![]() "Larry Dighera" wrote in message ... On Thu, 21 Apr 2005 16:48:00 -0700, "mindenpilot" wrote in :: Being instrument rated, I am aware of practice instrument approaches in VMC. But does ATC consider them as being conducted in under IFR or VFR regulations? That is my point. Perhaps one of the ATC professionals among the readership of this newsgroup is will be able to cite the relevant FAA Order governing this. In the article mentioned in the OP, it says that flights would be restricted to IFR flights on an IFR flight plan. I'm still not sure if you could get away with simply filing an IFR flight plan and flying it maintaining VFR the entire time. As Larry mentioned, could an ATC pro clear this up? Thanks, Adam N7966L Beech Super III |
![]() In the article mentioned in the OP, it says that flights would be restricted to IFR flights on an IFR flight plan. I'm still not sure if you could get away with simply filing an IFR flight plan and flying it maintaining VFR the entire time. As Larry mentioned, could an ATC pro clear this up? To operate under an IFR flight plan (as in UNDER A CLEARANCE) you must be instrument rated and current. What the weather is like doesn't matter. Either you CAN legally accept an IFR clearance or you CANNOT. Also, in a general comment regarding the whole thread... I'm noting that this discussion is being based on a lay-media article that is not being written to a pilot/industry audience. I wouldn't be surprised if either an STMP is placed in effect for this event, with reservations required, or perhaps other clarification being disseminated by NOTAM closer to the event. Dave |
![]() "Dave S" wrote To operate under an IFR flight plan (as in UNDER A CLEARANCE) you must be instrument rated and current. What the weather is like doesn't matter. Either you CAN legally accept an IFR clearance or you CANNOT. If that is true, how can a pilot who has let his currency lapse, get current again? Doesn't he have to be on an IFR flight to get current again? -- Jim in NC |
![]() Morgans wrote: "Dave S" wrote To operate under an IFR flight plan (as in UNDER A CLEARANCE) you must be instrument rated and current. What the weather is like doesn't matter. Either you CAN legally accept an IFR clearance or you CANNOT. If that is true, how can a pilot who has let his currency lapse, get current again? Doesn't he have to be on an IFR flight to get current again? Either with another pilot in the plane serving as safety who can accept the IFR clearance (and IS the PIC for that purpose), or under VFR under the hood with a safety pilot.. Or with an authorized instructor for an IPC. (Who can conduct it under either above listed method) Dave |
![]() "Dave S" wrote in message link.net... Morgans wrote: If that is true, how can a pilot who has let his currency lapse, get current again? Doesn't he have to be on an IFR flight to get current again? Either with another pilot in the plane serving as safety who can accept the IFR clearance (and IS the PIC for that purpose), or under VFR under the hood with a safety pilot.. Or with an authorized instructor for an IPC. (Who can conduct it under either above listed method) Dave This is what the instrument proficiency check is all about - what is it, six months after the 6 months? Requires a CFII if I understand correctly... |
![]() Morgans wrote: "Dave S" wrote To operate under an IFR flight plan (as in UNDER A CLEARANCE) you must be instrument rated and current. What the weather is like doesn't matter. Either you CAN legally accept an IFR clearance or you CANNOT. If that is true, how can a pilot who has let his currency lapse, get current again? Doesn't he have to be on an IFR flight to get current again? No. |
![]() mindenpilot wrote: In the article mentioned in the OP, it says that flights would be restricted to IFR flights on an IFR flight plan. I'm still not sure if you could get away with simply filing an IFR flight plan and flying it maintaining VFR the entire time. As Larry mentioned, could an ATC pro clear this up? Sure that's no big deal. |
In a previous article, Newps said:
mindenpilot wrote: In the article mentioned in the OP, it says that flights would be restricted to IFR flights on an IFR flight plan. I'm still not sure if you could get away with simply filing an IFR flight plan and flying it maintaining VFR the entire time. As Larry mentioned, could an ATC pro clear this up? Sure that's no big deal. Maybe ATC won't care, but the FAA does care because you'd be violating a FAR. -- Paul Tomblin http://xcski.com/blogs/pt/ It could have been raining flaming bulldozers, and those idiots would have been standing out there smoking, going 'hey, look at that John Deere burn!' -- Texan AMD security guard |
"Paul Tomblin" wrote in message
... [...] I'm still not sure if you could get away with simply filing an IFR flight plan and flying it maintaining VFR the entire time. As Larry mentioned, could an ATC pro clear this up? Sure that's no big deal. Maybe ATC won't care, but the FAA does care because you'd be violating a FAR. That depends on the intent behind "mindenpilot"'s question. Nothing he specifically said precluded legal operation. A pilot not instrument rated filing an IFR flight plan would indeed be violating the FARs. And perhaps that's what "mindenpilot" meant. But that's not what he said. As "Newps" said, it is perfectly fine to file IFR, fly with an IFR clearance, and yet maintain visual conditions the entire time, and even fly under the more relaxed standards of VFR, using a "VFR on top" clearance (which is what I presume "maintaining VFR" in "mindenpilot"'s post really means...you don't "maintain" a set of rules, you follow them, but you DO maintain a certain kind of visual conditions). Pete |
In a previous article, "Peter Duniho" said:
A pilot not instrument rated filing an IFR flight plan would indeed be violating the FARs. And perhaps that's what "mindenpilot" meant. But that's not what he said. Well, except in a previous post, he said: Also, if the weather is VFR, there is nothing stopping us VFR pilots from filing an IFR flight plan and flying in, as long as we maintain VFR Since he referred to himself as "us VFR pilots", it would indeed be a FAR violation for him to file and fly an IFR flight plan, even if he did it in VMC. -- Paul Tomblin http://xcski.com/blogs/pt/ "Zero Tolerance" in this case meaning "We're too stupid to be able to apply conscious thought on a case-by-case basis". -- Mike Sphar |
WI airport closure | Mike Spera | Owning | 0 | March 9th 05 01:53 PM |
N94 Airport may expand into mobile home community, locals supportive | William Summers | Piloting | 0 | March 18th 04 03:03 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Aviation Conspiracy: Bush Backs Down On Tower Privatization Issue!!! | Bill Mulcahy | General Aviation | 3 | October 1st 03 05:39 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
