Jim Weir: help to add car radio to aviation audio panel music input
Old April 22nd 05, 03:42 PM
Brian DeFord
RST Engineering wrote:
Not a problem. If you are trying to make the transistor impedance
converter, and you have a Rat Shack 2N2222 or PN2222 or some other garden
variety NPN transistor ... then ...
Look at the "front" of the transistor. That's the "flat" side. Hold the
transistor with the flat side towards you and the wire leads down.
From the left to right, the leads are "emitter", "base", and "collector".
Don't worry about what the words mean right now.
You also have several inputs to this little amplifier. One is the +12
battery voltage. One is airframe ground. One is the Alpine audio output.
(The Alpine needs a common ground to airframe.)
The collector of the transistor goes directly to +12 battery supply (through
a LITTLE TINY fuse).
The emitter goes to ground through a 470 ohm resistor.
There is a 47K resistor going from the collector to base. There is a 47K
resistor going from base to ground.
There is a 100 nF capacitor (0.1 uF) from the Alpine audio output to the
base of the transistor.
There is a 10 uF capacitor from the emitter of the transistor to the input
of the audio panel. This will undoubtedly be an electrolytic, so the (+)
lead of the capacitor is to the emitter of the transistor and the (-) lead
is to the audio panel.
Did that help?
Thanks you very much!!! That is a BIG help. Thank you for taking the
time to do this. I'll let you know how it turns out!
Regards,
Brian
Aviation Conspiracy: FAA Calls Controller Whistleblowers "Rogue Employees!!! Bill Mulcahy General Aviation 0 March 31st 05 04:29 AM
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Aerobatics 0 May 11th 04 10:43 PM
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Piloting 0 May 11th 04 10:43 PM
Marine Radio using Aviation Antennae Jim Weir Home Built 13 August 12th 03 10:05 PM
