compound curves in plywood
Old April 8th 05, 09:30 PM
I would guess that the construction techniques used
were similar to those used in boatbuilding.
http://www.albacore.org/USA/members/...g_albacore.asp
http://www.boats.com/content/default...contentid=1184
May help.
There is a remarkable wooden flying boat hull in the RAF Museum
at Hendon that was built in the early 1920s. It has a 'moulded'
hull which appears to have been constructed using boatbuilding
techniques of the time.
http://www.rafmuseum.org.uk/supermarine-southampton.htm
With its varnished finish it is simply stunning to
look at.
Old April 8th 05, 10:00 PM
BA-100
egroups.com:
May help.
look at.
All good stuff, but not what I realy need to know. Rummaging around, I
found this, which is a bit enlightening..
http://personal.eunet.fi/pp/gsahv/torture/torture.htm
Old April 8th 05, 10:39 PM
Alan Baker
In article .com,
May help.
look at.
Is everyone forgetting the deHavilland Mosquito? Constructed almost
entirely of cold-moulded plywood.
Alan Baker
Vancouver, British Columbia
"If you raise the ceiling 4 feet, move the fireplace from that wall
to that wall, you'll still only get the full stereophonic effect
if you sit in the bottom of that cupboard."
Old April 8th 05, 11:19 PM
Morgans
Isn't cold molding done using layers of wood, with glue applied as the wood
is bent in the mold, with the glue setting up in the new shape?
Jim in NC
Old April 8th 05, 11:48 PM
Alan Baker
Yup. And the original post was talking about just that, ISTM.
"Seems to me even the wettest veneers would split if you
tried to force them into or around a male or female mold. to date,"
Alan Baker
Old April 9th 05, 03:16 AM
Highflyer
"Morgans" wrote in message
wood
Jim in NC
Exactly. Plywood is nothing but thin veneers of wood glued together face to
face with the grain running at different angles, generally ninety degrees,
but sometimes other angles for special applications. Plywood is normally
laminated on a flat plate making a flat sheet of wood that is very hard to
bend into anything other than a conical curve because the laminated layers
are glued together so they can't slide.
Cold Moulding is merely a low temperature process using ordinary waterproof
glues, for makeing you own plywood from thin veneers that is formed over
something other than a flat plate, so that it comes out with the shape of
the mould it was laminated in or on, as the case may be.
No reason in the world you can't make compound curved plywood by laminating
it up over a male plug and useing a vacuum bagging process to apply the
requisite clamping pressure. Ideally pick a good waterproof glue that gives
you a rather long working time and bonds well with a fairly low clamping
pressure. Say 5 to 10 pounds per square inch clamping pressure that you can
easily obtain with simple vacuum equipment. Working time of fifteen or
twenty minutes should allow time to build up thin laminations and get
clamping pressure onto them. This can be stretched a lot by using staples
with a pull pad under them to apply temporary clamping pressure as you build
up the lamination.
I have only done this using older glues like resorcinol and aerolite and
urea resin. I would think it would work very well with some of the more
modern epoxy based wood glues like T-88, etc. If it works for canoes, it
oughtta work for a Bowlus. :-)
Highflyer
Highflight Aviation Services
Pinckneyville Airport ( PJY )
Nut/thread securing compound nauga Home Built 7 April 22nd 04 07:56 AM
Randolph Wing Walk Compound Larryskydives Owning 7 March 7th 04 09:44 PM
Plywood Kathi Jo Home Built 3 January 12th 04 10:48 PM
Somebody Terrified of Compound Curves ---- Or Just Lazy Larry Smith Home Built 8 October 31st 03 02:40 PM
Substitute for Mahogany plywood Kelvin & Janice Rempel Home Built 1 September 5th 03 08:02 PM
