Spruce
Old April 24th 05, 12:15 AM
COLIN LAMB wrote:
According to expert testimony in one case regarding a failed wing
spar in a
Citrabia, a compression failure can occur when the tree is felled.
I have seen some websites concerning the AD note on the Champion
aircraft
which have micro-photographs of what a compression failure looks
like. It
is very interesting and worthwhile to check out.
Roger that. The compression fracture often occurs in the rebound when
the tree hits the ground.
For a big tree of potentially prime spruce the feller may elect to top
it first, a task not for the faint of heart. A bed of second-growth is
then prepared, into which the tree is felled. No hard strike on the
ground and no rebound. They will ten cut away the lower twenty feet or
so, which will often be used for sounding boards and the like, and be
left with a clean stick up to 80 feet long.
But rather than becoming masts, spars or aircraft wood, the odds are
the tree will end up as fast-food packaging in Japan, Taiwan or Korea.
(Sitka spruce imparts no taste to food.)
If the tree was felled in the Tongas National Forest the lumber company
will pay the American tax-payer approximately $1.70... for the entire
tree. Clearly, we Americans have the best government money can buy :-)
-R.S.Hoover
Old April 24th 05, 04:27 AM
COLIN LAMB
The Pacific Northwest used to have large stands of Sitka Spruce trees.
Alas, they were mostly cut down for airplanes - World War I airplanes to be
exact. Processing plants were set up on the Columbia River right next to
Fort Vancouver, so the military could assist in running production full
tilt.
Colin
Old April 24th 05, 07:35 AM
trees.
to be
exact.
I guess they missed a few trees here & there. According to an FPL
report from the 1930's there was about 45 BILLION board feet of
havestable Sitka spruce in American forests and about three times that
amount in Canada.
But not in large stands. You'll occasionally see a pocket of nothing
but Sitka spruce but it normally grows in mixed stands, usually with
Western Hemlock. That's because of a little bug called the Spruce
Weevil. In the wild, growing in mixed stands, the spruce weevil isn't
much of a problem but it's deadly to single-specie stands of Sitka
spruce, as people have discovered from single-specie 're-forestation'
projects. Major thigh-slapper to foresters. Millions of dollars
wasted to produce square miles of Spruce Weevil fodder. [The weevil
attacks the new growth; you end up with a stunted, ground-hugging shrub
-- a 'forest' less than chest high.) USDA still has a lot to learn
from Mother Nature :-) (Today, the largest stands of Sitka spruce are
probably in Europe.)
The reality of Sitka spruce is that only 6% to 8% of an A-class log is
liable to meet aircraft-quality specs. Even then, the stick has to be
quarter-sawn before it can be accurately graded which means the sawyer
is liable to lose money on the deal unless he knows he's got a market
for it.
Fortunately, that reality works both ways. Since the major expense is
in the wastage and labor of resawing, if you can find a nice balk of
Sitka spruce and do the cutting, curing and grading yourself, you can
save over 90% compared to store-bought 'certified' spruce. (During the
height of the Depression, in order to save on freight and reduce
wasteage, Bill Piper Sr. drove to Oregon and hauled hand-selected loads
of spar-stock back to Pennsylvania on a rented trailer.)
Some lumber companies here in California still run their own barges
down from the PNW (Dixieline is one) and are willing to throw a log or
two on the load and even mill it to your spec. Assuming your pockets
are deep enough :-)
On the other hand, Western Hemlock is an acceptable substitute for
Sitka spruce and is about 8x more plentiful, plus the yield of
'aircraft-quality' timber is 10% to 12% for the same size log.
-R.S.Hoover
Old April 25th 05, 12:25 AM
Caveat Empty Headed
groups.com:
trees.
to be
exact.
amount in Canada.
for it.
are deep enough :-)
OK, let's say i go to the nearest supplier who has (allegedly) got some
Sitka of the correct quality. Let's say he has some boards about 12 foot
long and about 6 inches square.
OK, I think I can manage a ring count and gradient as well as seeing if my
spars will come out quarter sawn. after that, i'm lost. I think I can
probably spot a fracture on a raw board and moisture isn't realyan isue
since i know someone who can kinln dry it for me, but aside formall this,
what am I really looking for?
Old April 25th 05, 01:13 AM
plasticguy
Theres an old AC on the subject. Also look thru AC43.
Another place to look is for "LADDER GRADE" wood.
Older fire department ladders were wood and had very similar
requirements as airplane spars. Asking for ladder grade wood
is easier to do than to ask for airplane spar stock. Now that you have
more places to look, go find what you need. Take a plane and put a few
strokes
on the end of what you might need, look it over. You should be able to
find what you need. NOW DON"T TAKE MY HEAD OFF, I didn't say
to substitute ladder grade for AC43 wood. I just said that the specs are so
close
that asking for ladder grade wood gets you a bunch more places to check out
and doesn't get people afraid of liability...... Scott.
Old April 25th 05, 01:30 AM
Caveat Empty Headed
"plasticguy"
some Sitka of the correct quality. Let's say he has some boards about
12 foot long and about 6 inches square.
if my spars will come out quarter sawn. after that, i'm lost. I think
I can probably spot a fracture on a raw board and moisture isn't
realyan isue since i know someone who can kinln dry it for me, but
aside formall this, what am I really looking for?
have more places to look, go find what you need. Take a plane and put
a few strokes
to find what you need. NOW DON"T TAKE MY HEAD OFF, I didn't say
are so close
check out and doesn't get people afraid of liability...... Scott.
Yeah, I have the AC all right. What i need is a bit more pratical advice.
One of the other guys in my group got some very god spruce form this
dealer. the dealer himself seems to know what it is i'm looking for and is
going to let me see a good selection of logs. Local dealers are a problem
for me, actually (I'm not in the US) Local spruce is crap, forthe most part
and this is genuine sitka from Canada, but it isn't desgnated "aircraft
Spruce" so it's up to me to eyeball it when I'm buying it and make a god
cal on the day so's I don't waste my time and money. The plane idea's a
good one though!
Old April 25th 05, 05:46 AM
Dan, U.S. Air Force, retired
Caveat Empty Headed wrote:
"plasticguy"
a few strokes
are so close
good one though!
Get with your local EAA chapter, they should have a few people who can
show you around.
Old April 25th 05, 03:31 AM
First, find the center of the tree :-)
Looking at the butt-end of the 6x6, note the curvature of the annular
rings. You want to rotate the six-by until the curves are up, the
'cup' is down.
if the log was quarter-sawn the center of the log will be straight
down, relative to the center of curvature. It probably won't be but
the following will still work.
Because a log is a cylinder you can't avoid some curvature in the
annular rings across the width of a spar but you'd like to have them
symmetrical; without any slope from one edge to the other, which is why
you use quarter-sawing. This is because you want the stresses of
flight to be uniformly distributed around the center of the spar. If
their is any slope to the annular rings the center is displaced toward
the down-hill side of the slope. and some portions of the spar's
cross-section end up seeing higher stresses than other portions.
The amount of curvature across a 6x6 will give you some idea of the
diameter of the log. Since you want the flattest possible curvature
you want wood from near the outside of a log about four feet in
diameter. By measuring the center height of an annular ring as well as
its chord (ie, width of the timber) you can work out the diameter at
that particular section of the tree. For 10 rings to the inch , for a
six inch timber, a center height of about a quarter of an inch sez the
tree was about four foot across at that point. Which is good. Closer
you get to the core, the more pin-knots & pitch pockets you'll
encounter. What you'd like to get is wood from the mature growth of
the tree, after it's attained enough height so that it stops throwing
out branches.
So long as the ring count is uniform, anything from 8 per inch on up
will pass inspection but critical builders will often spec a minimum of
10 or 12 rings per inch. Anything more than 16 or so, the weight goes
up faster than the strength, which is why that old-growth Doug fir,
with counts up to 32/in looks better on paper than in use -- the stuff
runs about 40 pounds a cubic foot (!)
If all that checks out, take a look at the run-out of the grain. You
can do this on either surface, once you know how it was sawn. MilSpec
calls for a minimum of 1 in 15, meaning you pick out a grain and follow
it for 15 inches. If it moves more than an inch laterally in that
distance, you look for another stick.
The truth is, minimum grain run-out is determined by the part in the
airplane, in that you'd like to have the grain not run out for the
length of the part. For example, with a 16' spar having a depth of six
inches you'd like to have a run-out of 1-in-32, which would be the
ideal. One in fifteen is a little more than twice that and practice
has shown that's good enough.
In reality, working with wood taken from near the base of the tree (ie,
where the 'cylinder' is fairly uniform), with Sitka spruce it's not
uncommon to see grain having a run-out of one inch in fifteen FEET.
(You really gotta love wood like that :-)
Is it twisted? (If so, you don't want it.) To discover twist, you
need to examine both side of the piece, looking at the position of the
grain relative to the edge and comparing one side against the other.
If the grain is twisted, the run-out on one edge will be different from
the other. That's okay for bridge timbers but when you slice the balk
into spars, they'll tend to turn into pig-tails. Trees exposed to the
wind often have unusual grain patterns -- curves, spirals and so on.
Not the sort of thing you want in an airplane (or a mast).
Compression fractures are easy to spot in freshly sawn lumber (ie, when
you have both sides of the log available for inspection) but difficult
to detect after the lumber has cured. To get it to show up you need to
plane the surface. It's kind of hard to describe what a compression
failure looks like but it gives itself away as an anomolous feature,
usually linear and regular, that cuts across the grain. On close
inspection the annular rings may appear to have been offset by some
small amount and the cellular structure of the wood across the off-set
portion will be compressed. You'll need about a 3x loupe to see this
clearly but the usual inspection doesn't need to go that far since the
other evidence tells you what you need to know.
An honest sawyer won't sell you wood having a compression fracture...
unless you work for Home Depot or whatever. (Then they'll sell you
ANYTHING :-)
Truth is, it's not as hard as it sounds. But it remains a subjective
analysis in which experience plays a crucial role. Fortunately, the
odds are overwhelmingly in your favor.
This has probably been about as clear as mud. Kinda hard to describe
something you learned by actually handling the wood.
-R.S.Hoover
PS -- The liteature takes a stab at explaining 'quarter-sawn' but it's
pretty clear most authors have never stood there and watched it happen
Old April 25th 05, 03:59 AM
Caveat Empty headed
egroups.com:
'cup' is down.
out branches.
ANYTHING :-)
No, actually, that's exactly what i needed. A step by step appraoch to
actually examining a log. All those 1940's reprints of government flyers
bout it have only confused the hell out of me.
-R.S.Hoover
Actually, that's the one part i understand well!
Thanks a million of that. Might be an idea if you wrote that down and sent
it to the EAA to put in some future edition of one of their books.
What Others Are Saying About Aircraft Spruce jls Home Built 29 February 18th 05 11:29 PM
Aircraft Spruce: Abused Customers and Fourteen More Angry Comments -- More to Come jls Home Built 2 February 6th 05 08:32 AM
Buying Junk from Aircraft Spruce --- Or Putting Money Down a Rathole jls Home Built 41 February 5th 05 08:04 AM
Complaints about Churchgoer Jim Irwin and Aircraft Spruce --- Just the Tip of the Iceberg--- They Go On and On and On jls Home Built 6 February 4th 05 07:07 AM
sitka spruce al pernell Home Built 43 February 25th 04 11:02 PM
