Advice on sanding fibreglass
Old April 24th 05, 03:46 PM
UltraJohn
Kent Ashton wrote:
I've sanding a few Cozy/Long-EZ airplanes and I never had any problem with
rash or dust from that but sanding those UNI landing-gear struts will make
me itch for a day. Somehow those UNI fibers get pulled off longer and
form little needles.
Just a heavy long-sleeved shirt and a regular dust mask will do OK for me.
--Kent
From what I know of fiberglass work your not supposed to sand into the
fibers. Just till you BARELY expose the surface of the fiber. So If your
pulling enough fiber off to stick into yourself and cause a rash you are
way overdoing it.
Anyone else to comment, maybe I'm wrong but I think I'm close!
John
Old April 25th 05, 03:15 AM
Roger
On Sun, 24 Apr 2005 14:46:23 GMT, UltraJohn
--Kent
way overdoing it.
Pretty much, but not sanding into fibers is getting ready for the next
lay-up. You will sand into fibers when tapering a lay-up such as when
you add a couple layers at fuselage seams and then sand them to match
into the sides and bottom, or where ever they might be. Another
source of fibers (and they really itch) is sanding down a mill fiber
fill. It's normally used in places where you are going for strength
and I haven't run into many places where I needed to sand it, but man!
mixing up a batch, plus throwing in a little Cabosil to keep the resin
from running out is like playing in a roll of attic insulation.
As Kent said, long sleeve shirts with snug cuffs, gloves, Welder's
skull cap (if you have hair) and a good respirator. NEVER sand
fiberglass or resin without a respirator. Make sure it's a good one
too. I work with Vinyl Ester Resin (Derakane) and that stuff is
potent once it has been catalyzed. Smells nice before that. I use a
good organic vapor filter with a dust filter screwed on over it. I
have the kind that uses matching filters that gasket together and the
dust filter keeps the crap out of the activated charcoal.
I typically take the activated filters and put them in "Ziploc bags"
when not in use. Otherwise the carbon is soaking up *stuff* and
shortening its useful life.
I can work inside the fuselage wiping down parts with Acetone and
never even smell it. Just reposition the mask which breaks the seal
to your face for an instant will prove the filters are doing their
job. :-))
Don't take shortcuts and do "just a little sanding" without the mask.
If you are like me a little sanding may turn into an hour or two.
Good Luck,
www.rogerhalstead.com
John
Old April 26th 05, 11:07 PM
I have had way too many hobbies, including boatbuilding. I have
sanded plenty of fiberglass, mostly without a mask, and now that I'm
older and maybe a little wiser I expect that those several pounds of
dust that have made their way through my lungs to cause some trouble
later on. Dust can get into your eyes, too, even with goggles, and
cause eye irritations that make you look like you've been on a big
drunk. And it didn't seem to matter how much clothing I wore; it got
into everything and made me itch. A cold shower gets most of it off,
while a warm shower can open the pores and let it in so it can bug you
for a few more days.
I have sanded it wet a few times (with air sanders!) and there's
no dust at all, but you have to make really sure things are absolutely
dry before any further layup. Any moisture that gets into the matrix
could cause structural problems. A lot less big a deal in boats than in
airplanes, since most boats are way overbuilt.
Dan
Old April 27th 05, 03:44 AM
Morgans
wrote
I have
; it got
Another good clue for all you plastic airplane guys, is to spray your skin
with hairspray before, and after you sand. When you get in the cool shower,
it will wash off much better. It clogs the pores, so it does not go down
into the pores, then the after spray clumps the fibers together, so they
stay together, and wash off without going into your pores. Spray deodorant
works, too.
Try it! It really works!
Jim in NC
Old April 27th 05, 07:11 AM
Roger
On Tue, 26 Apr 2005 22:44:27 -0400, "Morgans"
wrote
I have
; it got
works, too.
Now that sounds really, really dangerous.
I load up on deoderant, a shot of hair spray and holler, "Dear, I'm
going out to the shop for a couple of hours"... "BANG!"
Old April 27th 05, 11:34 AM
Morgans
So you use open flame for sanding, or is there something else you want to
tell us?
Jim in NC
Fear of Sanding Stuart Grant Soaring 7 January 17th 05 05:28 PM
Advice and experts with 400 series Cessnas (414 and 421), purchase and training [email protected] Owning 36 January 9th 05 02:32 AM
Seeking advice on pilot training approach... Rob General Aviation 8 December 15th 04 12:58 AM
Route Advice? KGEU (Phoenix) -> KEMT (Los Angeles) Eclipsme Piloting 4 August 13th 04 04:15 AM
boot camp advice jameson Military Aviation 17 July 22nd 04 05:12 AM
