Mortimer Schnerd, RN wrote:
Both? Must be talking about Cessna. Navions only has a "ON (both) - OFF" selector (unless they have optional tanks). |
Well, their point is that, by changing from the setting you flew in on,
you may introduce the possibility of failure. Namely, if you fly in on the left tank and take off on both, the water in the right tank may ruin your day. Also, if the fuel selector malfunctions, you may be between settings and have "neither". I am not familiar with the specific designs of these valves, so this may not be an issue. Anyway, many of us dont't have a "both" setting. So, that introduces other possible failures like the tank you switched to is empty. Thanks for pointing out the "both" setting. As I said, some of us don't have one. As I said, opinions on this one vary greatly. Good luck Mike Mike Spera wrote: One well known aviation university teaches you to "fly out on the tank you flew in on". I take off on "both." If either one works, I have gas. __________________________________________________ _____________________________ Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com The Worlds Uncensored News Source |
"Mike Spera" wrote in message
... Well, their point is that, by changing from the setting you flew in on, you may introduce the possibility of failure. Namely, if you fly in on the left tank and take off on both, the water in the right tank may ruin your day. True. But how often does an engine fail due to fuel exhaustion, versus fuel contamination? Seems like procedure should take into account the most common failure mode. Also, consider that on most flights, you would have had a chance to use both tanks. By the time of your second departure, you should know whether either tank is contaminated. A corallary to all of the above is that if the flight was too short to check both tanks, it was probably also too short for a fuel shortage to be a problem. So, one could rationally worry more about contamination after a second departure following a very short flight. Also, if the fuel selector malfunctions, you may be between settings and have "neither". Better for that to happen on the ground than in the air, right? Pete |
George Patterson wrote:
Mike Spera wrote: One well known aviation university teaches you to "fly out on the tank you flew in on". I take off on "both." If either one works, I have gas. Doesn't that also mean that if one of the tanks is contaminated, you're going to draw the contamination into the engine, with no option of switching to a good tank (or, at least, you don't know which tank to switch to). |
Easy for you, George. The Archer doesn't have that position on the valve
:-( -- Bob (Chief Pilot, White Knuckle Airways) "George Patterson" wrote in message news:beF7e.5519$4v3.1682@trndny03... Mike Spera wrote: One well known aviation university teaches you to "fly out on the tank you flew in on". I take off on "both." If either one works, I have gas. George Patterson There's plenty of room for all of God's creatures. Right next to the mashed potatoes. |
One helpful point:
When changing fuel tanks, keep your hand on the fuel selector valve for about 30 more seconds and monitor the fuel pressure gauge. If the fuel pressure drops or the engine quits your hand will already be on the valve to re-select the good tank. In my childhood I flew a Beaver amphibian out of King Salmon. The procedure to maximize the available fuel was to run the tanks dry from the rear to the front. A beaver has fuel in the belly in two tanks (a bad place and most Beaver crashes involve fire.) I could rest my hand on the fuel selector valve and watch the fuel pressure gauge. Once the fuel pressure just started to drop the tank could be switched quickly without the engine quitting. Karl "Curator" N185KG |
Mike Spera wrote in message ...
One well known aviation university teaches you to "fly out on the tank you flew in on". The theory being that takeoff is not the time to "test" whether a tank you just switched to is blocked, the fuel valve malfunctioned, a tank is empty (cuz you forgot to check it), a tank you just switched to is full of water, etc. Pretty poor theory. It's a haphazardway of avoiding actually managing your fuel. I'm more of a measure, calculate type of guy myself. I keep a log of the tanks in flight in my Mooney (I don't have a "both" selector). I also don't buy into the "fill the tanks before take off" B.S. You should know how much fuel you need and how much extra you'll need. I just don't see putting 8 hours of fuel in my Mooney and pushing around like an over stuffed whale. All this reminds me of the Bonanza pilot who declared a fuel emergency only to discover he had another 3 hours of fuel. He always put 5 hours in it, but never let it go below 2 hours, he burned 12gal/hr but caluclated it as 15 gal/hr, etc, etc. All this "extra safety buffer" just meant he had NO idea how much fuel he had. -Robert, CFI |
![]() "Robert M. Gary" wrote in message om... Mike Spera wrote in message ... One well known aviation university teaches you to "fly out on the tank you flew in on". The theory being that takeoff is not the time to "test" whether a tank you just switched to is blocked, the fuel valve malfunctioned, a tank is empty (cuz you forgot to check it), a tank you just switched to is full of water, etc. Pretty poor theory. It's a haphazardway of avoiding actually managing your fuel. I'm more of a measure, calculate type of guy myself. I keep a log of the tanks in flight in my Mooney (I don't have a "both" selector). I also don't buy into the "fill the tanks before take off" B.S. You should know how much fuel you need and how much extra you'll need. I just don't see putting 8 hours of fuel in my Mooney and pushing around like an over stuffed whale. All this reminds me of the Bonanza pilot who declared a fuel emergency only to discover he had another 3 hours of fuel. He always put 5 hours in it, but never let it go below 2 hours, he burned 12gal/hr but caluclated it as 15 gal/hr, etc, etc. All this "extra safety buffer" just meant he had NO idea how much fuel he had. http://www.avweb.com/news/columns/182044-1.html August 9, 1998 Pelican's Perch #7: Run That Fuel Tank Dry! AVweb's John Deakin takes aim at yet another OWT (Old Wive's Tale). While running a fuel tank dry in your recip powered plane may serve to increase your heart rate, John explains why it's not such a bad thing at all, and it is probably a really good idea for most of us. In fact, John explains why it's one of the first things you ought to do with a new plane and how it could save your life someday. |
Matt Barrow wrote:
AVweb's John Deakin takes aim at yet another OWT (Old Wive's Tale). While running a fuel tank dry in your recip powered plane may serve to increase your heart rate, John explains why it's not such a bad thing at all, and it is probably a really good idea for most of us. In fact, John explains why it's one of the first things you ought to do with a new plane and how it could save your life someday. Flying the old Cherokee Six with four fuel tanks, you'd end up with almost 10 gallons unusable if you didn't run a tank dry occasionally. I tried to never let it happen with passengers on board. Screwed up once though... probably scared the hell out of them though nobody said anything about it once I'd explained what had happened. Mea culpa. -- Mortimer Schnerd, RN VE |
![]() "Mortimer Schnerd, RN" wrote in message . com... Matt Barrow wrote: AVweb's John Deakin takes aim at yet another OWT (Old Wive's Tale). While running a fuel tank dry in your recip powered plane may serve to increase your heart rate, John explains why it's not such a bad thing at all, and it is probably a really good idea for most of us. In fact, John explains why it's one of the first things you ought to do with a new plane and how it could save your life someday. Flying the old Cherokee Six with four fuel tanks, you'd end up with almost 10 gallons unusable if you didn't run a tank dry occasionally. I tried to never let it happen with passengers on board. Screwed up once though... probably scared the hell out of them though nobody said anything about it once I'd explained what had happened. Mea culpa. -- Mortimer Schnerd, RN I remember one time in a light twin. I decided to run the auxilliary tanks dry before returning to the mains so that I would have all of my remaining fuel in the mains for the approach and landing. I flew an hour on the mains to get some dump space for the overflow from the injectors and then switched to the aux tanks. After churning along on the auxs for some little time the right engine quit. As I was reaching for the fuel selector to switch it back to the main the left engine quit. The sudden total cessation of engine noise in midtrip got my passengers rather upset until I got them both making appropriate noises again and explained to them what had happened and why I did it that way. :-) Mea Maxima Culpa ... Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) VE |
First Two Aero Lessons This Weekend (Long) | David B. Cole | Aerobatics | 12 | December 3rd 04 01:18 AM |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
Flight test update - long | nauga | Home Built | 1 | June 5th 04 03:09 AM |
SWRFI Pirep.. (long) | Dave S | Home Built | 20 | May 21st 04 03:02 PM |
Across Nevada and Part Way Back (long) | Marry Daniel or David Grah | Soaring | 18 | July 30th 03 08:52 PM |
