recommendation from Lockheed was "Don't". As for the choice between ejecting and piling into a plowed field somewhere, I wouldn't relish the thought of sliding a 43,000 lb. aircraft across soft dirt/grass/etc. at speeds in excess of 110 mph, which would be the absolute minimum that you could touch down at. Now - that changes just a little bit if you're talking about a contolled, deadstick, flat, level approach to a 14,000 ft runway that's been foamed. But with an ejection seat that works, I'd rather take my chances on a controlled ejection. On a final note, VRC-50 landed a C-1A on the runway at Da Nang - gear up (intentionally). The aircraft eventually was flown to NARF in Atsugi a few weeks later after 2 engine changes and some minor "body work" on the belly. Oh yea - and they repaired the shrink-link strut that failed on the main gear during the original flight. It broke just as the gear was retracted into the wheel well, and the Main mount extended inside the wheel well, resulting in "2 down and locked". Regards, On Thu, 31 Mar 2005 09:41:14 +1200, "Cockpit Colin" wrote: I've read about the experiences of a few pilots who have had to eject - by all accounts it's an extremely violent process which none would care to repeat. Obviously it's done as a last alternative when the potential benefits out weigh the considerable risks. In the GA world it's not an option that we have - so in the event of, say, an engine failure, our only option is to go for a forced landing - which in my case is almost certainly going to mean a flat farmers paddock. I'd be curious to know how many "military fast jet" pilots would, in the event of a total engine failure contemplate/attempt a forced landing into the likes of a farmers paddock versus ejection? My thinking is that on one hand a GA plane is relatively flimsily built but capable of landing at a much lower speed - on the other hand a "military fast jet" is built to withstand many g's (so very strong construction) - and the pilot is secured to the aircraft with a very effective harness - with his head protected by a helmet (all advantages over a GA pilot) - but of course committed to landing at a higher speed. In the above scenario would a forced landing ever be an option - or would first choice always be ejection? Thanks for your thoughts. CC |
RAH'er has forced landing | Ron Wanttaja | Home Built | 33 | December 24th 04 12:58 PM |
VW-1 C-121J landing with unlocked nose wheel | Mel Davidow LT USNR Ret | Military Aviation | 1 | January 19th 04 05:22 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Off topic - Landing of a B-17 | Ghost | Home Built | 2 | October 28th 03 04:35 PM |
British pilot (in Britain), survives forced mountain landing | Tim K | Piloting | 3 | July 11th 03 04:14 PM |
