Enjoy the Arrow - it's one of the great airplanes. Be thankful for
that free-fall landing gear. I landed with 2 green last year when one of the squat switch wires broke from old age - strong pucker factor. |
No more wondering what jerk last flew the airplane, huh? Even better,
since you'll be in the same airplane all of the time you'll pretty soon figure it it knows how to read your mind. Think it, it does it. Took mine (an M20J) about 20 hours to figure out what I was trying to do. Then it began to really be fun -- you'd know exactly where it would touch down, if you were a couple of knots fast on final it felt awful! I think you'll find hand flying the thing IFR great fun, too, holding altitude within a needle width gets easy (but in my case having glide slope and localizer centered near the ground still takes lots of attention). You'll also figure out how to make it sip gas: low rpms, careful leaning, and the like. The IO360 that pulled the Mooney around on long trips eastbound (10 or 12 thousand feet) would be very happy drinking about 8 GPH. That provides all kinds of endurance (we carried about 60 gallons useable). About fuel management --for what it's worth I liked to taxi out on one tank, switch over to the take-off tank for run-up -- I'd break the hand of anyone who tried to switch tanks afterrunup and before takeoff!--. I figured at that point I proved both tanks would run the engine. I'd fly away half the tank I took off on, switch over, and take most of the fuel off the other tank. One of the thought processes was that the first tank still had enough in it to get me back to where I started from when I switched. (East coast based, nearly all first legs were into a headwind). No matter what my flight plan said, when I switched back to the takeoff tank (now I had somewhat more than 25% of the fuel left) I was going to land for gas. That fuel management scheme was part of our own checklist that was a bunch more thought out than the one the airplane came with. (Are your navs and coms set up for the miss inbound of the marker? Ours were. ADF was almost always tuned to a strong station near our destination, it turns out the adf needle makes a good replacement for the DG should it fail. That was part of our en route checklist.) There's a thought. Other pilots, chip in here. What things do you do to keep yourself safe that are not usually taught? I've offered a couple of obvious ones, you've got to have better ones. |
I burn fuel from the tank that the minute hand on my clock is pointing to.
That way I can always tell by looking if I remembered to switch tanks last 1/2 hour. My tie-down is fifty feet from the runway. I don't switch tanks on the ground for this reason. I'd hate to switch to a bad one only to find out at 100' that it's bad. I'd rather find out 1/2 hour later, at several thousand feet. My opinion will probably change the first time I find bad gas in one of my tanks. "Tony" wrote in message oups.com... No more wondering what jerk last flew the airplane, huh? Even better, since you'll be in the same airplane all of the time you'll pretty soon figure it it knows how to read your mind. Think it, it does it. Took mine (an M20J) about 20 hours to figure out what I was trying to do. Then it began to really be fun -- you'd know exactly where it would touch down, if you were a couple of knots fast on final it felt awful! I think you'll find hand flying the thing IFR great fun, too, holding altitude within a needle width gets easy (but in my case having glide slope and localizer centered near the ground still takes lots of attention). You'll also figure out how to make it sip gas: low rpms, careful leaning, and the like. The IO360 that pulled the Mooney around on long trips eastbound (10 or 12 thousand feet) would be very happy drinking about 8 GPH. That provides all kinds of endurance (we carried about 60 gallons useable). About fuel management --for what it's worth I liked to taxi out on one tank, switch over to the take-off tank for run-up -- I'd break the hand of anyone who tried to switch tanks afterrunup and before takeoff!--. I figured at that point I proved both tanks would run the engine. I'd fly away half the tank I took off on, switch over, and take most of the fuel off the other tank. One of the thought processes was that the first tank still had enough in it to get me back to where I started from when I switched. (East coast based, nearly all first legs were into a headwind). No matter what my flight plan said, when I switched back to the takeoff tank (now I had somewhat more than 25% of the fuel left) I was going to land for gas. That fuel management scheme was part of our own checklist that was a bunch more thought out than the one the airplane came with. (Are your navs and coms set up for the miss inbound of the marker? Ours were. ADF was almost always tuned to a strong station near our destination, it turns out the adf needle makes a good replacement for the DG should it fail. That was part of our en route checklist.) There's a thought. Other pilots, chip in here. What things do you do to keep yourself safe that are not usually taught? I've offered a couple of obvious ones, you've got to have better ones. |
Sounds like you have a well thought out plan, too. I think it might
have been in the owner's manual that said something like "switch to most full fuel tank" before takeoff, and after run-up. That's the worst possible time to change tanks. The only advantage my fuel scheme might have is, after taking most of the fuel from the second tank, I want to be in a landing pattern or at least cleared for a landing. It gives me a fairly secure 25% fuel remaining plan. I'd done a couple of really long flights, fuel limitations (and pilot bladder limits, if truth was to be told) were limiting factors. |
In article .com, Tony wrote:
have been in the owner's manual that said something like "switch to most full fuel tank" before takeoff, and after run-up. That's the worst possible time to change tanks. Ack. Have to agree with you, but I think you misread the instructions. I start and taxi on one tank, then run up on the other with takeoff on the same tank as the runup. That way, you know you have good fuel in both tanks. Morris |
![]() In article .com, Tony wrote: have been in the owner's manual that said something like "switch to most full fuel tank" before takeoff, and after run-up. That's the worst possible time to change tanks. How long would the engine run if you selected an empty tank? My 182 doesn't even go 30 seconds at idle after I turn the gas off. |
One well known aviation university teaches you to "fly out on the tank
you flew in on". The theory being that takeoff is not the time to "test" whether a tank you just switched to is blocked, the fuel valve malfunctioned, a tank is empty (cuz you forgot to check it), a tank you just switched to is full of water, etc. If you switch just prior to takeoff or just prior to runup, you have about 1 or 2 minutes of flight until the carb bowl and gascolator empties in a small Piper. Then, you get an empty fuel line or whatever was in the other tank. Usually, you are not in a very good position to deal with no fuel or contaminated fuel at the end of that short time period. Opinions on this one vary. I leave the valve where it is and switch after burning off about 5 gallons (climb to 2500' plus 10 minutes of cruise). Good Luck, Mike Journeyman wrote: In article .com, Tony wrote: have been in the owner's manual that said something like "switch to most full fuel tank" before takeoff, and after run-up. That's the worst possible time to change tanks. Ack. Have to agree with you, but I think you misread the instructions. I start and taxi on one tank, then run up on the other with takeoff on the same tank as the runup. That way, you know you have good fuel in both tanks. Morris __________________________________________________ _____________________________ Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com The Worlds Uncensored News Source |
"Mike Spera" wrote in message ...
Opinions on this one vary. I leave the valve where it is and switch after burning off about 5 gallons (climb to 2500' plus 10 minutes of cruise). For my first tank switch, I like to be over something that I wouldn't mind landing on or at a high enough altitude that having the engine stop would not be too exciting of an experience... Subsequent switches, I'm not as paranoid about... |
Mike Spera wrote:
One well known aviation university teaches you to "fly out on the tank you flew in on". I take off on "both." If either one works, I have gas. George Patterson There's plenty of room for all of God's creatures. Right next to the mashed potatoes. |
One helpful point:
When changing fuel tanks, keep your hand on the fuel selector valve for about 30 more seconds and monitor the fuel pressure gauge. If the fuel pressure drops or the engine quits your hand will already be on the valve to re-select the good tank. In my childhood I flew a Beaver amphibian out of King Salmon. The procedure to maximize the available fuel was to run the tanks dry from the rear to the front. A beaver has fuel in the belly in two tanks (a bad place and most Beaver crashes involve fire.) I could rest my hand on the fuel selector valve and watch the fuel pressure gauge. Once the fuel pressure just started to drop the tank could be switched quickly without the engine quitting. Karl "Curator" N185KG |
First Two Aero Lessons This Weekend (Long) | David B. Cole | Aerobatics | 12 | December 3rd 04 01:18 AM |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
Flight test update - long | nauga | Home Built | 1 | June 5th 04 03:09 AM |
SWRFI Pirep.. (long) | Dave S | Home Built | 20 | May 21st 04 03:02 PM |
Across Nevada and Part Way Back (long) | Marry Daniel or David Grah | Soaring | 18 | July 30th 03 08:52 PM |
