Krosno Roll Rate??
Old April 7th 05, 10:38 PM
Charles Petersen
Default Krosno Roll Rate??
We are building a simulator, using a Krosno cockpit on a motion platform.
Our expert on the motion platform is selecting the actuators, and the speed
varies with the price, so we are going to try to buy only as much power as
we need. Accordingly, we need to know the approximate roll rate of the
Krosno. Does anyone have this information or an educated guess??
Old April 8th 05, 07:59 PM
Vaughn
I have a few hundred hours in that type, but I hate to give you a number.
Call Barry Aviation at (561) 624-3000 and ask to talk to either Julius or Tim
Sr. Either of them will be able to give you a good answer.
Vaughn
"Charles Petersen" wrote in message
We are building a simulator, using a Krosno cockpit on a motion platform. Our
expert on the motion platform is selecting the actuators, and the speed varies
with the price, so we are going to try to buy only as much power as we need.
Accordingly, we need to know the approximate roll rate of the Krosno. Does
Old April 9th 05, 04:30 AM
bluegliderguy
Soaring Magizine Feb 93
Dick Johnson Flight Report
Aileron control was good and 45-to-45 degree rolls required
only about 5 seconds to perform at thermaling airspeeds.
Old April 9th 05, 02:42 PM
Vaughn
By the way, consider adding hand controls to your simulator. Here is the
best picture that I can find:
http://www.freedomswings.ca/gallery2...pg&W=600&H=435 It is a
simple series of notches to hold the spoiler in position and a hand lever that
connects to the left rudder cable. If you don't have those cables in your
cockpit, you could connect the lever to the left rudder peddle with a light rod.
Vaughn
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 June 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 May 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 April 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 March 1st 04 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 December 1st 03 06:27 AM
