#31
![]() "Doug" wrote in message oups.com... Well, I had received a preflight briefing. No mention of T Storms or ice. I was below the freezing level. Now you see, if I had KNOWN what was going to happen to me BEFORE I went into that cloud, I would not have done it. But I didn't KNOW ahead of time that I would get ice. I thought it would just be rain and maybe a little bumpy. Also, I was on my flight plan. My route took me through the cloud. Flying through clouds is what IFR flying is all about. I didn't see any lightning. It was a towering cumulus. I'd never had one of those in my path before. The preflight briefer said it was "just rain". If I encountered one of those now, assuming I could see it ahead of time, I'd request a diversion around it. That decision is based on experience. My experience made me wiser than I was previous to this event. It is possible to be ignorant even though one is intellegent, by the way. Ignorance means one just does not know, is not informed on the subject on hand. Not that one is stupid or unable to understand the subject. And the fact that I was ignorant on this subject does not mean I was ignorant of the entire subject of weather. I was never told not to fly into towering cumulus clouds. I was told not to fly into thunderstorms. I believed and still believe there is a difference. The whole reason I posted was to share my experience with others. Not to set myself up for ridicule because of my ignorance. I am sorry you took it that way. I have no idea about the depth or breadth of your weather knowledge, nor your prowess as a pilot, except from what you yourself stated, and what you yourself said that you did. You stated that you were 'Pretty ignorant about weather', and that you flew into a big, dark, TCU. I can only infer from this that you were 'Pretty ignorant about weather', and that you had no idea what to expect within a big, dark, TCU. My query was merely one of astonishment, and an expression of a conundrum that one could indeed be 'pretty ignorant' about weather' and have no idea what to expect within a big, dark, TCU by the time they're an instrument rated pilot. But in this there was no ridicule of you, nor impugning of your intelligence, nor any intent to do so. I am sorry if you took it that way. I stand corrected. |
#32
Ron,
No problem. Doug |
#33
![]() "Ron McKinnon" wrote in message news:Hfb9e.1074608$8l.983385@pd7tw1no... Some degree of weather knowledge is in most places a requirement for the Private licence/certificate, and, considering what's at stake, I'd think a pilot'd would have acquired more than the bare minimum knowledge by the time they've got an IR. Apparently not. You would think so, wouldn't you. I find it rather amazing that a certain number of IR pilots seem to look at their rating as a wand that magically makes IMC something benign... to be relished and welcomed. IMC is to be treated like the plague. It contains icing, turbulence, disorientation. It forces your dependence on electrical and mechanical devices which, reliable as they may be, are never completely infallible. The forecaster's ability to predict the precise conditions within the IMC is way less than that for VMC situations, and especially so for the most dangerous conditions. With all that going for it, flight into IMC should always be initiated only with the greatest of care. Part of that care, you would think, is a rather complete knowledge of the processes that produce it and that suppress it. And at least a passing knowledge as to how to recognize them on a weather chart as part of pre-flight planning.... |
#34
Fascinating discussion. Someone versed in learning theory could
probably put what seems obvious here - reading about it only imparts some unverified, unvalidated knowledge. Poking your nose in it completes the package. Re-reading the entire post suggests to me that the original poster was asking for some insight to all the stuff he has read to date. Despite all the various opinions and guidelines - there is still no definitive procedure for when one may safely penetrate a Cu and when one should not. In the end, you have to start poking your nose in a few and calibrate what you've read. Or you can simply *never* fly in one (at least not knowingly - see embedded)and limit your flying to visual reference or stratus-only (is there a rating for that?) As one poster pointed out, training doesn't require any actual. Without it, a lot of the weather training leaves one pretty ignorant about a lot of weather. Interestingly, this particular thread provides the so-called 'ignorant' with perhaps more insight than can be gained from any training manual. Def: "Weather Ignorant" he/she who has yet to poke one's probiscus in weather that one's common sense had decided to avoid like plague in future. Ron McKinnon wrote: "Doug" wrote in message oups.com... Well, I had received a preflight briefing. No mention of T Storms or ice. I was below the freezing level. Now you see, if I had KNOWN what was going to happen to me BEFORE I went into that cloud, I would not have done it. But I didn't KNOW ahead of time that I would get ice. I thought it would just be rain and maybe a little bumpy. Also, I was on my flight plan. My route took me through the cloud. Flying through clouds is what IFR flying is all about. I didn't see any lightning. It was a towering cumulus. I'd never had one of those in my path before. The preflight briefer said it was "just rain". If I encountered one of those now, assuming I could see it ahead of time, I'd request a diversion around it. That decision is based on experience. My experience made me wiser than I was previous to this event. It is possible to be ignorant even though one is intellegent, by the way. Ignorance means one just does not know, is not informed on the subject on hand. Not that one is stupid or unable to understand the subject. And the fact that I was ignorant on this subject does not mean I was ignorant of the entire subject of weather. I was never told not to fly into towering cumulus clouds. I was told not to fly into thunderstorms. I believed and still believe there is a difference. The whole reason I posted was to share my experience with others. Not to set myself up for ridicule because of my ignorance. I am sorry you took it that way. I have no idea about the depth or breadth of your weather knowledge, nor your prowess as a pilot, except from what you yourself stated, and what you yourself said that you did. You stated that you were 'Pretty ignorant about weather', and that you flew into a big, dark, TCU. I can only infer from this that you were 'Pretty ignorant about weather', and that you had no idea what to expect within a big, dark, TCU. My query was merely one of astonishment, and an expression of a conundrum that one could indeed be 'pretty ignorant' about weather' and have no idea what to expect within a big, dark, TCU by the time they're an instrument rated pilot. But in this there was no ridicule of you, nor impugning of your intelligence, nor any intent to do so. I am sorry if you took it that way. I stand corrected. |
#35
![]() "Maule Driver" wrote in message . com... Fascinating discussion. Someone versed in learning theory could probably put what seems obvious here - reading about it only imparts some unverified, unvalidated knowledge. Poking your nose in it completes the package. Re-reading the entire post suggests to me that the original poster was asking for some insight to all the stuff he has read to date. Despite all the various opinions and guidelines - there is still no definitive procedure for when one may safely penetrate a Cu and when one should not. In the end, you have to start poking your nose in a few and calibrate what you've read. Or you can simply *never* fly in one (at least not knowingly - see embedded)and limit your flying to visual reference or stratus-only (is there a rating for that?) Part of the issue is whether the pilot has been sufficiently trained in weather to at least make some judgement calls on his own, as to whether THIS situation is one in which it is probable the the TCU will rip his wings off, or will have some mild turbulence and nothing more. In his preplanning, does he simply read the forecast, (which maybe happened to say nothing about TCU's or CBs), then when he actually encounters one, how can he judge? Is it only: The forecaster's said nothing, so it can't be bad.... or does he make some further mental preparation such as: They were forecasting really serious CB with severe turbc to the south of here, maybe that area has moved further north than expected and they are starting to pop and I should be really careful? OR... This is the only one around and its pretty small in horizontal dimension, so its probably not too severe in there and I'll be through it in a hurry.... OR: It looks to be part of a line, so maybe there is some kind of squall line with extra lift, or maybe that cold front is moving faster than expected, and so probably its going to be more severe.... etc. "Poking your nose in" can be a dangerous thing to do, if you don't really understand what is happening. "Weather knowledge" is NOT: its a TCU, somebody told me those have turbulence, lets find out how bad... "Weather knowledge" is making some educated guess as to the processes at work so that you can make a reasonable judgement as to what severity to anticipate before you go in. Having said all that, if someone is looking for rules of thumb, my preference would be always to avoid penetration of a cloud of vertical development, and especially above the freezing level. Those that I would try to be especially careful of a .... Dark, and/or of broad horizontal extent. The darkness indicated a huge water content, and hence something (updrafts) is holding it up... and its getting ready to come down! .... Part of a line. Could be a weak front or squall line. Extra lift. .... built up quickly and/or appears to be building rapidly. Indicates very strong vertical currents. .... broad horizontally. Shows strong convective power exists, (and it takes longer to traverse). .... in an area where severe thunderstorms were forecast. Self explanatory. Those that I would be more tempted to traverse: White throughout, not dark. Not much water. Narrow. Not in them for long. Been around for a while and not building. Currents probably weak. Isolated, in an area where none were forecast. Convective power probably weak. Embedded in generally stable cloud. If the whole area is relatively stable, less likely that smaller embedded areas would be *severely* unstable. Remember that there is an exception to every rule... of thumb. :-) .... |
#36
This particular one was
Tall Dark No forecast of T storms No lightning Supposed below the freezing level (according to both the forecast and my temp guage) Isolated (they were cells, not really a line) But the kicker for me is It was easily circumnavigated No icing airmet, no tstorm airmet If I had to do it over again, I'd request a 90 degree turn to the right and a decent. Then turn back to course when it looked better. But I dunno, there is no black and white here. It is all about how much risk you want to take. For some, if it's legal, you are good to go. But for me, make the flight as safe as possible. If there is a reasonable, safer alternative, take it. Minimize the time spent in the clouds. Go above them, around them or below them if possible. Fly where the good weather is. Yes, do a little IMC here and there, but don't push it. |
#37
Icebound wrote:
"Poking your nose in" can be a dangerous thing to do, if you don't really understand what is happening. "Weather knowledge" is NOT: its a TCU, somebody told me those have turbulence, lets find out how bad... "Weather knowledge" is making some educated guess as to the processes at work so that you can make a reasonable judgement as to what severity to anticipate before you go in. That's the basic weather knowledge some of us (now) take for granted but that in fact, takes some training and experience to gain. Having said all that, if someone is looking for rules of thumb, my preference would be always to avoid penetration of a cloud of vertical development, and especially above the freezing level. Those that I would try to be especially careful of a ... Dark, and/or of broad horizontal extent. The darkness indicated a huge water content, and hence something (updrafts) is holding it up... and its getting ready to come down! ... Part of a line. Could be a weak front or squall line. Extra lift. ... built up quickly and/or appears to be building rapidly. Indicates very strong vertical currents. ... broad horizontally. Shows strong convective power exists, (and it takes longer to traverse). ... in an area where severe thunderstorms were forecast. Self explanatory. Those that I would be more tempted to traverse: White throughout, not dark. Not much water. Narrow. Not in them for long. Been around for a while and not building. Currents probably weak. Isolated, in an area where none were forecast. Convective power probably weak. Embedded in generally stable cloud. If the whole area is relatively stable, less likely that smaller embedded areas would be *severely* unstable. Remember that there is an exception to every rule... of thumb. :-) All very good stuff. The question is, "how do you get this information and get it added to your knowledge bank?" Well, this thread is a good place with experienced weather pilots giving their best. Reading every issue of every flying magazine for xx years can help - I did it and it did. But completing your IFR training I would submit, doesn't do it, unless one has access to instructors and pilots that can somehow share their knowledge. Everyone doesn't have that. I spent over 10 years racing cross country in gliders. Every hour was spend evaluating *every single cloud* in sight. After evaluating them, I often flew under them and had a chance to validate what I saw. When I screwed up, I often found myself on the ground. Along the way I was rained on many times, landed out many times, sucked up into a TCU where redline was required to get out, and hit by hail from below. I've (stupidly) flown underneath a few thunderstorms, been in a microburst, and landed in the middle of several storms, one notably with lightening (if the finish line is under one and you made it that far, are you going to quit and landout or finish? Landout is the answer but I was younger then and foolish) After all that, I found I still had a lot learn about actually flying *in* those same clouds. I knew to stay out anything that looks or smells like a TCU or thunderstorm. But I wasn't prepared for just how violent those benign looking pure white Florida afternoon Cu's could be. Or how terrifying embedded *light* convection can be when you can't see where it is or really know how strong it might get. Or conversely, just how comforting Stormscope, or radar, or ol' Cheap ******* can be on a southern afternoon. And I had no experience with ice - and though I've been dipped in it a few times I'm fortunate in that there's so much good writing on the subject that I've been able to avoid scaring myself so far. It's hard to gain "weather knowledgeabe" status. And how many people here are "knowledgeable" and yet not scared themselves in weather they should have avoided? Or Icebound, how did you come up with that name? |
#38
![]() "Maule Driver" wrote in message . com... ... Or Icebound, how did you come up with that name? Hee-hee. I just looked at my life: .... and realized that half the time I scrape it off my windshield, drive on it, walk on it, even play on it. I used to forecast it, saw its effects on the hulls of large ships, watched it snap every power pole in my village, saw it destroy my father's crops. My boat sits suspended above it for 6 months of the year, waiting for those few short summer weeks when it can be truly called a "pleasure" craft. I have flown as a passenger in it, (watching an hour of mysterious pump-handle activity by the DC3 co-pilot, probably keeping the leading-edge-boots working???). I have never flown in it as a pilot, (and freely admit that my opinions come from meteorological, and not aviation, experience). Best of all, it cools my gin-and-tonic while I visit aviation newsgroups where it is a topic of serious discussion. |
#39
Hee Hee!
Icebound wrote: ... Or Icebound, how did you come up with that name? Hee-hee. I just looked at my life: ... and realized that half the time I scrape it off my windshield, drive on it, walk on it, even play on it. I used to forecast it, saw its effects on the hulls of large ships, watched it snap every power pole in my village, saw it destroy my father's crops. My boat sits suspended above it for 6 months of the year, waiting for those few short summer weeks when it can be truly called a "pleasure" craft. I have flown as a passenger in it, (watching an hour of mysterious pump-handle activity by the DC3 co-pilot, probably keeping the leading-edge-boots working???). I have never flown in it as a pilot, (and freely admit that my opinions come from meteorological, and not aviation, experience). Best of all, it cools my gin-and-tonic while I visit aviation newsgroups where it is a topic of serious discussion. |
#40
![]() "Icebound" wrote: ... Or Icebound, how did you come up with that name? Hee-hee. I just looked at my life: ... and realized that half the time I scrape it off my windshield, drive on it, walk on it, even play on it. I used to forecast it, saw its effects on the hulls of large ships, watched it snap every power pole in my village, saw it destroy my father's crops. My boat sits suspended above it for 6 months of the year, waiting for those few short summer weeks when it can be truly called a "pleasure" craft. 8^) Hmmm... Maybe I should call myself "Humiditybound." -- Dan C-172RG at BFM |
Cumulus releases version 1.2.1 | André Somers | Soaring | 0 | March 2nd 05 09:58 PM |
Four States and the Grand Canyon | Mary Daniel or David Grah | Soaring | 6 | December 6th 04 10:36 AM |
[Announcement] Cumulus 1.1 released | André Somers | Soaring | 0 | January 24th 04 11:59 AM |
Blue Clouds | Mark Cherry | Simulators | 0 | September 21st 03 12:57 PM |
Across Nevada and Part Way Back (long) | Marry Daniel or David Grah | Soaring | 18 | July 30th 03 08:52 PM |
