#11
My wife even liked this one. But you know us helicopter pilots are
really good because we can handle 4 wiggly tails spinning in a circle. My poor attempt at humor. B2431 wrote: Your right, the B-25 had two of those wiggly things You have to careful of using technical terminology like that. I have seen twin wiggly things in mony aircraft, but enough about my wife. Rumour has it the USAF got rid of the C-121 Constelation because the newer pilots couldn't handle 3 pieces of tail at the same time. Dan, U. S. Air Force, retired |
On Mon, 04 Aug 2003 17:13:25 GMT, Chris W wrote:
I got such a good answer on my question about flap design I thought I would ask another design question. why would a plane that has two engines have two vertical stabilizers. No in the case of the Aircoupe I always thought the reason for the twin tail was so that the helical prop wash wouldn't induce a yaw tendency from the prop wash hitting the vertical stabilizer/rudder. It is my understanding that the Aircoupe was designed so you wouldn't need rudder pedals, and the twin tail I think would have helped that. But on a twin engine, what's the point? having two vertical stabilizers and two rudders seems significantly more complicated both structurally and mechanically so why do it if there isn't some advantage? There must be one I don't know about. So many smart answers to averything but the question. If the tail assembly is in the prop awsh, the low and no-speed response is much greater. ie ground and taxi. The tradeoff is the crosswind component induced by the spinning prop, which the Ercoup didn't want, so the put the rudders outboard of the prop and pu on a kickass main gear system to keep the thing straight. Mr Knowital. |
In the case of some Navy jets, the issue was one of space. The vertical
surface area desired on a plane like an F-14 would have required a single tail too tall to fit inside the hangar deck. Or so I have heard it explained by the "Aviator" types. Harry "first effective rudder" Frey Wright 1902 glider, etc. |
Pitts questions | Wendy | Aerobatics | 7 | February 13th 04 03:48 AM |
Accelerated spin questions | John Harper | Aerobatics | 7 | August 15th 03 07:08 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Oshkosh Get together Roster - Sign in, please! | Bruce E. Butts | Home Built | 4 | July 26th 03 11:34 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
