![]() "Icebound" wrote in message ... "Mike Rapoport" wrote in message ink.net... "Ron McKinnon" wrote in message news ![]() "Mike Rapoport" wrote in message nk.net... TCU have, as you would expect, characteristics between CU and CB clouds. All three can be thought as different stages of the same think, a cloud pruduced by convection. Obviously three seconds before a TCU starts producing lightning and becomes a CB, it is going to a lot like a thunderstorm inside. A minor point: A TCU will not 'produce lightning to become a CB'. If it produces lightning it *is* a CB, and has been for some time, but it is not the production of lightning that makes it a CB. That is what I said ( I think) A thunderstorm becomes a thunderstorm when the thunder starts. Three seconds before the first lightning, it is still a TCU. Well, no. A TCU becomes a cumulo-nimbus when the rounded califlower-like shape of the TCU begins to top off with a wispy fibrous top, often stretching downwind like an anvil. This is ice crystals forming at the very top of the cloud. That is the classic definition used by weather services. Observers will not call it a CB if they continue to see the hard-edged form at the tops.... not until they see the formation of the wispy fibrous top. However, once lightning, or hail, or funnel-clouds are observed, the observer will almost surely class it a CB, regardless. Do you have a source of this definition? I can't find one but while looking, I found several sites with pictures of CBs that don't all have the wispy tops Here is one: http://www.chitambo.com/clouds/cloudshtml/calvus.html It is not necessary that a CB produce lightning, nor hail, nor heavy precipitation, nor Mammae, Funnel Clouds, Tornados or Waterspouts. It can do none of these things and still be a CB. But if any of these things happen it is necessarily a CB. I am not sure what you are saying here, If it doesn't produce lightning it isn't a thunderstorm (CB) so I would say that it is nessesary for a CB to produce lightning. The production of the ice-crystals at the top will normally be accompanied by lightning, but ever if it is not, it would still be called a CB if the fibrous ice-crystal anvil-shaped top exists. Conversely, when a TCU is only slightly taller than a CU, it is going to be more like a CU inside. There is a relationship between the vertical height of a convective cloud and turbulence but it is not absolute. I have never heard of large hail coming from anything other than a big CB. If it hails, it's a CB, by definition. A TCU can produce snow pellets, however (and ice pellets, I think (it's been a while)), This is the first time that I have heard that hail defines a thunderstorm. A thunderstorm is defined by lightning (and therefore thunder). Hail is produced by updrafts in a cloud through the freezing level allowing frozen precipitation to remain aloft and grow. I don't see why this couldn't happen without lightning. I was hailed upon yesterday and there was no thunder. Hail (hard "real" hail, not the soft stuff in some cold-weather cumulus) ... Hail does not define a thunderstorm, but because the conditions required for it are typically exactly the same that produce lightning and the rest of the CB symptoms, you will be hard pressed to find an observer who will not call a hailing cloud a CB, just because he hasn't seen lightning or heard thunder. I agree that most observers would call a hailing cloud a CB but the hail that fell on me yesterday was pea sized and mostly clear yet fell from a cloud that had a top of perhaps 15,000' and was not producing thunder. Mike MU-2 |
![]() "Mike Rapoport" wrote in message link.net... "Icebound" wrote in message ... "Mike Rapoport" wrote in message ink.net... "Ron McKinnon" wrote in message news ![]() "Mike Rapoport" wrote in message nk.net... TCU have, as you would expect, characteristics between CU and CB clouds. All three can be thought as different stages of the same think, a cloud pruduced by convection. Obviously three seconds before a TCU starts producing lightning and becomes a CB, it is going to a lot like a thunderstorm inside. A minor point: A TCU will not 'produce lightning to become a CB'. If it produces lightning it *is* a CB, and has been for some time, but it is not the production of lightning that makes it a CB. That is what I said ( I think) A thunderstorm becomes a thunderstorm when the thunder starts. Three seconds before the first lightning, it is still a TCU. Well, no. A TCU becomes a cumulo-nimbus when the rounded califlower-like shape of the TCU begins to top off with a wispy fibrous top, often stretching downwind like an anvil. This is ice crystals forming at the very top of the cloud. That is the classic definition used by weather services. Observers will not call it a CB if they continue to see the hard-edged form at the tops.... not until they see the formation of the wispy fibrous top. However, once lightning, or hail, or funnel-clouds are observed, the observer will almost surely class it a CB, regardless. Do you have a source of this definition? I can't find one but while looking, I found several sites with pictures of CBs that don't all have the wispy tops Here is one: http://www.chitambo.com/clouds/cloudshtml/calvus.html I chose the definition from the Canadian Manual of Observation which defines CB: DEFINITIONS OF CLOUDS Cumulonimbus: Heavy and dense cloud with aconsiderable vertical extent, in the form of amountain or huge tower. At least part of its upper portion is usually smooth, or fibrous or striated, and nearly always flattened; this part often spreads out in the shape of an anvil or vast plume. ----- But some more insight can be obtained from the World Met Organization code-table: http://badc.nerc.ac.uk/data/surface/code.html (Low cloud type) Code 3 allows a CB to be defined without the "clearly fibrous" tops, but which must "at least partially, lack sharp outlines", ....which shows the the icing of the tops has begun. Code 9 CB requires the "clearly fibrous" top. The key is that to meet the classic definition of CB, the icing of the tops (and hence the smoother fibrous shape)... has at the very least, begun to form. It is not necessary that a CB produce lightning, nor hail, nor heavy precipitation, nor Mammae, Funnel Clouds, Tornados or Waterspouts. It can do none of these things and still be a CB. But if any of these things happen it is necessarily a CB. I am not sure what you are saying here, If it doesn't produce lightning it isn't a thunderstorm (CB) so I would say that it is nessesary for a CB to produce lightning. The production of the ice-crystals at the top will normally be accompanied by lightning, but ever if it is not, it would still be called a CB if the fibrous ice-crystal anvil-shaped top exists. Conversely, when a TCU is only slightly taller than a CU, it is going to be more like a CU inside. There is a relationship between the vertical height of a convective cloud and turbulence but it is not absolute. I have never heard of large hail coming from anything other than a big CB. If it hails, it's a CB, by definition. A TCU can produce snow pellets, however (and ice pellets, I think (it's been a while)), This is the first time that I have heard that hail defines a thunderstorm. A thunderstorm is defined by lightning (and therefore thunder). Hail is produced by updrafts in a cloud through the freezing level allowing frozen precipitation to remain aloft and grow. I don't see why this couldn't happen without lightning. I was hailed upon yesterday and there was no thunder. Hail (hard "real" hail, not the soft stuff in some cold-weather cumulus) ... Hail does not define a thunderstorm, but because the conditions required for it are typically exactly the same that produce lightning and the rest of the CB symptoms, you will be hard pressed to find an observer who will not call a hailing cloud a CB, just because he hasn't seen lightning or heard thunder. I agree that most observers would call a hailing cloud a CB but the hail that fell on me yesterday was pea sized and mostly clear yet fell from a cloud that had a top of perhaps 15,000' and was not producing thunder. Where, geographically? And did it fall on you on the ground, or did you encounter it in flight? And how was the cloud top determined. |
![]() "Icebound" wrote in message ... Snip I chose the definition from the Canadian Manual of Observation which defines CB: DEFINITIONS OF CLOUDS Cumulonimbus: Heavy and dense cloud with aconsiderable vertical extent, in the form of amountain or huge tower. At least part of its upper portion is usually smooth, or fibrous or striated, and nearly always flattened; this part often spreads out in the shape of an anvil or vast plume. ----- But some more insight can be obtained from the World Met Organization code-table: http://badc.nerc.ac.uk/data/surface/code.html (Low cloud type) Code 3 allows a CB to be defined without the "clearly fibrous" tops, but which must "at least partially, lack sharp outlines", ....which shows the the icing of the tops has begun. Code 9 CB requires the "clearly fibrous" top. The key is that to meet the classic definition of CB, the icing of the tops (and hence the smoother fibrous shape)... has at the very least, begun to form. Thanks! I have been using "CB" and "thunderstrom" interchangably, perhaps this is not strictly true. I agree that most observers would call a hailing cloud a CB but the hail that fell on me yesterday was pea sized and mostly clear yet fell from a cloud that had a top of perhaps 15,000' and was not producing thunder. Where, geographically? And did it fall on you on the ground, or did you encounter it in flight? And how was the cloud top determined. North Idaho. I was on the ground (bicycling in hail of all things) The tops I estimate at 10-12k based on my experience flying in the area (I am confident that I could easily top them VFR). I gave 15,000' as a very conservative estimate, I have a high degree of confidence that they were lower. The highest terrain around is 6200' and this was sticking to the bottom of the cloud so the vertical height was about 6000'. Mike MU-2 |
![]() "Mike Rapoport" wrote in message ink.net... "Icebound" wrote in message ... Thanks! I have been using "CB" and "thunderstrom" interchangably, perhaps this is not strictly true. Ron has correctly described the difference. CB is a cloud, thunderstorm is a condition reported only when thunder is heard or lightning seen. Being the "thunderstorm cloud", the terms CB and thunderstorm are often used interchangeably in generic descriptions, but we can and should be more precise. I agree that most observers would call a hailing cloud a CB but the hail that fell on me yesterday was pea sized and mostly clear yet fell from a cloud that had a top of perhaps 15,000' and was not producing thunder. Where, geographically? And did it fall on you on the ground, or did you encounter it in flight? And how was the cloud top determined. North Idaho. I was on the ground (bicycling in hail of all things) The tops I estimate at 10-12k based on my experience flying in the area (I am confident that I could easily top them VFR). I gave 15,000' as a very conservative estimate, I have a high degree of confidence that they were lower. The highest terrain around is 6200' and this was sticking to the bottom of the cloud so the vertical height was about 6000'. I don't pretend to be an expert in mountain meteorology. But because the direction of the wind plays such an overwhelming part in the lift equation, it would be my guess that a TCU was developing, the vertical currents were there, the coalescence of water was occurring and freezing. But in a typical flatland TCU/CB this build-up keeps going for perhaps up to couple of hours and great height, here I would guess that a wind change killed the vertical currents rather quickly... and the precipitation, no longer supported, simply fell out. My guess, don't know. |
Cumulus releases version 1.2.1 | André Somers | Soaring | 0 | March 2nd 05 09:58 PM |
Four States and the Grand Canyon | Mary Daniel or David Grah | Soaring | 6 | December 6th 04 10:36 AM |
[Announcement] Cumulus 1.1 released | André Somers | Soaring | 0 | January 24th 04 11:59 AM |
Blue Clouds | Mark Cherry | Simulators | 0 | September 21st 03 12:57 PM |
Across Nevada and Part Way Back (long) | Marry Daniel or David Grah | Soaring | 18 | July 30th 03 08:52 PM |
