![]() "John D. Abrahms" wrote in message om... I know that all the airplanes that people build by themselves fall into the experimental category, because they are not factory-made, serialized products but individually built with different quality and with different modifications. Not really. You can restore a certified airplane from a dataplate and a single piece of metal and build everything yourself. If you can get an IA to sign off on it, and the FAA to agree, it doesn't have to be experimental. I also know that GA airplanes made of composites usually fall into the experimental class category, too. No. Cirrus, Lancair and a few others are composites and they are certified aircraft. What really annoyed me is that there also are planes that are not composite and also are factory-made in high numbers that fall into experiemnat category, like the Aero L-39 Jet airplane. That's because it's an ex-military airplane that was never put through normal certification. In order to fly in private hands it has to have an experimental airworthiness certificate. From what I know a pilot who wants to fly a L-39 jet airplane needs 1000hrs of PIC time, and after that needs a Letter of Authorization to be able to fly the L-39. Correct. What if the L-39 would not be registered as experimental but as normal/utility/aerobatic airplane? The manufacturer, as far as I know, has no interest in spending the oodles of money required to achieve this. And most likely you wouldn't be able to afford the airplane if they did. Would this also require 1000hrs of PIC time before someone can fly with this L-39? It would require a type rating. Are there any PIC hours required to be allowed to fly turbine airplanes? To my knowledge, that is only the case on the few ex-military experimentals being sold out there. I also heard that it's not possible to use an experimental plane for training (PPL, CPL, IFR, whatever). No. A CFI can use your experimental to train you to fly it. Juan |
Used to be ex military aircraft were in the Restricted category. I
dealt with a Grumman Goose and a Lodestar years ago where that was the case. Is that no longer true or are fighters and trainers different? The way I remember it was the FAA came out with the hours and LOA requirement because there were too many doctors and lawyers that had more money than brains and got out of their Bonanza and into a P-51 and killed themselves. Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
The LOA is no longer called an LOA, but from what the FSDO told me about
the requirements, it is still a rose by another name. Don Hammer wrote: Used to be ex military aircraft were in the Restricted category. I dealt with a Grumman Goose and a Lodestar years ago where that was the case. Is that no longer true or are fighters and trainers different? The way I remember it was the FAA came out with the hours and LOA requirement because there were too many doctors and lawyers that had more money than brains and got out of their Bonanza and into a P-51 and killed themselves. Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
LOA's are still around. For the ex-mil's now they have a weird
pseudo-type-rating system that shows up on your license. But that applies only to ex-mil on that AC that's been recently updated. For my BD-5J, for example, I was told to apply for an LOA, and that's what the FSDO will issue me if aero-medical ever gets around to handling my special issuance renewal. "AINut" wrote in message ... The LOA is no longer called an LOA, but from what the FSDO told me about the requirements, it is still a rose by another name. Don Hammer wrote: Used to be ex military aircraft were in the Restricted category. I dealt with a Grumman Goose and a Lodestar years ago where that was the case. Is that no longer true or are fighters and trainers different? The way I remember it was the FAA came out with the hours and LOA requirement because there were too many doctors and lawyers that had more money than brains and got out of their Bonanza and into a P-51 and killed themselves. Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
![]() "Don Hammer" wrote in message ... Used to be ex military aircraft were in the Restricted category. I dealt with a Grumman Goose and a Lodestar years ago where that was the case. Is that no longer true or are fighters and trainers different? Don't know about the Goose or Lodestar but the ex-mil fighters are covered by an AC, can't remember the number. The way I remember it was the FAA came out with the hours and LOA requirement because there were too many doctors and lawyers that had more money than brains and got out of their Bonanza and into a P-51 and killed themselves. Still applies. ![]() |
![]() "Don Hammer" wrote in message ... Used to be ex military aircraft were in the Restricted category. I dealt with a Grumman Goose and a Lodestar years ago where that was the case. Is that no longer true or are fighters and trainers different? Flavors and trends do change over time. It did indeed, used to be the case that most warbirds that didn't have a civilian type certificate were certified in the "Restricted" category with the specific restrictions determined on a case by case basis. As I recall there were also some in the "Limited" category, with the specific limitations also determined on a case by case basis. At that time it was also true that the "certificate" given to an amateur built aircraft was only valid for one year. Every year you had to have the FAA come out and inspect the airplane to renew it. Then the FAA figured out that they were in the business of giving free annuals for homebuilts and instituted the present permanent "certificate" that must be inspected every year by a certified mechanic. Note that a "repairman certificate" holder is a "certified mechanic" whose "certification" extends only to one specific airplane. :-) Nowadays most of the warbirds are finding their certification easier in the "Exhibition" category. This category generally allows some radius of operation, of several hundred nautical miles, for "pilot proficiency maintenance" where you can fly pretty much as you please. Trips outside of that radius require that the FAA be "notified" prior to the trip. Generally you can fax the FAA office a "notification." You can also send them a list of the shows and flyins that you plan to attend once a year. Much of this change is because of the changing view of warbirds. At one time they were just big, expensive, impractical airplanes. Now they are antiques and collectors items and people pay money to see them up close and see them fly. I can remember when you could buy a surplus fighter for a couple of thousand bucks because nobody wanted the headaches. I just wish I had bought a few dozen of them an stored them in the back of my hangar! :-) I did meet one older gentleman down in Louisiana who had thirty Stearman trainers brand new in the crate stored in the back of his hangar. He said whenever he needs a little extra money he puts one together and sells it. Since that was back in the sixties, I doubt that any of them are left in the hangar. He was in his sixties then as well and may not need extra money anymore! Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) |
On Thu, 7 Apr 2005 16:36:28 -0500, "Highflyer" wrote:
I can remember when you could buy a surplus fighter for a couple of thousand bucks because nobody wanted the headaches. I just wish I had bought a few dozen of them an stored them in the back of my hangar! :-) Dunno, HF...I've *seen* your hangar. Sure there ain't a couple of P-40s stashed in back? :-) Ron Wanttaja |
![]() "Ron Wanttaja" wrote in message ... On Thu, 7 Apr 2005 16:36:28 -0500, "Highflyer" wrote: I can remember when you could buy a surplus fighter for a couple of thousand bucks because nobody wanted the headaches. I just wish I had bought a few dozen of them an stored them in the back of my hangar! :-) Dunno, HF...I've *seen* your hangar. Sure there ain't a couple of P-40s stashed in back? :-) Ron Wanttaja No P-40s Ron. However, there ARE a couple of Vultees. :-/ Back behind the Stinson and the Pietenpol and the Cavalier and the Apache. It is getting crowded in there. One of these days I will get ALL of them together and flying. Then I WILL have a parking problem! :-) Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) |
PA-32 on Experimental Certificate | Mike Granby | Owning | 3 | July 21st 04 03:04 AM |
Crashing Experimental on America's Funniest Home Videos | Jay | Home Built | 7 | March 10th 04 12:11 AM |
USA: Experimental Certificates | C.Fleming | Soaring | 4 | October 30th 03 10:48 PM |
A couple Questions-Ramp Checks and Experimental Operations | Badwater Bill | Home Built | 48 | October 8th 03 09:11 PM |
2 Place Experimental.... | [email protected] | Soaring | 8 | September 7th 03 03:03 AM |
