VFR Climb gradient
Old April 3rd 05, 12:53 AM
Sparse
Default VFR Climb gradient
Does anyone know of a VFR climb gradient. The only possible thing I can
come up with is what Part 25 says an aircraft must be able to meet
concerning the takeoff path. From the start of takeoff to 1500 feet or
when transition from takeoff to enroute configuration is complete. an
aircraft must be able to climb at least at a 1.2% gradeitn. I ahev
heard of a gradeint of 1.6% for VFR but I acn find nothing about it. I
know the IFR gradient is 3.3%.
Old April 3rd 05, 03:13 AM
Bob Gardner
Part 25 is for transport category aircraft; Part 23 is for folks who fly
little airplanes. AFAIK there is no minimum gradient for Part 23 aircraft,
but you are wise to consider gradient rather than climb rate when planning.
In many cases, it is smarter to do a circling climb over the departure
airport until high enough to clear any terrain that might pose a problem.
Bob Gardner
"Sparse" wrote in message
Old April 3rd 05, 03:18 AM
Bob Gardner
It's a Gardner time-honored tradition...answer first, then research. 23.65
is the appropriate reg, and there are prescribed climb gradients for
airplanes with one, two, three, or four engines. As Damon Runyan wrote, you
could look it up.
Bob
Old April 3rd 05, 05:53 AM
Sparse
Up yours
23.65
wrote, you
could look it up.
Bob
can
or
an
it. I
Old April 3rd 05, 07:00 AM
Toņo
Sparse wrote:
Up yours
Sparse,
I believe that Bob was responding to his own previous post and not to you.
Toņo
Old April 3rd 05, 10:25 AM
The Part 25 transport category climb gradients are neither VFR or IFR; they
are a minimum performance requirement for all operations. IFR takeoff
minimums, obstacle departure procedures, or SIDs will often require IFR
climb gradients in excess of the Part 25 minimums. 200 feet per mile
(3.3%) is the minimum IFR climb gradient for departures when a gradient is
not specified.
Airway en route climb gradients are less than 3.3% and are split into three
values, depending upon altitude. The only reference to these gradients is
in the TERPs section pertaining to airway design.
Old April 3rd 05, 02:06 PM
Matt Whiting
Toņo wrote:
Sparse wrote:
Up yours
Sparse,
Toņo
Not that it matters, he COULD have looked it up himself.
Matt
Old April 3rd 05, 02:17 PM
Whoa....
I think you misunderstood.
I think Mr Gardner was actually being a bit self-deprecating here.
On 2 Apr 2005 20:53:20 -0800, "Sparse" wrote:
Up yours
23.65
wrote, you
could look it up.
Bob
can
or
an
it. I
Old April 3rd 05, 06:35 PM
Bob Gardner
A little testy today, are we? Forget to take your meds?
Forgive my assumption that because you referred to Part 25 you also had
access to Part 23. Herewith the relevant sections:
"§ 23.63 Climb: general.
(a) Compliance with the requirements of §§ 23.65, 23.66, 23.67, 23.69, and
23.77 must be shown -
(1) Out of ground effect; and
(2) At speeds that are not less than those at which compliance with the
powerplant cooling requirements of §§ 23.1041 to 23.1047 has been
demonstrated; and
(3) Unless otherwise specified, with one engine inoperative, at a bank angle
not exceeding 5 degrees.
(b) For normal, utility, and acrobatic category reciprocating engine powered
airplanes of 6,000 pounds or less maximum weight, compliance must be shown
with § 23.65(a), § 23.67(a), where appropriate, and § 23.77(a) at maximum
takeoff or landing weight, as appropriate, in a standard atmosphere.
(c) For normal, utility, and acrobatic category reciprocating engine powered
airplanes of more than 6,000 pounds maximum weight, and turbine engine
powered airplanes in the normal, utility, and acrobatic category, compliance
must be shown at weights as a function of airport altitude and ambient
temperature, within the operational limits established for takeoff and
landing, respectively, with -
(1) Sections 23.65(b) and 23.67(b) (1) and (2), where appropriate, for
takeoff, and
(2) Section 23.67(b)(2), where appropriate, and § 23.77(b), for landing.
(d) For commuter category airplanes, compliance must be shown at weights as
a function of airport altitude and ambient temperature within the
operational limits established for takeoff and landing, respectively, with -
(1) Sections 23.67(c)(1), 23.67(c)(2), and 23.67(c)(3) for takeoff; and
(2) Sections 23.67(c)(3), 23.67(c)(4), and 23.77(c) for landing.
[Amdt. 23-50, 61 FR 5186, Feb. 9, 1996]
§ 23.65 Climb: All engines operating.
(a) Each normal, utility, and acrobatic category reciprocating engine
powered airplane of 6,000 pounds or less maximum weight must have a steady
climb gradient at sea level of at least 8.3 percent for landplanes or 6.7
percent for seaplanes and amphibians with -
(1) Not more than maximum continuous power on each engine;
(2) The landing gear retracted;
(3) The wing flaps in the takeoff position(s); and
(4) A climb speed not less than the greater of 1.1 VMC and 1.2 VS1 for
multiengine airplanes and not less than 1.2 VS1 for single engine airplanes.
(b) Each normal, utility, and acrobatic category reciprocating engine
powered airplane of more than 6,000 pounds maximum weight and turbine engine
powered airplanes in the normal, utility, and acrobatic category must have a
steady gradient of climb after takeoff of at least 4 percent with
(1) Take off power on each engine;
(2) The landing gear extended, except that if the landing gear can be
retracted in not more than seven seconds, the test may be conducted with the
gear retracted;
(4) A climb speed as specified in § 23.65(a)(4)."
As noted by others, VFR/IFR does not enter into the discussion.
Bob Gardner
Up yours
23.65
wrote, you
could look it up.
Bob
can
or
an
it. I
Old April 3rd 05, 07:10 PM
Bob Gardner
Good point about TERPS, although it is directed to procedures designers, not
pilots. Of course, Parts 23 and 25 are directed to manufacturers, not
pilots, and contain nothing that pilots must adhere to. Good guidance,
though, in all three cases.
Bob
wrote in message ...
they
not specified.
three
Angle of climb at Vx and glide angle when "overweight": five questions Koopas Ly Piloting 16 November 29th 03 10:01 PM
Second Stage Climb Gradient? Bill Instrument Flight Rules 10 September 15th 03 06:41 PM
Second Stage Climb Gradient? Bill Piloting 10 September 15th 03 06:41 PM
172 N Climb Performance Roger Long Piloting 6 September 10th 03 11:18 PM
More About Leaning During Climb Dan Luke Owning 13 July 11th 03 02:36 PM
Copyright Š2004-2025 AviationBanter.
