Mike Spera wrote in message ...
One well known aviation university teaches you to "fly out on the tank you flew in on". The theory being that takeoff is not the time to "test" whether a tank you just switched to is blocked, the fuel valve malfunctioned, a tank is empty (cuz you forgot to check it), a tank you just switched to is full of water, etc. Pretty poor theory. It's a haphazardway of avoiding actually managing your fuel. I'm more of a measure, calculate type of guy myself. I keep a log of the tanks in flight in my Mooney (I don't have a "both" selector). I also don't buy into the "fill the tanks before take off" B.S. You should know how much fuel you need and how much extra you'll need. I just don't see putting 8 hours of fuel in my Mooney and pushing around like an over stuffed whale. All this reminds me of the Bonanza pilot who declared a fuel emergency only to discover he had another 3 hours of fuel. He always put 5 hours in it, but never let it go below 2 hours, he burned 12gal/hr but caluclated it as 15 gal/hr, etc, etc. All this "extra safety buffer" just meant he had NO idea how much fuel he had. -Robert, CFI |
![]() "Robert M. Gary" wrote in message om... Mike Spera wrote in message ... One well known aviation university teaches you to "fly out on the tank you flew in on". The theory being that takeoff is not the time to "test" whether a tank you just switched to is blocked, the fuel valve malfunctioned, a tank is empty (cuz you forgot to check it), a tank you just switched to is full of water, etc. Pretty poor theory. It's a haphazardway of avoiding actually managing your fuel. I'm more of a measure, calculate type of guy myself. I keep a log of the tanks in flight in my Mooney (I don't have a "both" selector). I also don't buy into the "fill the tanks before take off" B.S. You should know how much fuel you need and how much extra you'll need. I just don't see putting 8 hours of fuel in my Mooney and pushing around like an over stuffed whale. All this reminds me of the Bonanza pilot who declared a fuel emergency only to discover he had another 3 hours of fuel. He always put 5 hours in it, but never let it go below 2 hours, he burned 12gal/hr but caluclated it as 15 gal/hr, etc, etc. All this "extra safety buffer" just meant he had NO idea how much fuel he had. http://www.avweb.com/news/columns/182044-1.html August 9, 1998 Pelican's Perch #7: Run That Fuel Tank Dry! AVweb's John Deakin takes aim at yet another OWT (Old Wive's Tale). While running a fuel tank dry in your recip powered plane may serve to increase your heart rate, John explains why it's not such a bad thing at all, and it is probably a really good idea for most of us. In fact, John explains why it's one of the first things you ought to do with a new plane and how it could save your life someday. |
Matt Barrow wrote:
AVweb's John Deakin takes aim at yet another OWT (Old Wive's Tale). While running a fuel tank dry in your recip powered plane may serve to increase your heart rate, John explains why it's not such a bad thing at all, and it is probably a really good idea for most of us. In fact, John explains why it's one of the first things you ought to do with a new plane and how it could save your life someday. Flying the old Cherokee Six with four fuel tanks, you'd end up with almost 10 gallons unusable if you didn't run a tank dry occasionally. I tried to never let it happen with passengers on board. Screwed up once though... probably scared the hell out of them though nobody said anything about it once I'd explained what had happened. Mea culpa. -- Mortimer Schnerd, RN VE |
![]() "Mortimer Schnerd, RN" wrote in message . com... Matt Barrow wrote: AVweb's John Deakin takes aim at yet another OWT (Old Wive's Tale). While running a fuel tank dry in your recip powered plane may serve to increase your heart rate, John explains why it's not such a bad thing at all, and it is probably a really good idea for most of us. In fact, John explains why it's one of the first things you ought to do with a new plane and how it could save your life someday. Flying the old Cherokee Six with four fuel tanks, you'd end up with almost 10 gallons unusable if you didn't run a tank dry occasionally. I tried to never let it happen with passengers on board. Screwed up once though... probably scared the hell out of them though nobody said anything about it once I'd explained what had happened. Mea culpa. -- Mortimer Schnerd, RN I remember one time in a light twin. I decided to run the auxilliary tanks dry before returning to the mains so that I would have all of my remaining fuel in the mains for the approach and landing. I flew an hour on the mains to get some dump space for the overflow from the injectors and then switched to the aux tanks. After churning along on the auxs for some little time the right engine quit. As I was reaching for the fuel selector to switch it back to the main the left engine quit. The sudden total cessation of engine noise in midtrip got my passengers rather upset until I got them both making appropriate noises again and explained to them what had happened and why I did it that way. :-) Mea Maxima Culpa ... Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) VE |
Highflyer wrote:
I remember one time in a light twin. I decided to run the auxilliary tanks dry before returning to the mains so that I would have all of my remaining fuel in the mains for the approach and landing. I flew an hour on the mains to get some dump space for the overflow from the injectors and then switched to the aux tanks. After churning along on the auxs for some little time the right engine quit. As I was reaching for the fuel selector to switch it back to the main the left engine quit. The sudden total cessation of engine noise in midtrip got my passengers rather upset until I got them both making appropriate noises again and explained to them what had happened and why I did it that way. :-) Mea Maxima Culpa ... I had essentially the same thing happen to me one night coming back from Cleveland in a C-402. I'd been up for almost 24 hours and was exhausted (the flight had been scheduled for early the previous morning, cancelled and then rescheduled as I was getting ready for bed). I had flown all night in a mix of clouds, occasional icing, and VFR. I was moving auto parts from Shelby, NC to CLE, then back to CLT (my home base). No passengers; just me. I took off from Cleveland IFR and my attitude indicator croaked. There was another one on the copilot's side but I was on top before long so it was no big deal. I settled down to cruise on the mains. After an hour of hand flying, I switched over to the auxillary tanks. Then I fell asleep. I woke up to some yaw and less noise... the left engine had quit! I reached over to switch tanks and hit the boost pump to get a restart. Then the other one quit before I could switch that tank. Holy ****! That got my attention. I switched tanks on the right engine and hit that boost pump. By that time the left engine started. A moment later the right one came back. I remember complimenting myself on the accuracy of my fuel leaning. Whew! I swore to God I'd never fall asleep again while flying. I broke my promise twice before completing that flight. What do they say? Any flight that doesn't end up on the 11 o'clock news couldn't have been all that bad. It wasn't that great though... I fought 70 knot headwinds up to Cleveland (rode home at mach two), suffered a right brake failure, failed attitude indicator, got to play with ice, had the company credit card denied twice (at Charlie West and Cleveland), and ran the tanks dry. I really prefer the dull life. -- Mortimer Schnerd, RN VE |
![]() Mortimer Schnerd, RN wrote: Whew! I swore to God I'd never fall asleep again while flying. I broke my promise twice before completing that flight. I read many years ago about a corporate pilot who was repositioning a plane (big twin) from Indiana to Illinois for a morning flight. He'd been flying all day and was tired. He fell asleep enroute and woke up just as the last engine died and the sun was coming up. He made a successful deadstick on a dirt road. When a farmer came along in a truck, he asked where he was. He was in New Mexico. I would have loved to have been a fly on the wall when that guy called his boss and told him the morning flight would be a little late :-)) Weren't there a couple of snoozing airline pilots on a red-eye that overshot L.A. and were finally awakened well out over the Pacific? I seem to recall reading about that one in the paper sometime in the 90s. Tired pilots with autopilots can be a bad combo :-) John Galban=====N4BQ (PA28-180) |
![]() "John Galban" wrote Tired pilots with autopilots can be a bad combo :-) Tired pilots withOUT autopilots could be a dead combo. ;-) -- Jim in NC |
![]() "Mortimer Schnerd, RN" wrote in message . com... Matt Barrow wrote: AVweb's John Deakin takes aim at yet another OWT (Old Wive's Tale). While running a fuel tank dry in your recip powered plane may serve to increase your heart rate, John explains why it's not such a bad thing at all, and it is probably a really good idea for most of us. In fact, John explains why it's one of the first things you ought to do with a new plane and how it could save your life someday. Flying the old Cherokee Six with four fuel tanks, you'd end up with almost 10 gallons unusable if you didn't run a tank dry occasionally. I tried to never let it happen with passengers on board. Screwed up once though... probably scared the hell out of them though nobody said anything about it once I'd explained what had happened. Mea culpa. You might want to try Deakin's approach of gathering fuel data when alone and then be rather cautious of warning passengers that the engine will "burp" before it happens. One aside is that I'd not recommend it with passengers that are "Nervous Nellie's" to begin with. Of all the people that I take as passengers (family and business partners) all have been around GA a long time and so are comfortable with GA (that might be a good thread: Those who will fly airlines but not GA). two of my partners have private tickets, my son has his IR, my daughter her PVT, and my wife has soloed. They have NO problem with an engine burping. It is reassuring to know that my useable fuel is actually eight gallons more than the specs portray...not that I push that foolishly. -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
Matt Barrow wrote:
You might want to try Deakin's approach of gathering fuel data when alone and then be rather cautious of warning passengers that the engine will "burp" before it happens. One aside is that I'd not recommend it with passengers that are "Nervous Nellie's" to begin with. What I actually tried doing in the Cherokee Six was staging legs that didn't require me to run things dry. For example, I could fly a C-210 nonstop from UZA to MYAM (Rock Hill, SC to Marsh Harbour, Bahamas, 650NM) and land with 1.5 hours of fuel. The Cherokee Six on the same trip required a stop in VRB (Vero Beach, FL) to take on fuel. The only time I ever ran a tank dry with people on board came from such a trip. I had landed on a main and forgot to switch to one of the other tanks and ran it dry about 1500 feet in the air immediately after takeoff. The silence was deafening. I hate when I do stuff like that. -- Mortimer Schnerd, RN VE Pilot's Prayer: "Dear Lord, please don't let me screw up today. And if I do, don't let anybody see it." |
First Two Aero Lessons This Weekend (Long) | David B. Cole | Aerobatics | 12 | December 3rd 04 01:18 AM |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
Flight test update - long | nauga | Home Built | 1 | June 5th 04 03:09 AM |
SWRFI Pirep.. (long) | Dave S | Home Built | 20 | May 21st 04 03:02 PM |
Across Nevada and Part Way Back (long) | Marry Daniel or David Grah | Soaring | 18 | July 30th 03 08:52 PM |
