![]() wrote in message oups.com... Only 650TT? Unless there's serious corrosion or a burnt valve, there should be no problems with exhaust valves. Why does the engine need work already? Dan Bottom ends on those engines are usually good for 2,000 hours. The tops start going at 500. Same for any of the small Continental engines and the O-300. The jugs just don't last. $500 is a good investment in exhaust valves. After 500 hours they start to neck down. They aren't sodium-filled like Lycoming exhaust valves, but of course they don't run as hot either. I have seen a few of these Continental jugs last as much as 800 hours, but they are the exception, not the rule. Now watch and see if someone doesn't jump in here claiming a thousand hours, and counting, on his cylinders. |
OK, I'll do it. I had over a thousand (maybe 1200STOH) on the C-85 in
my old Chief. Never been majored and when I sold it, it had 2400TT. Compressions were in the 75 and above range. Used a quart in 14-16 hours. Since the top, it had used Shell 15W-50 semi-synthetic oil. Of course, I'm not claiming there couldn't have been worn parts (valves etc.) but it sure ran sweet and strong. On the other hand, I have to tear down my A-65 since I have (suspect at this point) a burned valve from 100LL use I imagine (cross country to/from Oshkosh last year and that was all that was available). It has about 850 SMOH. Since I have one dead one, I will pull all 4 and put in 100 Octane valves since I don't think 80 is coming back... Scott jls wrote: wrote in message oups.com... Only 650TT? Unless there's serious corrosion or a burnt valve, there should be no problems with exhaust valves. Why does the engine need work already? Dan Bottom ends on those engines are usually good for 2,000 hours. The tops start going at 500. Same for any of the small Continental engines and the O-300. The jugs just don't last. $500 is a good investment in exhaust valves. After 500 hours they start to neck down. They aren't sodium-filled like Lycoming exhaust valves, but of course they don't run as hot either. I have seen a few of these Continental jugs last as much as 800 hours, but they are the exception, not the rule. Now watch and see if someone doesn't jump in here claiming a thousand hours, and counting, on his cylinders. |
![]() "Scott" wrote in message ... OK, I'll do it. I had over a thousand (maybe 1200STOH) on the C-85 in my old Chief. Never been majored and when I sold it, it had 2400TT. Compressions were in the 75 and above range. Used a quart in 14-16 hours. Since the top, it had used Shell 15W-50 semi-synthetic oil. Of course, I'm not claiming there couldn't have been worn parts (valves etc.) but it sure ran sweet and strong. Scott, you are a combination of special, astute, and lucky. Good for you. On the other hand, I have to tear down my A-65 since I have (suspect at this point) a burned valve from 100LL use I imagine (cross country to/from Oshkosh last year and that was all that was available). It has about 850 SMOH. Since I have one dead one, I will pull all 4 and put in 100 Octane valves since I don't think 80 is coming back... I flew into a rural sod field on the Nolichucky River and coaxed a friendly farmer to take me to a local Amoco station for gasoline --- So's I could avoid that dreadful 100LL from the county airport. There weren't any gasoline cans there but a darling waitress at the greasy spoon next door washed out two flat and flexible 5-gallon cooking oil containers for me. That 87 octane got me and the little A-65 home. If you're stuck with the deplorable tankful of 100LL, MMO helps. I had a burnt valve on a low-time A-65 once. I changed out the rocker arm because it looked like the toe was pushing the stem eccentric in the guide. I lapped in a new valve and it worked and has kept good compression now for more than 200 hours. Scott jls wrote: wrote in message oups.com... Only 650TT? Unless there's serious corrosion or a burnt valve, there should be no problems with exhaust valves. Why does the engine need work already? Dan Bottom ends on those engines are usually good for 2,000 hours. The tops start going at 500. Same for any of the small Continental engines and the O-300. The jugs just don't last. $500 is a good investment in exhaust valves. After 500 hours they start to neck down. They aren't sodium-filled like Lycoming exhaust valves, but of course they don't run as hot either. I have seen a few of these Continental jugs last as much as 800 hours, but they are the exception, not the rule. Now watch and see if someone doesn't jump in here claiming a thousand hours, and counting, on his cylinders. |
A-65 exhaust stud specs | Jerry Jensen | Home Built | 4 | March 3rd 04 01:13 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Home Built | 0 | January 26th 04 07:48 AM |
SS exhaust ball joints | Stu | Home Built | 1 | January 3rd 04 10:34 PM |
Exhaust Tape | RobertR237 | Home Built | 19 | July 30th 03 03:06 AM |
Exhaust for VW motor | Andre | Home Built | 0 | July 14th 03 03:14 PM |
