Being asked to "verify direct XXX"
Old April 16th 05, 04:14 PM
G. Sylvester
One thing I've quickly picked up on is that ATC pretty much expects
everybody to be able to navigate direct.
expects is the keyword. It isn't required and often I get
told "fly heading XXX, when able direct YYYY."
If you tell them you've got a VFR GPS (in your remarks), they'll happily
give you direct clearances
they'll happily give you direct JFK to SFO. It's up to you to
do it. VFR GPS means nothing to them since you are still a /A or /U.
(I don't
keep the DB current and there's certainly no reason at all they should
expect that I do).
no one except the PIC checks to make sure a plane's panel-mounted
database is current. ATC sure doesn't.
What you are saying is the equivalent of a /G airplane with out
of date databases. You are NOT legal to fly IFR with out of
date databases (there are exceptions but in general, the answer
is no).
Not to be Mr. Police Officer or mean about it.....you said you are
newly minted IFR pilot when did you
take your written test? Did you study the Gleim. there are only
about 10 questions on GPS including a couple on the exact
thing you are asking about. I took mine not too long ago (my
checkride is coming up)
I've been
asked to "verify direct XXX" when I'm off course by a quite small amount
- no more than 10 degrees.
Course probably doesn't matter (a guess). If you want to fly S-turns
down a victor airway, they'll probably think you're drunk but
as long as you stay with the airway you are probably legal. If
you are really S-turning it, they might say something.
The other reason they might ask is if one controller says "cleared
direct XXX, contact Socal on 134.65." When you contact
the next controller you should say "Airbus 12345, 2000, direct XXX."
Just like if they give you a heading and are handed off, you should
tell them your newly assigned heading. Don't assume anything. A
friend of a friend was given a heading, passed to another controller,
10 minutes later he flew into a mountain. Controller probably was
dazing off as it was late at night and didn't realize the pilot
was on a heading and not on an airway with a MEA.
I've vowed to put a stop to this, and I have realized that I should
probably pay even closer attention to my heading.
just trim out the plane perfectly including rudder trim so your
TC is perfectly level. It's just like your elevator trim. Get
them perfect and the plane will stay straight.
My two-part question is 1) Should I be concerned at all by being asked
such a question by ATC?
concerned, no. But of course you'll wonder. Just like when I
flew into LAS in an Archer. I made a nice radio call "Cherokee XXXXX,
6000, information bravo." They came back and asked if I had information
bravo. This happened on 2 controllers no less. I figure they're used
to dealing with 'real' airplanes that I can only dream of flying.
And 2) Just _what_ is the IFR "heading
tolerance", anyway??
they probably couldn't care less about headings as long as you are where
you are. They might ask you so they know the winds aloft so when they
provide RV the airplane goes where they intend to go.
Gerald Sylvester
Old April 16th 05, 04:22 PM
Steven P. McNicoll
"G. Sylvester" wrote in message
m...
do it.
Direct to SFO from JFK? Unlikely.
Old April 16th 05, 04:30 PM
Paul Folbrecht
expect that I do).
No kidding. My point was that, being that it's a _VFR_ GPS and that I
did _not_ file /G, I am under no regulatory requirement at all to keep
it current.
is no).
Yes, there are exceptions for enroute ops, but that's another matter.
I took it it November and got a 98%. I am aware of the regs governing
IFR GPS use. No offense, but you missed my point.
Old April 17th 05, 12:33 AM
Newps
is no).
Not true. It depends on the individual GPS. RTFM.
Old April 17th 05, 08:48 AM
G. Sylvester
(there are exceptions but in general, the answer is no).
There are exceptions.....it depends......
ummm, we're saying the same thing, aren't we?
Agreed, RTFM always applies hence the indefinite statements.
Gerald
Old April 17th 05, 03:39 PM
Newps
G. Sylvester wrote:
(there are exceptions but in general, the answer is no). Not true. It
There is no FAR that says the database must be current. The law is
whatever the manufacturer says it is in the manual. It's just the
opposite of what you said, most of the time an expired database is OK.
Especially for terminal and enroute ops. Only for approaches is it
pretty standard that the databse be current.
Old April 18th 05, 06:31 PM
Dave Butler
To pick a nit: actually it's whatever it says in the Pilot's Operating Handbook
Supplement. The manufacturer supplies a boilerplate suggested wording for the
SPOH and *usually* that's what gets sent in to Oklahoma City for the approval,
which is approved (or not) for each individual aircraft. I don't think there's
anything preventing someone sending in different wording, and if it gets
approved, it's approved. I don't know whether that's actually ever been done.
Old April 16th 05, 04:48 PM
Paul Folbrecht
I haven't been doing that. That right there could (and probably does)
explain 2 of the 3 cases I can recall of being asked this question.
The last one, the one where I know I was a bit off course, was the
aforementioned occurance where we lost vacuum just moments later..
though actually, honestly, I don't really think that was the culprit
(though I normally do fly by the DG and VOR head and not the GPS ground
track).
This was my first time left seat in this particular airplane as well,
and I was studying an approach plate (no excuse, I know).
And, as I noted, not on this or any other time did I detect annoyance
from the controller.. in fact she (Chicago center) was very polite and
chipper.
I'm sure (well, 99% sure) I have nothing to worry about.
Rudder trim? You mean the little tab on the back of the rudder? :-) I
fly a '79 C-152, and, no, it does not fly completely hands-off level.
Few of them do!
Another thing I've wondered about is how often the pilot is told when
they'll be filing paperwork. It seems the norm is the dreaded "call
this number on landing" but I know that they don't have to do that. If
a controller was really peeved at you, he might take perverse pleasure
in making sure you didn't know what was coming.
Before somebody replies, I know that controllers are not out to violate
pilots and are almost all good guys & gals.
And 2) Just _what_ is the IFR "heading tolerance", anyway??
I should have stated the question as "course-deviation tolerance".
Old April 16th 05, 11:15 PM
G. Sylvester
from my very limited experience the first controller will
say "fly heading XXX and intercept V25..." Usually the next
controller all you have to say is "heading XXX" and can leave
off the intercept V25 as that will clue them in enough.
chipper.
it's amazing how you can really see personalities and/or moods over the
air.
Few of them do!
I didn't even know a C152 flies. ;-) j/k. The other way to do it
is just crack open a door. hehehe.
I've heard that it takes number of things. 1, affect safety of flight.
2, not apologize and sound like you did everything right and they
are wrong. 3, they are in a bad mood. I'll tell you when it happens
to me although I don't exactly plan on it. ;-)
well the other day I heard a pilot ask the SQL Tower for the controllers
name. She got the initials. I guess it can work both ways.
agreed. They've help my butt more times than they've given me a hard
time.
I've never heard of any but that doesn't mean much. I presume as
long as you are within the +/-4nm of the airway they don't care.
You violate their aircraft separation and then they might 'violate'
you though.
Maybe the best thing to do is don't mention the VFR GPS as it implies
that you are /G.
Gerald
Clearance: Direct to airport with /U Judah Instrument Flight Rules 8 February 27th 04 06:02 PM
Direct To a waypoint in flightplan on Garmin 430 Andrew Gideon Instrument Flight Rules 21 February 18th 04 01:31 AM
"Direct when able" Mitchell Gossman Instrument Flight Rules 18 October 21st 03 01:19 AM
Filing direct John Harper Instrument Flight Rules 10 October 9th 03 10:23 AM
Don Brown and lat-long Bob Gardner Instrument Flight Rules 30 September 29th 03 03:24 AM
