Paul Folbrecht wrote in
: Anyway, on to my question. A couple times now, when I've been navigating direct, either to a fix or airport identifiable by VORs or one that isn't (such as an uncontrolled field with no navaid), I've been asked to "verify direct XXX" when I'm off course by a quite small amount - no more than 10 degrees. Or, perhaps, I've gotten off course a bit and have a larger heading correction (20-25 degrees) in to get back on track, momentarily. I've never had a controller sound annoyed, but it does concern me a bit that they see fit to more or less ask "Are you sure you know where you're going"?? Was it the same controller who gave you the clearance? How far off course were you with respect to miles, not degrees? Especially during controller changes and/or handoffs, controllers may not always have clearly documented the last clearance they gave you. The next controller confirms this either by asking you to verify, or giving you the clearance again. I've had this happen to me numerous times. Generally speaking, though, I have found that a "correction" will only be made if you are off by more than a couple of miles and don't seem to be correcting, or if your error threatens to cause separation issues (although this is more common with altitude busts than heading busts). I look at it as a good thing, not a bad one. One time when flying IFR in IMC I managed to miss a waypoint on an airway. As I flew off the "real" airway I was asked to verify I was on the airway. When I confirmed they indicated that I looked like I was direct to the next waypoint (I think it was RBV or SAX VOR) and not on the airway. When I realized the error and fessed up, they cleared me direct to where I was going anyway - presumably no one else was around, and it was only a few degrees different. But had there been other traffic in the area, and had they not corrected me (ie: RADAR down or what not), it could have led to bad things... Accidents happen, people are only human and do make mistakes. That's why ATC is not annoyed to help you. They're there to help you. They will get annoyed if they have to correct you frequently (READ: NY TRACON if it's more than once, or if they just corrected someone else before you). But everyone gets an occassional correction - I've even heard it happen to Heavies! ![]() |
Clearance: Direct to airport with /U | Judah | Instrument Flight Rules | 8 | February 27th 04 06:02 PM |
Direct To a waypoint in flightplan on Garmin 430 | Andrew Gideon | Instrument Flight Rules | 21 | February 18th 04 01:31 AM |
"Direct when able" | Mitchell Gossman | Instrument Flight Rules | 18 | October 21st 03 01:19 AM |
Filing direct | John Harper | Instrument Flight Rules | 10 | October 9th 03 10:23 AM |
Don Brown and lat-long | Bob Gardner | Instrument Flight Rules | 30 | September 29th 03 03:24 AM |
