Pentrating Towering Cumulus Clouds
Old April 18th 05, 02:54 PM
Icebound
"Mike Rapoport" wrote in message
ink.net...
"Ron McKinnon" wrote in message
newscD8e.1052899$8l.772250@pd7tw1no...
nk.net...
TCU have, as you would expect, characteristics between CU and CB clouds.
All three can be thought as different stages of the same think, a cloud
pruduced by convection. Obviously three seconds before a TCU starts
producing lightning and becomes a CB, it is going to a lot like a
thunderstorm inside.
A minor point: A TCU will not 'produce lightning to become a CB'. If
it produces lightning it *is* a CB, and has been for some time, but it
is
not the production of lightning that makes it a CB.
That is what I said ( I think) A thunderstorm becomes a thunderstorm when
the thunder starts. Three seconds before the first lightning, it is still
a TCU.
Well, no. A TCU becomes a cumulo-nimbus when the rounded califlower-like
shape of the TCU begins to top off with a wispy fibrous top, often
stretching downwind like an anvil. This is ice crystals forming at the very
top of the cloud.
That is the classic definition used by weather services. Observers will not
call it a CB if they continue to see the hard-edged form at the tops.... not
until they see the formation of the wispy fibrous top. However, once
lightning, or hail, or funnel-clouds are observed, the observer will almost
surely class it a CB, regardless.
It is not necessary that a CB produce lightning, nor hail, nor heavy
precipitation, nor Mammae, Funnel Clouds, Tornados or Waterspouts.
It can do none of these things and still be a CB. But if any of these
things happen it is necessarily a CB.
I am not sure what you are saying here, If it doesn't produce lightning it
isn't a thunderstorm (CB) so I would say that it is nessesary for a CB to
produce lightning.
The production of the ice-crystals at the top will normally be accompanied
by lightning, but ever if it is not, it would still be called a CB if the
fibrous ice-crystal anvil-shaped top exists.
Conversely, when a TCU is only slightly taller than a CU, it is going to
be more like a CU inside. There is a relationship between the vertical
height of a convective cloud and turbulence but it is not absolute. I
have never heard of large hail coming from anything other than a big CB.
If it hails, it's a CB, by definition. A TCU can produce snow
pellets, however (and ice pellets, I think (it's been a while)),
This is the first time that I have heard that hail defines a thunderstorm.
A thunderstorm is defined by lightning (and therefore thunder). Hail is
produced by updrafts in a cloud through the freezing level allowing frozen
precipitation to remain aloft and grow. I don't see why this couldn't
happen without lightning. I was hailed upon yesterday and there was no
thunder.
Hail (hard "real" hail, not the soft stuff in some cold-weather cumulus)
.... Hail does not define a thunderstorm, but because the conditions required
for it are typically exactly the same that produce lightning and the rest of
the CB symptoms, you will be hard pressed to find an observer who will not
call a hailing cloud a CB, just because he hasn't seen lightning or heard
thunder.
Old April 18th 05, 03:56 PM
Mike Rapoport
"Icebound" wrote in message
ink.net...
nk.net...
clouds. All three can be thought as different stages of the same think,
a cloud pruduced by convection. Obviously three seconds before a TCU
starts producing lightning and becomes a CB, it is going to a lot like
a thunderstorm inside.
is
when the thunder starts. Three seconds before the first lightning, it is
still a TCU.
very top of the cloud.
not call it a CB if they continue to see the hard-edged form at the
tops.... not until they see the formation of the wispy fibrous top.
However, once lightning, or hail, or funnel-clouds are observed, the
observer will almost surely class it a CB, regardless.
Do you have a source of this definition? I can't find one but while
looking, I found several sites with pictures of CBs that don't all have the
wispy tops
Here is one: http://www.chitambo.com/clouds/cloudshtml/calvus.html
it isn't a thunderstorm (CB) so I would say that it is nessesary for a CB
to produce lightning.
to be more like a CU inside. There is a relationship between the
vertical height of a convective cloud and turbulence but it is not
absolute. I have never heard of large hail coming from anything other
than a big CB.
thunderstorm. A thunderstorm is defined by lightning (and therefore
thunder). Hail is produced by updrafts in a cloud through the freezing
level allowing frozen precipitation to remain aloft and grow. I don't
see why this couldn't happen without lightning. I was hailed upon
yesterday and there was no thunder.
required for it are typically exactly the same that produce lightning and
the rest of the CB symptoms, you will be hard pressed to find an observer
who will not call a hailing cloud a CB, just because he hasn't seen
lightning or heard thunder.
I agree that most observers would call a hailing cloud a CB but the hail
that fell on me yesterday was pea sized and mostly clear yet fell from a
cloud that had a top of perhaps 15,000' and was not producing thunder.
Mike
MU-2
Old April 18th 05, 07:35 PM
Icebound
link.net...
ink.net...
nk.net...
think, a cloud pruduced by convection. Obviously three seconds before
a TCU starts producing lightning and becomes a CB, it is going to a
lot like a thunderstorm inside.
is
is still a TCU.
the wispy tops
I chose the definition from the Canadian Manual of Observation which defines
CB:
DEFINITIONS OF CLOUDS
Cumulonimbus: Heavy and dense cloud with
aconsiderable vertical extent, in the form of
amountain or huge tower. At least part of its
upper portion is usually smooth, or fibrous or
striated, and nearly always flattened; this part
often spreads out in the shape of an anvil or vast
plume.
But some more insight can be obtained from the World Met Organization
code-table:
http://badc.nerc.ac.uk/data/surface/code.html (Low cloud type)
Code 3 allows a CB to be defined without the "clearly fibrous" tops, but
which must "at least partially, lack sharp outlines", ....which shows the
the icing of the tops has begun.
Code 9 CB requires the "clearly fibrous" top.
The key is that to meet the classic definition of CB, the icing of the tops
(and hence the smoother fibrous shape)... has at the very least, begun to
form.
CB to produce lightning.
accompanied by lightning, but ever if it is not, it would still be called
a CB if the fibrous ice-crystal anvil-shaped top exists.
than a big CB.
Where, geographically? And did it fall on you on the ground, or did you
encounter it in flight? And how was the cloud top determined.
Old April 18th 05, 07:51 PM
Mike Rapoport
Snip
defines CB:
plume.
code-table:
tops (and hence the smoother fibrous shape)... has at the very least,
begun to form.
Thanks! I have been using "CB" and "thunderstrom" interchangably, perhaps
this is not strictly true.
North Idaho. I was on the ground (bicycling in hail of all things) The
tops I estimate at 10-12k based on my experience flying in the area (I am
confident that I could easily top them VFR). I gave 15,000' as a very
conservative estimate, I have a high degree of confidence that they were
lower. The highest terrain around is 6200' and this was sticking to the
bottom of the cloud so the vertical height was about 6000'.
Mike
MU-2
Old April 18th 05, 10:37 PM
Icebound
ink.net...
Ron has correctly described the difference. CB is a cloud, thunderstorm is
a condition reported only when thunder is heard or lightning seen. Being
the "thunderstorm cloud", the terms CB and thunderstorm are often used
interchangeably in generic descriptions, but we can and should be more
precise.
I don't pretend to be an expert in mountain meteorology. But because the
direction of the wind plays such an overwhelming part in the lift equation,
it would be my guess that a TCU was developing, the vertical currents were
there, the coalescence of water was occurring and freezing. But in a
typical flatland TCU/CB this build-up keeps going for perhaps up to couple
of hours and great height, here I would guess that a wind change killed the
vertical currents rather quickly... and the precipitation, no longer
supported, simply fell out.
My guess, don't know.
Old April 18th 05, 08:53 PM
Ron McKinnon
ink.net...
nk.net...
is
still a TCU.
than a big CB.
the 'soft stuff' -- you're probably talking about snow-pellets, which can
be produced by TCUs (as well as CBs)
An observer will of course report a hailing cloud as a CB irrespective
of whether thunder or lightning has been observed. But this is because
thunder or lightning are not necessary phenomena for a CB, and it is
necessarily a CB if it produces hail.
Though reporting the clould as a CB, such observer would not report
a thunderstorm, unless he also hears thunder.
Cumulus releases version 1.2.1 André Somers Soaring 0 March 2nd 05 09:58 PM
Four States and the Grand Canyon Mary Daniel or David Grah Soaring 6 December 6th 04 10:36 AM
[Announcement] Cumulus 1.1 released André Somers Soaring 0 January 24th 04 11:59 AM
Blue Clouds Mark Cherry Simulators 0 September 21st 03 12:57 PM
Across Nevada and Part Way Back (long) Marry Daniel or David Grah Soaring 18 July 30th 03 08:52 PM
