I've picked my plane
Old April 15th 05, 05:30 AM
AINut
Hmph! If you GAVE me the Maverick, I still probably couldn't afford the
fuel .
John E. Carty wrote:
I'd like the same financing options for a new Maverick jet, though the cost
is roughly 2 million :-)
Max Cruise - 412 kts.
Max Range - 1,508 nm.
Ceiling - 31,000 ft.
Rate of Climb - 3,000 ft./min
Rate of Climb (Single Engine) - 1,300 ft./min.
Take-off Distance (Std. Gross Wgt.) - 1,800 ft.
Landing Distance (flaps) - 1,900 ft.
Stall Speed (Gross Wgt.) - 78 kts.
Stall Speed (Empty Wgt.) - 70 kts.
Empty Weight - 2,900 lbs.
Gross Weight - 5,800 lbs.
Useful Load - 2,900 lbs.
Length - 28.5 ft.
Wingspan - 33.25 ft.
Height - 9 ft.
Wing Area - 144.6 sq. ft.
Wing Loading - 36 lbs./sq.ft.
Fuel Capacity - 380 USG
Engines ( Fanjets - 1,100 lbs. thrust each ) - (2) Williams International
FJ33-4
Cabin Size - 52" wide, 43" high, 104" long
Cabin Seating - 5 adults
Baggage Area - 35 cubic ft.
Air Frame - Pre-preg Carbon/Fiber/Nomex
"Carl / KG6YKL" wrote in message
news:3HG7e.46637$lz2.28467@fed1read07...
Okay, here is my aircraft. Now, does anybody have a 0% APR loan with 120
mos differed payments?
MX-7-180C Star Rocket - Taildragger with 76” Hartzell Constant Speed Prop
and Spring Aluminum Gear. Lycoming 0-360 180 hp engine with the enhanced
performance of a constant speed propeller.
$136,230.00 Base Price w/ standard equipment
$800 Paint Option: Gull Gray Base 2015, Midnight Blue
Primary Stripe 2013, Dark Charcoal Velour 3703-44
$2125.00 Complete Berkshire Elephant leather seat and side
panel centers and door pockets., including the sides,
back and pockets on pilot and copilot seats. Complete
leather passenger seats.
$300 Lowes Grey Instrument Panel
$500 28 Volt System Upgrade for IFR Packages
$10,233.00 S-Tec System 50 Autopilot
$995 Bose Aviation Headset X (Triport Technology - ANR)
$65 Bose Install Harness (each headset)
$221 Tires and Tubes 8.50x6 - Tailwheel Models Only
$200 Clear Windshield
$686 Observation Doors
$686 Observation Windows
$2900 Super Sky Light w/ Cover
$627 Swing-Out Window - Copilot
$700 Auxiliary Fuel Tanks (85 gallons total)
$390 Dynamic Balancing for Propeller
$259 Grab Handles on Fuselage (L/R)
$450 Ground Service Plug
$210 Hour Meter
$251 Landing Light - Right Wing
$1834 Shoulder Harness Set (4 point) (Pilot and Copilot)
$161,722.00 Sub Total
$12,533.4550 Tax
$174,255.4550 GRAND TOTAL
Sorry just having fun.
Carl
I need some advice on buying my own plane BEFORE training... Anthony L Piloting 6 April 22nd 04 11:13 PM
Navy sues man for plane he recovered in swamp marc Owning 6 March 29th 04 12:06 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 07:27 AM
