Dave Stadt wrote:
"John T Lowry" wrote in message k.net... Sounds to me like an idea worth pursuing. Could have two shear pins, with visually checkable integrity during preflight inspection, to counter the problem of one failing. John Lowry Flight Physics Now you have added two additional points of failure. Just to play devil's advocate (1): I would think that the pins could be designed to have a mean time between failures at least as long as that of the engines themselves. Just to play devil's advocate (2): Would failure of a shear pin be qualitatively any different than any other engine failure? Just to play devil's advocate (3): Logic would suggest that a propellor shaft shear pin failure would most likely occur during take-off, since that's when the engine is delivering the most power. Just how much torque is the propellor applying to the shaft at this time? (Disclaimer: I really do understand everyone's concern about adding potential failure points to the system.) Rich Lemert |
A 300-hp direct-drive engine is producing 583 lb-ft of torque at 2700
rpm. |
Newbie question on trailering Setup | joe | Soaring | 11 | December 26th 04 11:10 PM |
sound of wind shear | Dan Jacobson | General Aviation | 2 | May 11th 04 11:43 PM |
IPAQ Wiring - which pins are used | Michael | Soaring | 9 | March 15th 04 08:48 PM |
Amazing Wind Shear Today | Jay Honeck | Piloting | 25 | December 3rd 03 10:23 PM |
taper pins | Ernest Christley | Home Built | 4 | September 12th 03 03:15 AM |
