Thomas Borchert wrote:
Andrew, The DG is merely providing HEADING information (ie. the setting of the bug). And that is autopilot specific. Apparently. We had to get a certain model of Sigmatek DG for it to work with the STEC-50. I was told by a person that installs STECs for us that the STEC can be "configured" to work with different DGs. He didn't say "all different", though. We're upgrading from ARC units: Navomatic 300As. According to him, we merely specify this when we purchase a new STEC. Also, we now switched to another model, which also delivers bootstrap heading info like a remote compass would. We need that for the WX-500 we installed. Ah, this is something I didn't understand. What is "bootstrap heading info", and how does the WX-500 (whatever that is {8^) use it? We've a strikefinder in our aircraft. Does that mean we need "bootstrap heading info"? - Andrew |
Andrew,
Ah, this is something I didn't understand. What is "bootstrap heading info", and how does the WX-500 (whatever that is {8^) use it? We've a strikefinder in our aircraft. Does that mean we need "bootstrap heading info"? Depends on the model of Strikefinder. In order for the the Strikefinder to orient its display correctly in relation to where the aircreaft's nose is pointing, it needs some kind of heading info. The WX-500 (remote "Strikefinder" with no display, working with Garmin 430 and other displays) uses the heading info from a "bootstrap compass" as it is normally found in HSI installations. This compass sends out a compass signal to auto-align the HSI. It can also be used to align the Strikefinder displays. Even if the WX-500 is displaying on a GPS, it cannot use GPS derived heading signals to align itself - the reason being that the GPS doesn't know your heading, only your track. If you don't already have an HSI, installing one (including the bootstrap compass) is really expensive. The "cheap way" to get a bootstrap signal without actually having a bootstrap compass is to have a DG with a bootstrap signal output (as made by Sigmatek). Of course, that signal is not derived from a compass but rather from the manual setting of the DG - if you don't align it with the compass manually and it precesses out of the real heading, so will the bootstrap signal. Hope I'm clear ;-) -- Thomas Borchert (EDDH) |
Hope I'm clear ;-) Very! I appreciate the explanation. - Andrew |
