#21
On Fri, 1 Apr 2005 at 02:32:55 in message
.net, Rich Lemert wrote: This morning, while driving past the airport on my way to work, the thought occured to me that a shear pin could be used to protect airplane engines (at least partially) from prop strikes. My understanding is that the props on light singles (at least) are connected directly to the engine's drive shaft It occurs to me that a shear pin could only work effectively against a rotational stoppage. Since a normal prop either fits over a crankshaft end or is bolted to a plate, a shear pin could do little or nothing. What loading cases would you propose for the shear pin failure? In a minor accident which way are the prop tips usual bent? I somehow feel that the possibility of a prop detaching in flight should not be encouraged. :-) -- David CL Francis |
On Fri, 1 Apr 2005 at 13:06:26 in message
t, John T Lowry wrote: Sounds to me like an idea worth pursuing. Could have two shear pins, with visually checkable integrity during preflight inspection, to counter the problem of one failing. Good idea but when both were in place the shear failure load would be twice as strong? -- David CL Francis |
This system would also allow the prop to windmill without attempting
to turn the engine in cases of engine failure. So what do we do for a flywheel? Dan |
That isn't a flywheel. It a ring gear mount for the starter
that also drives belt for the alternator (if it's a Lyc). It's aluminum and weighs about four pounds. An engine such as the O-320, with its four huge cylinders (compared to a Chev 350's eight much smaller ones, for instance) would need a wheel of about 50 pounds in that small diameter. In all direct-drive aircraft engines the prop is the flywheel. In most geared certified engines, the prop is the flywheel. Geared ultralight engines like the Rotax have a separate flywheel, as do many of the converted and geared or belted auto engines. They have other problems with resonance between the prop and flywheel that can lead to belt or gear failures if not properly designed and operated. Dan |
Newbie question on trailering Setup | joe | Soaring | 11 | December 26th 04 11:10 PM |
sound of wind shear | Dan Jacobson | General Aviation | 2 | May 11th 04 11:43 PM |
IPAQ Wiring - which pins are used | Michael | Soaring | 9 | March 15th 04 08:48 PM |
Amazing Wind Shear Today | Jay Honeck | Piloting | 25 | December 3rd 03 10:23 PM |
taper pins | Ernest Christley | Home Built | 4 | September 12th 03 03:15 AM |
