![]() "Stefan" wrote in message ... Of course it could. Whether it would make sense is a different question. How could it be any other way? |
Steven P. McNicoll wrote:
How could it be any other way? Just a few examples: It could be QNH everywhere (requires defined QNH regions). It could be GPS altitude (would even simplify things a lot, but requires all aircraft to be expensively equipped). Heck, it could even be radar altitude everywhere, of course compensated for ground elevation. As I said, whether it would make sense or even be practical is a different question, but there are a lot of solutions which are thinkable. Stefan |
![]() "Stefan" wrote in message ... Just a few examples: It could be QNH everywhere (requires defined QNH regions). If it's QNH everywhere there's no transition altitude. It could be GPS altitude (would even simplify things a lot, but requires all aircraft to be expensively equipped). Heck, it could even be radar altitude everywhere, of course compensated for ground elevation. As I said, whether it would make sense or even be practical is a different question, but there are a lot of solutions which are thinkable. How does one set the barometric pressure for GPS altitude or radar altitude? |
If it's QNH everywhere there's no transition altitude. .... Right. As I understood, you said: This is the only way to set the altimeter. I answered: No, there are a myriade of ways to do it, from which one was chosen, probably for good reasons. Maybe I misunderstood your first statement. Stefan |
![]() "Stefan" wrote in message ... Right. As I understood, you said: This is the only way to set the altimeter. I answered: No, there are a myriade of ways to do it, from which one was chosen, probably for good reasons. Maybe I misunderstood your first statement. I was responding to Cockpit Colin's message on how things are done in New Zealand. He said a correction for barometric pressure is applied only below the transition altitude, and that there's no need for any correction for flight levels. He assumed it's the same way in the US. I said it's the same way everywhere, as the definitions of "transition altitude" and "flight level" require it to be that way. |
![]() "Steven P. McNicoll" wrote in message ink.net... "Stefan" wrote in message ... Right. As I understood, you said: This is the only way to set the altimeter. I answered: No, there are a myriade of ways to do it, from which one was chosen, probably for good reasons. Maybe I misunderstood your first statement. I was responding to Cockpit Colin's message on how things are done in New Zealand. He said a correction for barometric pressure is applied only below the transition altitude, and that there's no need for any correction for flight levels. He assumed it's the same way in the US. I said it's the same way everywhere, as the definitions of "transition altitude" and "flight level" require it to be that way. For example in the UK, transition level tends to be 3000 ft except around the major airports where it can be as high as 6000ft. This means that the lowest FL is usually FL035. The normal practice is to take off on the airfieldQNH, and then if on a cross country trip, readjust the setting to the Regional QNH. This is the lowest forecast QNH for the respective region. On arrival at an airfield we set QFE which gives zero elevation when landed. Only IFR traffic is obliged to use flight levels above 3000ft or the transition altitude (in fact one of the definitions of IFR is the use of flight levels). VFR traffic can use then if they want but then should follow Instrument flight Rules. cb |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Pressure Altitude and Terminology | Icebound | Piloting | 0 | November 27th 04 09:14 PM |
GPS Altitude with WAAS | Phil Verghese | Instrument Flight Rules | 42 | October 5th 03 12:39 AM |
GPS Altitude with WAAS | Phil Verghese | Piloting | 38 | October 5th 03 12:39 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
