In article .com, Tony wrote:
have been in the owner's manual that said something like "switch to most full fuel tank" before takeoff, and after run-up. That's the worst possible time to change tanks. Ack. Have to agree with you, but I think you misread the instructions. I start and taxi on one tank, then run up on the other with takeoff on the same tank as the runup. That way, you know you have good fuel in both tanks. Morris |
![]() In article .com, Tony wrote: have been in the owner's manual that said something like "switch to most full fuel tank" before takeoff, and after run-up. That's the worst possible time to change tanks. How long would the engine run if you selected an empty tank? My 182 doesn't even go 30 seconds at idle after I turn the gas off. |
One well known aviation university teaches you to "fly out on the tank
you flew in on". The theory being that takeoff is not the time to "test" whether a tank you just switched to is blocked, the fuel valve malfunctioned, a tank is empty (cuz you forgot to check it), a tank you just switched to is full of water, etc. If you switch just prior to takeoff or just prior to runup, you have about 1 or 2 minutes of flight until the carb bowl and gascolator empties in a small Piper. Then, you get an empty fuel line or whatever was in the other tank. Usually, you are not in a very good position to deal with no fuel or contaminated fuel at the end of that short time period. Opinions on this one vary. I leave the valve where it is and switch after burning off about 5 gallons (climb to 2500' plus 10 minutes of cruise). Good Luck, Mike Journeyman wrote: In article .com, Tony wrote: have been in the owner's manual that said something like "switch to most full fuel tank" before takeoff, and after run-up. That's the worst possible time to change tanks. Ack. Have to agree with you, but I think you misread the instructions. I start and taxi on one tank, then run up on the other with takeoff on the same tank as the runup. That way, you know you have good fuel in both tanks. Morris __________________________________________________ _____________________________ Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com The Worlds Uncensored News Source |
"Mike Spera" wrote in message ...
Opinions on this one vary. I leave the valve where it is and switch after burning off about 5 gallons (climb to 2500' plus 10 minutes of cruise). For my first tank switch, I like to be over something that I wouldn't mind landing on or at a high enough altitude that having the engine stop would not be too exciting of an experience... Subsequent switches, I'm not as paranoid about... |
Grumman-581 wrote:
"Mike Spera" wrote in message ... Opinions on this one vary. I leave the valve where it is and switch after burning off about 5 gallons (climb to 2500' plus 10 minutes of cruise). For my first tank switch, I like to be over something that I wouldn't mind landing on or at a high enough altitude that having the engine stop would not be too exciting of an experience... Subsequent switches, I'm not as paranoid about... I took off from Marsh Harbour once in a Cherokee Six with the fuel selector on the tank that I'd arrived on. About two minutes later I was gliding back down waiting for the fuel tank I should have been on in the first place to start supplying fuel to the engine. Stupid. The Cherokee Six had four fuel tanks and lots of opportunities to run tanks dry. I take off on the fullest tank now, no matter which one I arrived on. As for where I switch tanks, it's more when than where. I don't particularly care where I am as long as I have sky under me. Cherokees aren't known for their superior glide characteristics.... or quick restarts. C-210s... now they restart quick! They all should do as well. -- Mortimer Schnerd, RN VE |
On Thu, 14 Apr 2005 12:14:17 GMT, "Grumman-581"
wrote: "Mike Spera" wrote in message ... Opinions on this one vary. I leave the valve where it is and switch after burning off about 5 gallons (climb to 2500' plus 10 minutes of cruise). For my first tank switch, I like to be over something that I wouldn't mind landing on or at a high enough altitude that having the engine stop would not be too exciting of an experience... Subsequent switches, I'm not as paranoid about... I takeoff on the tank I did the runup on. |
Mike Spera wrote:
One well known aviation university teaches you to "fly out on the tank you flew in on". I take off on "both." If either one works, I have gas. George Patterson There's plenty of room for all of God's creatures. Right next to the mashed potatoes. |
![]() "George Patterson" wrote in message news:beF7e.5519$4v3.1682@trndny03... Mike Spera wrote: One well known aviation university teaches you to "fly out on the tank you flew in on". I take off on "both." If either one works, I have gas. George Patterson There's plenty of room for all of God's creatures. Right next to the mashed potatoes. Some of us don't have that option. |
George Patterson wrote:
Mike Spera wrote: One well known aviation university teaches you to "fly out on the tank you flew in on". I take off on "both." If either one works, I have gas. PA-32s and C-402s lack that ability, among many others. In fact, on the C-402 if you chose to take off on the aux tanks first, you just blew fuel overboard. You had to create room in the mains for the fuel. The mains fed the engines. The aux fed the mains. Therefore you take off on the mains and fly for an hour. THEN you switch to the aux and fly for another 35 minutes or so, then switch back to the mains for the rest of the flight. Both? Must be talking about Cessna. -- Mortimer Schnerd, RN VE |
Mortimer Schnerd, RN wrote:
Both? Must be talking about Cessna. Maule. George Patterson There's plenty of room for all of God's creatures. Right next to the mashed potatoes. |
First Two Aero Lessons This Weekend (Long) | David B. Cole | Aerobatics | 12 | December 3rd 04 01:18 AM |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
Flight test update - long | nauga | Home Built | 1 | June 5th 04 03:09 AM |
SWRFI Pirep.. (long) | Dave S | Home Built | 20 | May 21st 04 03:02 PM |
Across Nevada and Part Way Back (long) | Marry Daniel or David Grah | Soaring | 18 | July 30th 03 08:52 PM |
