Lost Comms While on Vectors for traffic
Old April 23rd 05, 07:11 PM
O. Sami Saydjari
Default Lost Comms While on Vectors for traffic
Yesterday, I was vectored for nearly 30 minutes around/through the
Cleveland Class B airspace. The controller ended up taking me directly
over the airport and north to the lake and then west. As I was doing
this, I wondered what the lost comms procedure would be when you are on
a ATC vector for traffic. Seems the only logical action is to squawk
7600 and resume own navigation to your flight plan. Does that make sense?
-Sami
Old April 24th 05, 06:59 AM
Lynne
Makes sense. However, every vector must be for somewhere. IE:
"Gulfstream zero golf alpha, turn left heading 250 vectors for traffic,
you can expect direct choo choo" If you are not given a location where
the vector is for, it's fully appropriate to ask the controller for one.
Old April 24th 05, 02:23 PM
O. Sami Saydjari
To be unambiguous, through, it seems the instruction would have to
include a time, like "Gulfstream zero golf alpha, turn left heading 250
vectors for traffic, you can expect direct choo choo in 10 minutes,"
otherwise you do not know when to resume direct choo choo.
Old April 24th 05, 02:43 PM
Roy Smith
By the time the controller is done saying all that, you might already be a
hood ornament on the traffic he was trying to vector you around.
Old April 24th 05, 02:51 PM
O. Sami Saydjari
Perhaps, though my experience is that vectors are given WELL in advance
of any possible collision. In my case, I believe they were vectoring to
keep me out of approach paths into Cleveland.
There is still a question of how lost comms is handled in this situation.
Old April 24th 05, 03:46 PM
Roy Smith
Of course. I was being facetious (at least a little bit). There are times
around New York when the controller literally is giving back to back
vectors and there just isn't time for niceties like telling you where
you're headed, but they are the exception.
Step 1, figure out if terrain is an issue. If it is, do whatever you need
to do to avoid terrain.
Step 2, figure out if fuel is an issue. If it is, see step 1 above.
If neither of the above apply, you're in an abnormal situation, but not an
emergency (it would be an emergency if terrain or fuel was a problem).
You've got time to work the problem. Assume they're watching you on radar
and will move any traffic around you.
See if you can re-establish comm. Try a different frequency. My GPS has a
wonderful "Nearest ARTCC" feature. I've used that to re-establish comm
when I lost touch with Approach. Try FSS. Try 121.5. Try calling
1-800-wx-brief on your cell phone. But, I'm weaseling here. Let's assume
you've done all that stuff and you really are left with no way to
communicate, but still have navigation capability. Further assume that
you're in IMC (i.e. can't weasel out of the problem by just landing VFR at
a convenient uncontrolled field).
The rule basicly says to use, in order, cleared, expected, filed. Your
current clearance is an open-ended vector to nowhere, and you haven't been
given anything to expect. At some point you need to abandon the vector and
return to your previously cleared route. The heart of the question is
when, and where do you go when you do decide to abandon the vector.
Unfortunately, there's no good answer to that. You (the PIC) know more
about the exact situation you're in at the moment than we (the folks who
hang out on r.a.ifr) do. Squawk 7600. Pick a reasonable way to get back
on your previously cleared route, and go for it.
Old April 25th 05, 12:38 AM
Newps
No, it's not. You must be given a reason for a vector the first time.
Every subsequent vector is assumed to be for the same reason. Also
there's no requirement to throw in the "expect direct xxx"
Old April 25th 05, 01:21 AM
Jim Burns
I like this short concise approach. My method of teaching this to IFR
students was to "Do what is expected and what makes sense" Remember your
primary instructor pounding into your head that no matter what happens the
first thing you are going to do is "fly the airplane"? That's exactly what
you're going to do if you're IFR on vectors for traffic with no expect
further clearance and loose your comms. You can squak 7600 so they can keep
a better eye on you, but your primary concern is YOU, not them. They will
take care of everybody else, your job is to take care of you.
To think about Sami's situation, he was vetored for traffic directly over
Cleveland's airport, why? There probably aren't any planes directly over
the airport.
Then north to the lake, why? Maybe they were routing approaches and
departures in and out on east and west headings?
Then west, why? Maybe to get him back on his original flight path. Makes
sense.
So if comms fail after you're given those vectors, do what you're cleared
for then do what's expected. If no further clearance time was given, do
what's expected and what makes sense. How much would it hurt to continue
north over the lake before turning west? Look at your map, would it
interfere with anybody else? If not, keep going north until you feel
confident that it's time to turn west. If so, then turn west before it's
somebody elses problem.
The FAA tries to make a rule with a list of "what ifs" for every occasion.
What is often more proper is to simply use common sense and sometimes in
doing so we actually end up complying with the regs by accident.
Old April 25th 05, 02:41 AM
Steven P. McNicoll
"Lynne" wrote in message
Every vector must be for someTHING, not necessarily someWHERE. When
initiating a vector the controller must advise the pilot of the purpose.
The vector may me for traffic or for spacing.
Old April 25th 05, 03:48 AM
G. Sylvester
correct. if they say "vectors for traffic" and you lose comm,
squawk 7600 and then fly direct to your next fix as that is
your clearance. if they
say "fly heading 060" (but not for traffic), it is to
intercept an approach course or victor/jet airway
but it is for something. If they are just handing out vectors
to nowhere just to vector you around the Class B, well
do as they say in thee book. Do as cleared (but with no
further explanation) - expected (they didn't say anything) -
filed. Fly to the next fix even if it is behind you and then
continue on as filed. If they ask you then they can also listen
to the tapes and they should 'expect' a better clearance from
their controllers.
Gerald
Florida Mil and NASA Comms Log - Tues, 18 May 2004 AllanStern Military Aviation 4 July 10th 04 02:00 AM
Florida Military Comms Log - Thurs 15 Apr 2004 AllanStern Military Aviation 1 April 17th 04 08:38 PM
Q about lost comms on weird clearance Paul Tomblin Instrument Flight Rules 34 February 2nd 04 09:11 PM
Lost comms after radar vector Mike Ciholas Instrument Flight Rules 119 January 31st 04 11:39 PM
Soviet Submarines Losses - WWII Mike Yared Military Aviation 4 October 30th 03 03:09 AM
