Towplane performance
Old April 7th 05, 12:09 AM
Scott
Uh, but I think you might be missing an important point. Experimental
aircraft such as the RV series can't be used for hire. If the plane and
pilot are provided free, and not compensated in any way, then it might
be doable. I guess you'd have to find a pilot that is only interested
in building time and not wanting to make money...I'm out
Scott
Udo Rumpf wrote:
"Roy" wrote in message
om...
Many thanks for all the advice and suggestions so far.
Non of the suggestions were for other than standard (old) aircraft
products.
It has been suggested that an RV9 with a big motor (160-200hp) would
be great to do the job.
Anyone else considered this approach?
We are not a commercial operation and dont have to pay our pilots.
There is no insurance problem so this solution has some appeal. ie
new airframe, easy repair & maintenance.
Have a look at this site.
http://www.soarmn.com/soaring_files/...ison_table.jpg
This Towplane table was done in 1994. The calculation are all referenced to
see level and standard temperature. The performances appear high,
but are not, because most of the comments on this group referred to High
temperature and high altitude. All Climb performances are with a fully
loaded
twin Grob. Acceleration on the Ground was not taken into account.
For example if the temperature is 80F and a 1000ft the factor becomes .77
Please note how well the Zenith 300 with a 180 HP does.
I could well imagine Dick VanGrunsven RV 9 with a 180HP would do very
well but
the RV 10 would be a better choice, as the airframe is stronger and
designed
to take a bigger engine, the airframe would still be well under 1500lb
if it is a
very basic tow plane. For example the RV 9 with a pilot and fuel and a
max 160HP
( allowed only) has a power loading of 10.
The RV10 with the same pilot and fuel would, but 180 HP, would have
the same
power loading as the RV9. The RV 10 has a larger wing area, it would
climb better
at the speeds we tow at. Also the Airframe is designed for up to 260HP.
For a club with a small membership and limited options I would favour a
stripped down
C-170 or 172 with 180HP if Summer temperature and see elevation allow.
Parts and services are readily available and the performance is not bad
at all for 180HP.
Regards
Udo
Old April 7th 05, 12:47 AM
Udo Rumpf
"Scott" wrote in message
pilot are provided free, and not compensated in any way, then it might be
doable. I guess you'd have to find a pilot that is only interested in
Scott
I did not make a point about the viability as it relates to
the regulation, but rather performance.
Udo
om...
products.
to
loaded
.77
well but
designed
to take a bigger engine, the airframe would still be well under 1500lb if
it is a
max 160HP
The RV10 with the same pilot and fuel would, but 180 HP, would have the
same
climb better
stripped down
at all for 180HP.
Regards
Udo
Old April 8th 05, 12:48 AM
Roy
Scott wrote in message ...
Scott
Scott
Presume you haven't heard of that phenomina called Gliding Clubs,
where volunteers act as instructors and others as towpilots... FOR
FREE.
I hear there are lots of them functioning around the world.:-))
AND gentlemen, wonder of wonders, there are other juristictions than
the USA that have glider towing.....sometimes it appears that people
presume only US residents read or contribute to this news group :-)))
Well off to go flying on a great Noo Zeeland day. Yep its FRiday and
the therms are popping.
Old April 8th 05, 12:59 AM
Shawn
FREE.
Oh relax Roy. We'll get over ourselves as soon as we're done selling
ourselves to the Chinese. Sometime around the second week of December.
How were those upside down thermals?
Shawn
Glider - Towplane Signals Mike the Strike Soaring 24 March 26th 05 09:33 PM
Performance World Class design proposal iPilot Soaring 85 September 9th 04 09:11 PM
Complex / High Performance / Low Performance R.T. Owning 22 July 6th 04 08:04 AM
Super Cub towplane performance Marc Arsenault Soaring 1 July 11th 03 01:42 PM
