SeeYou and Volkslogger
Old April 20th 05, 09:25 PM
Mal.com wrote:
have you tried using strepla
Yes - I couldn't get it to work either.
what error came up !
No error "came up", nothing happened. The Volkslogger did not see any
communication from the PC and defaulted to the usual logging mode.
I tried to download a flight from my Volkslogger using SeeYou
(latest
version) without success. Has anyone successfully done this?
Tom
Old April 21st 05, 04:03 PM
Mal.com
Well if both cant do it that points to a connection problem check the com
port connection!
Are you using the serial cable with a power pack or battery yes?
What operating system are you using ?
You can set the logger to PC mode via the logger menu this can help as you
have 9 second window to get communication before it starts logging
set the pc mode open strepla then press F8 try com 2 with 9600 baud rate.
Go via the ACT: menu then PC: mode
If you change the com port try a reboot or program restart.
Are you running a software firewall on your PC ?
HTH
Mal
http://www.strepla.de/StrePla3/engli...exEnglish.html
(latest
Tom
Electronic declaration (for Volkslogger) stephanevdv Soaring 0 June 23rd 04 11:54 PM
Volkslogger woes Dan Rihn Soaring 10 March 25th 04 03:10 PM
Volkslogger questions Dan Rihn Soaring 1 January 7th 04 02:26 AM
Volkslogger flight log problem Bill Staley Soaring 1 October 7th 03 03:26 PM
