Heh heh...
I once had a car where the rev-limit function was built-in to the fuel pump relay and it had a design quirk. Once the RPM limit was exceeded, the fuel would be cut off but only after a short time delay. So the effective limit was 6100 plus however many RPM you could get in about 1/2 second! Eric Law "Eduardo K." wrote in message ... In article , EL wrote: In addition to the points made by others, let me throw this out: Suppose the prop strike occurs when the engine is set to high power (maybe not the most likely scenario but quite possible). The prop makes contact with something and the pin shears. At that very instant, the engine is set to high power but now has no load on it. With no load, the engine will speed up a lot - way past redline. A likely outcome would be pistons, connecting rods, and parts of cylinders/heads flying out in all directions, possibly followed by fire - considerably more damage than from a normal prop strike! The engine's ECU should take care of that. (grin ![]() -- Eduardo K. | | "World domination, now" http://e.nn.cl | Linus Torvalds |
Newbie question on trailering Setup | joe | Soaring | 11 | December 26th 04 11:10 PM |
sound of wind shear | Dan Jacobson | General Aviation | 2 | May 11th 04 11:43 PM |
IPAQ Wiring - which pins are used | Michael | Soaring | 9 | March 15th 04 08:48 PM |
Amazing Wind Shear Today | Jay Honeck | Piloting | 25 | December 3rd 03 10:23 PM |
taper pins | Ernest Christley | Home Built | 4 | September 12th 03 03:15 AM |
