Alternate airports
Old March 31st 05, 06:48 PM
Ross Richardson
Peter Duniho wrote:
"Andrew Sarangan" wrote in message
. 61...
If the destination does not have an instrument approach you must pick an
alternate.
If the destination has an instrument approach, then you don't need an
alternate unless the the weather is worse than 2000' ceiling or 3SM vis
+/1hr of the ETA. (ie if the forecast is worse than VFR then you need an
alternate).
The above is not "the process for choosing an alternate". It's the process
for deciding whether you NEED an alternate.
You can't pick any airports as an alternate. Only a few airports qualify
as an alternate.
Wrong. Any airport qualifies, as long as the forecast is for VFR conditions
from the descent from MEA all the way to the ground. Beyond that, lots of
airports have instrument approaches and thus qualify as an alternate under
lower forecast conditions. Even in IFR conditions, it's far from true that
"only a few airports qualify as an alternate".
Pete
We have a local airport (KGYI) with an ILS and it does apply as an
alternate. At the time it didn't have weather reporting, but now has a AWOS
Regards,
Ross
________________________________________
972.952.3170 Phone 972.949.9249 Pager
972.952.2574 FAX
McKinney / Wing A2 North @ 48v72
Airports Rated Critical Unsatisfactory: Given Black Star Rating Michael Ravnitzky Piloting 0 February 3rd 05 03:34 AM
"I want to thank Mayor Daley for tearing down his airport." Larry Dighera Piloting 13 January 24th 05 04:00 AM
Time to revamp traffic patterns at non-towered airports? Ace Pilot Piloting 47 February 11th 04 03:16 PM
Alternate requirements Anthony Chambers Instrument Flight Rules 8 September 17th 03 09:45 PM
fatal bird strike StellaStar Piloting 9 July 13th 03 09:41 PM
