Compass turns revisited
Old April 4th 05, 05:45 PM
Bob Gardner
Default Compass turns revisited
Got a little memory jog in the April 2006 Designee Update...other than
"Basic Instrument Flight Maneuvers," there is nothing in the 2004 (latest)
PTS about timed turns OR compass turns. Nothing. Nada. So instrument pilot
wannabes need not be concerned about demonstrating either one to the
examiner. The examiner has some degree of latitude in deciding just what a
"basic instrument flight maneuver" is...but no one is going to get a pink
slip with "Timed turns to headings" on it.
Bob Gardner
Old April 4th 05, 07:06 PM
Michael
pink
However, the full procedure partial panel non-precision approach is
still in place, and in order to do that you will need to do compass
turns or timed turns to headings. The change allows you to do what
works best for you. Over time, I've discovered that what works best
depends on the student and the equipment.
Some students just don't get math. For them, the mental math required
to figure out how many seconds the turn needs to be is too much to do
while flying under the hood. For others, the jumping around, lead, and
lag of the compass is too difficult to deal with - they prefer to time
the turn, the check the compass only in level flight.
I personally belong to the latter camp. I am a strong believer in only
looking at the compass when I know it will be accurate, and using time
for turns when the heading gyro is not available. I've taught some
students that method, and they've done well with it. Others hated it,
and wound up just looking at the compass anyway. If they slow the rate
of turn to half-standard-rate when getting close to the heading, it
works reasonably well. Fortunately I've never had a student who
couldn't deal with either method. I'm not sure what I would do then.
Michael
Old April 4th 05, 07:48 PM
Roy Smith
Michael wrote:
Fortunately I've never had a student who couldn't deal with either
I think the answer needs to be "not sign them off for the checkride".
The ability to turn to and maintain a heading without a working DG is
an essential skill. Somehow you need to be able to do it.
Just turning until the little picture of the airplane is pointing in
the same direction as the purple line might just be a reasonable plan
with today's cockpits. Unfortunately, I'm not sure you would convince
an examiner of that.
Back when all our airplanes had ADF's in them, just setting the ADF to
a distant AM radio station made a decent DG replacement.
Old April 4th 05, 09:05 PM
paul kgyy
A new replacement for the ADF is the GPS, of course. Many, like the
GNS430, provide course information that's a very useful replacement for
a bad gyro. I used it on my checkride and the examiner made me turn to
a different page. But if all the electrons die, you have to know how
to use a magnetic compass.
Old April 4th 05, 09:47 PM
a different page
The examiner was not authorized to do this.
Pilots need to hold examiners to the same standards that the examiners
hold the pilots, i.e., the standards as described by the PTS.
Pilots don't get to say "I think I'll do it this way, and screw what
the standards say".
Neither does the examiner.
Old April 6th 05, 08:17 PM
ram
Its my understanding that a recent email to DPEs discussed exactly this
scenario and told DPEs that they could not allow pilots to use the GPS
during partial panel. Someone out there may be able to verify this.
I completed (successfully!) my instrument checkride last evening and was not
allowed to use the GPS during this maneuver. I tried to load the approach
and was told "no." Turned to the position page and the DPE turned it to the
NAVCOM page (not much help). Had to rely on the compas and the timer.
Bob
news
a different page
the standards say".
Old April 4th 05, 09:32 PM
Michael
Well, that's a defeatist attitude. I would like to think that I would
come up with some method they could handle.
In a glass cockpit Cirrus (at least the one I flew) it is the only
plan. A PFD failure leaves you with ASI, electric AI, Altimeter - and
two Garmin 430's without CDI's (the only CDI is built into the HSI
presentation on the PFD). The only approach you can shoot after PFD
failure is a GPS, and you can shoot it ONLY by turning until the little
picture of the airplane is pointing in the same direction as the purple
line. I suppose you could use a compass, but I'm not sure what the
benefit would be.
Unfortunately, I'm not sure you would convince an examiner of that.
In the Cirrus I flew, there was no way to simulate PFD failure (vacuum?
who dat?) which would not allow that approach to work. There would be
no convincing involved, and with the deletion of compass turns from the
PTS, the examiner no longer has the option of failing both GPS units (I
guess we lost the PFD and both GPS units or the constellation?) and
making the applicant do compass turns.
Of course the recommended emergency procedure in the event of PFD
failure is to engage the autopilot and not hand-fly at all, and you can
argue that losing the autopilot AND the PFD on the same flight is
unlikely. On the other hand, that makes the autopilot a no-go item for
IMC, and I doubt any examiner would accept this.
The interesting question is whether an examiner would insist on setting
up a situation, however improbable, that would require the student to
do partial panel flying without the GPS. I suppose he might, but it
would surprise me if he did. Is it reasonable to expect an instrument
rating applicant to be able to handle multiple point failures - and
then allow him to carry passengers in low IMC in a single engine
airplane?
Much as I hate to say it, the truth is that partial panel as we know it
is not so much a valuable skill in itself (except in the sense that
learning to do ANYTHING that is demanding in an airplane is valuable as
it makes you a better pilot) and more a reasoned response to flying
with unreasonable technology. When both your sole attitude gyro and
your sole heading gyro are plumbed to a single dry pump, you better be
proficient at flying with both of them failed, since dry pumps are
junk. It might interest you to know that the ATP checkride includes no
partial panel work at all, since that sort of crap is not tolerated in
transport category aircraft.
Michael
Old April 4th 05, 10:05 PM
Barry
Don't the 430's still have the CDI on the "Default NAV page"? Or did Garmin
change the interface for the Cirrus?
Old April 4th 05, 10:09 PM
Ron
Michael,
I think you need to brush up on your Garmin GPS's. In the Cirrus, I
believe, the Garmins drive the Avidyne display. One of the navigation pages
on the Garmin displays a CDI that scales properly to approach sensitivity.
That is much more accurate than following the magenta line for a backup
approach.
Ron
"Michael" wrote in message Well, that's
benefit would be.
Experience with SIRS compass? Ross Oliver Owning 2 March 18th 05 06:21 PM
Vertical Card Compass Mystery Rosspilot Owning 3 November 3rd 04 06:01 PM
Do you use your magnetic compass? Roger Long Piloting 42 May 25th 04 12:08 PM
Strange compass behavior me Owning 10 February 14th 04 04:24 AM
Compass turning error Marty Ross Piloting 3 August 21st 03 02:53 PM
